ComancheKid45
    3
Everything posted by ComancheKid45
  1. Ha Ha yeah it was a pretty 1, i just remember him saying "some guy in Canada bought it".....i figured it was worth a shot :cheers:
  2. You didnt happen to get that Eliminator from a fellow in Pennsyalvania last year did you?
  3. Awesome! The video itself was even pretty cool
  4. Never saw "Taken" but have seen "Shooter" a few times and will agree on its badassness :clapping:
  5. I Like it! :thumbsup: :yes:
  6. Installed a new Alternator.....Hope my electrical gremlins will leave
  7. Alright, well tonight i just replaced my alternator with a 105amp Delco Remmy from Advance Auto. I changed it in suspicision of a failing Alt. due to low a Voltage gauge and dimming lights at stop signs/ traffic lights while idling and on the brakes. Upon test driving after the new alternator install I noticed that every once in a while (only happened twice) after a bump the gauge will drop into the red, lights all dim for a few seconds then resume. I Checked the connections at the battery, both connections at the Alternator and the belt tension. I also took off the group of eyelets and cleaned all of them and re installed. Battery was replaced in August of 2009. Even after all this my voltage guage still remains at just above the "low" safe mark but my lights no longer dim at idle and on the brakes. I guess the guage is just out of wack since with a Multimeter on the battery under idle conditions with no loads I'm pulling 14.7 volts. Also the Battery cables still seem in good shape with no signs of rubbing through or issues. Anyway, just seeing if theres anything else i should keep an eye on or check out, over the next few days. Thanks for any info! :thumbsup:
  8. didnt really do anything....but i did run into a fella with a pretty nice 89 SWB....316,000 miles on orgional 4.0 :bowdown: but been through 3 Pugeots, lol. I gave him the site address and he seemed really intrested, hope he show up :thumbsup:
  9. itll be a truck :thumbsup:
  10. lol well thats the 1 i went with, besides the fancy chrome trim its the same :rotf:
  11. http://www.summitracing.com/parts/IDT-2600000010/ your welcome :wavey: :rotfl2:
  12. I havent posted in here yet....anyway I'm just as impressed as anybody, if i had an MJ like that idk if it would ever leave the garage, id probably get a fullscale display case and keep it in my living room, lol Great Job and thanks for preserving 1 of these great Trucks
  13. It was a great Truck to be cutting up but the end result is kinda cool for some odd reason. Thats his final video, he has a few showing his progress, including the untouched truck :shake:
  14. I think i'd go this route... Yeah i might have 2 look into this as another project sometime as well.....i did a cluster swap but forgot about my PRND321 switch when i pulled the old cluster and you can figure out the rest, lol oops, atleast all i drive are jeeps so I'm used 2 the shift points :yes: I did this today....$20 from summitracing.com.....works great! :clapping:
  15. you could buy all that at Advance Auto....lol spring spreaders have got to be the most dangerous thing ive found while working there :doh: :rotf:
  16. Throw on the ZJ coils and see how much lift you acctually gain... I threw a set on ontop of my 1.5" BB and gaind .75" of lift, basically leveled the truck out....i have a set of 3" XJ AALs in my garage waiting for an oppertunity somewhere someday, but they werent needed. next to my XJ (only shackle in rear stock height otherwise)
  17. An XJ AAL will work for about half the advertised height on an MJ..... example 3" XJ AAL = approx. 1.5" on an MJ ;)
  18. I hate em! I wanna be in control of my actions, not vise versa..... I have them in my delivery trucks at work and can't stand em in the snow
  19. O ok.....i have 1 Jack and 1 2 peice thingy. but with switching them between 2 Jeeps thats the main reason i was looking for another set. Thanks for the info on the winch tool though :thumbsup:
  20. That gauge is measured in Kilometers :rotfl2:
  21. Alright gonna ask the cheapy question here... What is the maximum amount your alternator can safely put out on the factory 8ga. wire?
  22. I'm looking for The rod that is used 2 lower the spare tire down from the truck, this peice is also used 2 raise and lower the OEM Spare tire jack. If you have the Jack and tool as a set id be intrested in both as a set if the price is right. Make me an offer on what ya got. :thumbsup: Thanks! :waving:
  23. 4.0l AW4 3.55, 30x9.50x15------between 10-13 normally, but my speedo is not calibrated so I'm sure its a bit better :hmm:
  24. Do you remeber what your old gas gauge read prior to the install? maybe you have a full tank? lol Otheresie check your gauge's fuse under the dash, if its blown or missing your fuel gauge will always be inaccurate
  25. Yeah I agree, this would be 1 id try and keep as orgional and clean as possible :thumbsup:
