3
Everything posted by ComancheKid45
My 88 Jeep Comanche Eliminator
ComancheKid45 replied to 88eliminator's topic in Member Projects: Your Comanches
Great job so far! 3-4" of lift and 31s really pops a Comanches looks. -
that little power transmission switch
ComancheKid45 replied to mik666's topic in MJ Tech: Modification and Repairs
Mostly all those settings do are keep the trans out of overdrive. -
jeep lighting mods...
ComancheKid45 replied to mikekaz1's topic in MJ Tech: Modification and Repairs
I ordered a set of those Crees to try out. I'll let ya know how they work. ;) -
AW4 to AW4 tranny swap
ComancheKid45 replied to dcramer67's topic in MJ Tech: Modification and Repairs
Alright thanks....I'll check my harness and see what I find as well -
I didn't get a new harness with the t case, is this something that's already integrated in a stock renix harness? -
Literally just did this last month. Swapped a 95 aw4 and 231 into my 88 MJ. Straight bolt in swap, besides a couple small things Speedo cable housing will need to be swapped in place of the electronic plug. The shift arm on the Aw4 will need to be swapped due to different angles Otherwise its straight forward, Id recommend changing all the seals you can while everything's out and easly accessible and a new torque converter isn't a bad idea as well as check your flexplate on the engine for cracks. The only downside after the swap is you will lose your "part time" indicator light, I'm not sure if theres a way to keep that...Otherwise take your time, hire a friend or 2 for the day and dig in! -
Only issue I've had with their stuff is the downpipe I bought didn't clear the front driveline and rubbed on right hand turns. Alittle clearencing and all was good though...this was on an 88 4.0
88 Comanche (My Style)..."The Blue Truck"
ComancheKid45 replied to ComancheKid45's topic in Member Projects: Your Comanches
And some photos of taking advantage of this nice weather. -
"Worlds Fastest Comanche" Peter Lechtanski 1952 - 2016
ComancheKid45 replied to Automan2164's topic in The Pub
:(- 21 replies
- WFCPeter
- Worlds Fastest Comanche
(and 3 more)
Tagged with:
Got the new exhaust welded up today finalizing this whole adventure. Gonna get er all shined up this afternoon. :) -
Mufflers, what's everyone running?
ComancheKid45 replied to JeepsOLot's topic in MJ Tech: Modification and Repairs
I run Flowtech Raptor mufflers on my trucks and run 18" glass packs in place of the cats. -
What fuel sending unit/pump is this?
ComancheKid45 replied to Crassis-Comanche's topic in MJ Tech: Modification and Repairs
Pumps are the same. Shine a light in the tank and look around, if it's not bad I wouldn't bother with removing it. -
Which RR sliders do you have? The standard sliders or the supersliders with the rail? Supersliders on an XJ. Also super-expensive........... Super sliders. I'm more than happy with them after installing them in 2012, but they took a lot of muscling to get on there
I have the Rocky Road outfitters sliders, which I had to weld on to make work so I can't praise their designing and fitment very well either. I think Krustys sliders look great, I wouldn't be afraid to run em on my trucks.
Looks like a Comanche one to me. -
I'm stuck at work.....haha
Well it's sure been an adventure. After getting it all buttoned up it was evident that the transfer case chain was absolutely shot, so out it came again and the 231 was serviced with a new chain and fork pads. All back together this week only to have the new shift cable fail.....not happy, cheap junk is all it is. I have another of a different brand on the way. The trans and transfer case all work great now atleast, its been a great learning experience as well. :) -
Jeep XJ MJ OEM AM FM CD Player Mopar 82300393
ComancheKid45 replied to HOrnbrod's topic in MJ Tech: Modification and Repairs
Awesome -
I like it!
Alright fellas, I know the whole "fix my noise" approach online isn't always the best but I'm just looking for anymore opinions. Anyway, 88 Aw4/231. Just finished up a transmission and transfer case swap and now have a severe bang/knocking. With the truck on stands and in 4wd it only occurs when hitting the brakes, when driving it occurs when turning and under acceleration. So far I've checked out these parts. Reset and adjusted transfer case linkage Tore apart front diff and examed internals, including, ring, pinion and Spartan locker as well as both axle shafts. Nothing abnormal Fluid in t-case is full and fresh Fluid in ft diff was water contaminated and was swapped, new fluid was also very milky after being in there for a few hundred feet, fresh fluid will be used upon reassembly Axle shaft u joints are both tight and clean, lf is brand new along with shafts. Transfer case was working fine from the previous owner and I have no issues from it in 2wd on the jackstands. So that's where I am, anyone have anything else I should check out?
