6
Everything posted by krustyballer16
Need some of you guys' input on it since it might be something else I start building. This one is actually going on my XJ. I had an olddd nates 4x4 bumper made outta 2x4 tubing. Got it at a decent price, added a receiver, light protection and some "decorative" cover pieces on the side. I started ROUGH mock up at work. Its 24" of 5/16"x4.5" (closest i could find to what i needed) down each frame rail to build off of. 1/4" plate, 10" wide across the bottom to mount a winch to. And some different angles up front and I'll need something to mount a fairlead to. And d ring tabs will run down the frame tie ins I kinda wanted something that looks like the narrow dirtbound bumper. Throw some ideas and pics in here. For now it will only be as wide as the frame. Just for recovery. Sent from my SM-G892A using Tapatalk
And dash Sent from my SM-G892A using Tapatalk
Got a somewhat complete burgundy full center console Sent from my SM-G892A using Tapatalk
I've got one that is missing a cover. I'll take it off and he can have it for shipping cost.... Sent from my SM-G892A using Tapatalk
I rattle canned mine with fabric paint from AutoZone. Been 2 years and no wear or rub off... Sent from my SM-G892A using Tapatalk
Epoxy that fuel sending unit leak?
krustyballer16 replied to coolwind57's topic in MJ Tech: Modification and Repairs
We might have too. I had it out a couple times Sent from my SM-G892A using Tapatalk -
I used jb weld on mine and holding strong for 4 years now, no leaks Sent from my SM-G892A using Tapatalk -
2018 Midwest CC PowWow - Badlands, Attica IN on August 25th
krustyballer16 replied to 89eliminator's topic in The Pub
September probably wouldn't work for me. Have a kid scheduled to pop out Sept. 11... Sent from my SM-G892A using Tapatalk -
Woah Black Betty! Ham or Lamb?!
krustyballer16 replied to krustyballer16's topic in Member Projects: Your Comanches
Past couple days I got the brake light switch bracket made and tacked in place for now.ill probably have to add a return spring to the pedal like on my blue MJ. I took the LJ nerf bar off the passenger side. Looks so much better now! Went and bought ZJ radiator hoses to see how they'll work. I'll have to cut and splice but should be an easy job. Put a radiator cap on too Sent from my SM-G892A using Tapatalk -
So... what changed? I can't sleep as you'll notice.
krustyballer16 replied to gogmorgo's topic in The Pub
It would have to be in the bumpers like stated above. Since wheel base is all the same and fenders are all the same, I'd say itd have to be in...front bumper. But that would only affect 84-96 that had the bumperettes... Sent from my SM-G892A using Tapatalk -
Not forward into the steering wheel Sent from my SM-G892A using Tapatalk
You need mj seat brackets for a direct bolt to the floor pan. This requires removing the xj brackets and attaching mj brackets Sent from my SM-G892A using Tapatalk
How to pick non mj specific seats
krustyballer16 posted a topic in MJ Tech: Modification and Repairs
How does everyone that's put different seats in go about figuring out what to get them out of? Does everyone just pick a seat they like that's cheap or free and just slap it in or do you look at specific sizes? If so, how do you measure them? I basically want to know how you know they'll work in your MJ, or if you even do know before you buy them... Sent from my SM-G892A using Tapatalk -
It's not a bushing now with the drop brackets. it just needs a spacer now Sent from my SM-G892A using Tapatalk -
Bo and I just now realized it's missing a spacer in the top/stock control arm spot. Ya,I don't think I'd personally put these on but I'm not swapping em right now or until I have to Sent from my SM-G892A using Tapatalk -
That's the upper control arm drop bracket. It uses the lower drop bracket and the boomerang. I've never seen a set up like this either. Cheap. Sent from my SM-G892A using Tapatalk -
Got a 5.2 y pipe from a buddy that was rebuilding his. Very tight fit on the passenger side and I don't know how I'm gonna get the nuts in the flanges on the top side... Stock 5.2 radiator top hose is close to fitting but not quite. Gonna have to chop it up and make my own. No biggie. Did it on my blue MJ Sent from my SM-G892A using Tapatalk -
