TNT
Everything posted by TNT
  1. It isn't done yet and you can see the skill he has. It will be built safe with driveshaft loops and a trans blanket. to potect him. Heat can always be dealt with. Read his threads and you will be amazed..
  2. another one. This one is an old build. http://www.pirate4x4.com/forum/showthread.php?t=495084
  3. Here is some of his other work. http://www.offroadfabnet.com/forums/showthread.php?t=2712 http://www.pirate4x4.com/forum/showthread.php?t=538263
  4. Nice start of a MJ build thread. He does some sick fab work. http://www.offroadfabnet.com/forums/showthread.php?t=2867
  5. TNT
    Went Fisnun But
    I'll put that on my to do list.
  6. bullsh*t. I would sell every comanche I own, and give away my parts, if I could get the brute. x2
  7. I like gearing 4.56 would be my choice for 32"-33" tires.:brows: I'm going with 5.13's and 35"-36" tires.
  8. The LCA's are the super ride version, not the super flex ones.
  9. He probably won't wheel it hard enough. He could probably get away with a Auburn :rotf: If he gets a lunch box locker the carrier break won't matter. ;) I hope he puts that axle to good use I traded the 3.07 geared D44 and some $$$ for it. Factory gears are the best and that axle is in great shape. :D It's a factory 4.09 geared MJ D44.
  10. 15th here :cheers:
  11. So that's what you call it. You been doing the stranger again huh...
  12. For the correct ratio too. :cheers:
  13. You never know. Besides ther should be good info that applies to standard 4.0's too. ;) I have also built over a dozen engines so I will try to help when I can. :D
  14. Signed up and made a few posts. :brows:
  15. Give us some details. Which harness are you using? And what throttle body did you use? It hard to say. Did you swap all the sensors or what did you do?
  16. I like it
  17. I would gladly show them to you. If you come over and helped with my built it just might cost you the parts prices. Are you sticking with the HP D30 or interested is swaping in a HP D44 narrowed to about 62". I can show you how to narrow an axle. If you keep the D30, I can turn the C's for proper caster/pinion angle and correct the spring pad mounting angle also.
  18. The pics will go in the build thread in the MJ Projects forum. :D BTW thank for you input. :cheers:
  19. I have to be able to afford the rear locker so the mini spool is temporary solution. I might have to regear it after everthing else is done. The axles are a big chunk of the budget and since the ratios match they might be last. :roll: My XJ had a welded rearend for about 10k miles. Tire wear wasn't that bad. :brows: As for turning in the snow iit's all about the skinny pedal.
  20. So what tires and rims did you wind up using instead of the 33x10.50-15's? BTW I can build you some long arms in spring or a 3-link like I will be doing. It will save you some cash and will work out great. I'm a fan of the 3-link with a trackbar because there is no binding. You can drive mine when it's done to check out the handling.
  21. Sounds good to me. Thanks
  22. Does anyone have any good trophy truck rear suspension tech or pictures? I plan on a 4-link but this might be better yet. :brows:
  23. Since my build is going to start very soon and I need to finalize my plans before starting. I know some people think a front HP D44 is a waste and a D60 should be used. For me I think A HP D44 is the right choice. Here is what I have planned. I'm getting a complete '87 kingpin axle HP D60 DRW axle for a decent price which I could use for my MJ, but I think it is over kill.. The 1 ton axles weigh too much IMO for higher speed use and ride quality.. I'll just resell it and use the money to beef my D44. I'm sure someone here could find a good home of it. If anybody wants a sweet deal PM me. Since I want it to be close to street legal, 6" of lift and 35"-37" tires are planned. There will be using quite a bit of JeepSpeed influence in the build. I'm plating the frame with 1/8" steel and extending the cab 9" to use 2dr XJ doors for more interior space. It will have a complete rollcage that will tie into the front spring/shock mounts, the front bumper, the rear frame, rockrails and rear shock mounts. A custom dovetailed bed will be built and the frame will be bobbed at the rear shackles. It will have a '95 XJ with a fresh 4.0 that is slightly built. An AW-4 trans and a built/reclocked NP242 transfercase will be used. The XJ will also supply the wiring and creature comforts.... It will be built for speed/ride quality mainly and not as a hardcore crawler, but still want it to be able to hold its own. This is why I'm following a prerunner type of a build. I need suspension that absorbs as much impact as possible. The plan is a front mid length 3-link with a trackbar. Total travel will be about 14" using high quality shocks. Air bumps will be done at some point. For now the rear leaf springs with a traction bar and my 11.5" travel RS9000's are the part of the plan for now. I've been planing a long travel 4 link with coilovers and air bumps in the rear to be done at a later date. About 18" travel coil overs will be sweet. Hopefully I'll have a 2wd MJ by then to keep the miles off of this one. I'm doing as much as possible to maximize uptravel. The front inner fenders are being reworked to allow 35-36" tires to stuff fully. I might switch to Hannemann 6" extension fiberglass prerunner fenders later date. For now it's running stock fenders with the stock flares. They have been raised 4.5" and stretched for a good clearance. Depending on the tire width the tires may stick out a couple of inches. I still need to extend the inner fender so the front end of it curve ends at the core support. I'm splicing it with a second inner fender, changing to a different air filter and relocating the battery.3 I have a '77 F-150 HP D44 axle and a '79 Bronco 9" axle I will be using. The axles will be regeared to a 5.13 ratio. The front axle has 1/2" tubes, will be narrowed slightly, trussed and have the caster/pinion angles properly adjusted. Warn or Superior axle shafts will be used and it will use the strongest u-joint that can handle full time use. A Truetrac will be used in the front. A high steering true crossover will be used if it will clear at full suspension compression. The Ford knuckles and brakes are being swapped for mid '80 Dodge flat top knuckles and brakes. The rearend will be shaved, get disc brakes and be trussed. It will also have a pinion guard built for it. I still haven't decided what diff to use it the rear axle yet, so a mini spool will work for me. With OD and the 5.13 gears the engine will be at under 2600rpm at 70mph with 35" tires. With 36" tires the rpm will be even lower. I'm talking true tire size, some 37" tires only measure slightly over 36". I'm thinking about relocating the radiator, condensor and trans cooler to the bed. I'm just trying to figure out where I can run the plumbing. That would allow me to make a new bumper and help balance out the wieght bias I have the XJ almost totally stripped and should be starting the transformation on the MJ after that. I have a few friends helping me with it. I plan on making some trips around the country to enjoy the some trails and scenery. I have a bad back so ride quailty is a important concern. About the time it gets done I will get my probably get my handicap tags... Having a fawked up back sucks.... But the parking will be better... I plan on updating this post as the build progresses. My back slows up my progress, but the meds help... This will be my last build I do and think the above plan should fit my needs. If you made it this far and have any input post it up. :cheers:
  24. When my wiper motor spot welds broke free from the tube it mounts on I put 3 self tapping bolts in and it has been fine for 2 years. It took about 15 mins from start to finish.
  25. TNT
    Weather WTF
    That really sucks... I feel sorry for the familys it has affected. :cry:
