Everything posted by Bounty Hunter
Still need the small vacuum canister?
Still need?
Ball joint.......what is this?
Bounty Hunter replied to Jeep Driver's topic in MJ Tech: Modification and Repairs
It's used primarily on d44 axles to set balljoint preload, the amount of force required to turn the steering knuckle. You can also get them with an offset to adjust for camber and caster. Not always the proper method but wth. -
There are MANY more advantages to a Waggy 44, such as larger brakes, serviceable bearings, locking hubs, better high-steer options, stronger axle housing, lower gearing options, and more locker options. I run one to match my 'Zu rear. 6-lug wheels are cheap and plentiful. Sure switching to low pinion is a disadvantage, that's why I'm narrowing two Ford HP44's to run Waggy shafts.
8.8 Axle Swap Into A 90 Comanche
Bounty Hunter replied to Biotex's topic in MJ Tech: DIY Projects and Write-Ups
Not exactly accurate. I have seen a couple of 8.8's fail and lose an axle shaft in person and know of more. So they 8.8's you witnessed break were due to the c-clips? Or they broke a shaft and the axle walked out because it's a c-clip axle? Would take quite a side load to break 'due' to c-clips. -
Good chance the input shaft will not be long enough to reach the seal in the auto.
What Battery Shall I Buy??
Bounty Hunter replied to 500kalle's topic in MJ Tech: Modification and Repairs
Not true. You're thinking of side-post batteries. The studs on a blue-top Optima are adjacent to the top terminals and they're fine for heavy loads such as winching. -
Where To Get A 60, Or 62Mm Throttlebody!?!?!
I've never seen anything available for a 2.5L TBI. I've rebuilt my 2.5L TBI throttle body and there isn't much metal there to remove. Now if it's a '91-'04 throttle body, I make 62mm throttle bodies and spacers. Professionally machined. -
I've had a good experience with my two Blue-top Optimas. The additional stainless threaded studs on top are great for attaching the winch and other accessories. -
Automatic Or Manual
Bounty Hunter replied to 88whitemanche's topic in MJ Tech: Modification and Repairs
I love my manual for tight trails, being able to clutch and roll back for tight 2 and 3+point turns is far easier than brake, shift, brake, shift, brake, shift, of an auto. Auto's are much more prone to water contamination, and go against the KISS method of keeping things simple. -
Problem Reassembling Np231
Bounty Hunter replied to Oddmodman's topic in MJ Tech: Modification and Repairs
I use a wire brush, then follow up with brake cleaner on a rag to clean all the sealing surfaces. Use the RTV very sparingly, 1/16" bead and spread flat with your finger.- 16 replies
- Problem
- reassemble
(and 2 more)
Tagged with:
Wrangler cases are clocked differently, but the difference is where the holes are drilled on the trans, not on the case. Wrangler cases are clocked differently due to the attachment holes in the transmissions being different between Wranglers and XJ/MJ's. The bolt pattern on the front of the transfer cases is the same between Wranglers and XJ/MJ's. So don't worry about a transfer case that comes out of a Wrangler, what you need to pay attention to is input shaft type and rear output length, as they were different lengths over the years.
Your adjustment should be a happy compromise between pinion angle and caster. You may need to run slightly less caster than ideal to get a good pinion angle that doesn't vibe. Since both your UCA and LCA are adjustable, keep an eye on wheelbase and where the tire is in the wheelwell. You may need to change the length of the UCA's as well to get the wheelbase where it needs to be along with the proper alignment specs.
Comanche Front Leaf Conversion - Steering?
Bounty Hunter replied to awc737's topic in MJ Tech: Modification and Repairs
I run BTF high-steer arms on my Waggy front, they're reasonable priced and clear my RE SOA springs just fine. I run TRE's, not heims. You'll need a passenger side flat-top knuckle minimum, unless you want the tierod over the springs too, then pick up a DS flat-top knuckle. The DS flat-top is plentiful and cheap, the PS is a little more rare and costs a little more. Whether you go with the Waggy axle housing or the full-width Ford, you can use the same GM/Jeep flat-top knuckles designed for disc brakes. You can use GM/Jeep parts from the knuckle out on either axle housing. The big benefit of the '78/'79 Ford F250 d44 is the thicker axletubes and high pinion. I'm narrowing two Ford d44's to Waggy width to run Waggy shafts for these two benefits alone. -
Np231 Rebuild And Upgrade
Bounty Hunter replied to skidoo_j's topic in MJ Tech: Modification and Repairs
How were you able to use a non-CV shaft with the SYE? Simply running a different fixed yoke in the rear? I also run the wide chain, 6gear planetary, 2lo, and SYE. Much more strength than my 4banger needs. -
Cool, looking forward to the pics of this tool. I rebuild and upgrade a lot of 231's for folks so post up if you have any questions. What upgrades do you have planned? -
Exactly, that's why I often recommend against the 8.8 rear. Don't get set on a 5-lug wheel pattern. A Waggy front d44 can be had for under $200 and you'll be able to upgrade to high-steer much easier/cheaper. Then you'll also have larger serviceable bearings, larger brakes, and locking hubs. Not to mention a stronger axle housing. I use a Isuzu Rodeo rear d44 so I have 6-lug wheels at all 4 corners, and it has rear disc brakes. Honda Passport would be another rear d44 donor. -
Can you post up some close-up pics of that fire pit?
Later model Toy axles from IFS trucks will have the wider rear axle. It would be a good swap to match the 6-lug Waggy d44 front axle. Even better is the Rodeo/Passport rear d44 as it is 6-lug with disc brakes, although 1" wheel spacers would be recommended. I run a Waggy front axle but I'm narrowing a Ford HP44 to run Waggy shafts and outers. Rodeo rear d44, spools in both.
'95 Np242 Into A '90 4.0?
You know thread count and diameter will be the same, but it's hard to say if the bolt length will be the same between the two different transmissions.- 9 replies
- Transfer Casetcase
- 242
(and 1 more)
Tagged with:
They're expensive. It's best to have one too long that will reach the seal in the transmission than to have one too short, so you can try it and see if it'll fit. If it doesn't fit, you can have your input shaft machined to the correct length, or you can buy the correct one from me for $40, I have a bunch. Retail they're very expensive. The entire t-case requires disassembly to replace the input shaft.- 9 replies
- 242
(and 1 more)
Tagged with:
Being a c-clip axle isn't a downside, have you seen an 8.8 fail due to c-clips? And I'd question being 20% stronger than a d44. Don't forget they commonly spin the axletubes inside the diff housing under a load. This is usually solved by welding the tubes to the housing. I used 55% nickel rods when I welded mine. -
The 95 auto has a medium length input shaft and the ax15 requires a short input shaft, both are 23spl.- 9 replies
- 242
(and 1 more)
Tagged with:
Dana 60 Rear Axle Disc Brake Problems
Bounty Hunter replied to bowsher's topic in MJ Tech: Modification and Repairs
I used a master cylinder from a '79 Grand Marquis with 4whl discs, and a Grand Cherokee 4whl disc proportioning valve.