I got lucky and now own one! Sent from my SM-G892A using Tapatalk
Got a buuuunch of goodies with Betty too! A lot of black interior! An extra set of MJ seat brackets. Some sweet 80s chrome rain guards, some of Adam's bucket seat lever bezels, black bucket seats, a mini console with a change holder that there isn't many of, if any, out there. No said since there's a 2.5L base in the tailgate, I should turn it into a 5.2L badge so I did, roughly. I'll clean it up And I told him it wasn't a deal if the bunny didn't come with it! So got it! And while I was at Noahs place he gave me a LWB driveshaft that I'll have to cut down to fit since the truck had no drive shafts and I was gonna have to have them made to length anyways Sent from my SM-G892A using Tapatalk -
Can see my list of stuff to do. Got the shifter cable ran and installed. Bo had a floor shifter already set up in the truck. The cable and everything was in the cab, we just had to route and hook it up. That consisted of drilling a hole in the firewall to get inside the cab. The hole is drilled where the cable should go through (looked at my 1990 MJ with the floor shifter. Opened up the rear diff and looked like someone pooped in it...cleaned that up. Front diff was super clean. My dad Got all the wiring under the hood soldered together and done. Took the maroon dash out to mess with brake pedal and brake light switch. When I got the truck the brake pedal and bracket wasn't bolted in. Bo had started to figure out the brake light switch but we didn't really know how it was going so I just took a pedal and bracket out of my 88 parts truck and made the pedal fit the booster rod (knocked the stud out and bolted the rod eyelet on the pedal) Had to put the pedal assembly in. Interior will be tan because eventually I'm going to pai....eh, I'll leave that a surprise... Sent from my SM-G892A using Tapatalk -
Backstory on how i got this truck: About 8 months or so ago when Bo (shelvyluvv) was selling his 86 MJ, black betty, we started talking about it and he talked me into buying it. Ended up throwing him some cash over the next few months and built him some bumpers for his cj5, that he sold before I could deliver the bumpers. But that worked out a little better for me.(has now turned into building a rear bumper for his 48 ford.) Sounds like an awesome exchange, and it was, except we were/are 2000 miles apart. I'm in Cory, Indiana and he is in 29 palms, California. So we set a date for the end of February and slowly started to count down the days. During this time I got ahold of John Jackson (johnj) and ended up going 500 miles north and picking up his TDI swapped MJ and hauling it out to Cali with me. I ended up selling the cj5 bumper to a guy in cali and building a rear bumper, that some of you have seen, for Noah Bricker in Death Valley. Good timing and locations of buyers. (My trip is documented in the Pub section) So I got Black Betty back home after 9 days on the road. Half way through the 5.2L swap. All the hard work done, wiring and mounting the engine and transmission. Still a lot of little stuff to do. Slowly getting it done. Bo's original build thread... https://comancheclub.com/index.php?/topic/3219-Project-"Black-Betty" Now for an image dump to get to present status...
Youre the man with all the links lol. That's Johnj's truck at my house the weekend before I took it out to Bo's in Cali It's a fun little truck to drive. Quiet and smooth. Not as much low end power as my Cummins but once that turbo lights it's a rocket ! But I still prefer my loud rattling Cummins. Sent from my SM-G892A using Tapatalk
- 299 replies
- diesel
- cummins 3.3l
(and 1 more)
Tagged with:
Ya, 1.9L I believe. John's Build is on here Sent from my SM-G892A using Tapatalk
- 299 replies
- diesel
- cummins 3.3l
(and 1 more)
Tagged with:
My Cummins compared to John's TDI Sent from my SM-G892A using Tapatalk
- 299 replies
- diesel
- cummins 3.3l
(and 1 more)
Tagged with:
In what year? Sent from my SM-G892A using Tapatalk
