Minuit
    13
Everything posted by Minuit
  1. Ran by the pick and pull and got a timing cover out of a '95 (with 318,000 miles!) today. It has the timing marks and looks to be 100% exactly the same as my old one. What was the original finish on these? Were they painted or bare aluminum? The donor part is so dirty it's impossible to tell what it looked like 20 years ago.
  2. Dunno about anyone else, but I'd gladly pay $150 to keep fuel injection.
  3. $600 for something in that kind of shape is an absolute steal and it even has the metric ton rear suspension! After seeing the first couple of pics I was about to jump down and write about how you had a set of front mud flaps and that they're rare, etc, then I saw they were diamond plate... yuck. I don't guess the PO got the memo on the "stick 3x5 index cards under the fender flare" masking trick. If he screwed up something that easy I'd be worried that there might be other scary hackjobs hiding under there.
  4. The "joystick" remote mirrors are very common in junkyards. Make sure you loosen the tiny set screw underneath where the joystick comes out (Torx size 6) and don't try to just rip them off.
  5. Thanks a lot! It's comments like yours that keep me going. I've always tried to do the absolute best work on this truck that I can (it's up to you all to decide if I'm successful), and for the most part I'm not a fan of cutting corners. I'm a very detail oriented person - to the point where a minor detail being off makes me very uncomfortable, and I think my truck reflects that. After all, the big picture is just a combination of a bunch of little details, right?
  6. No new pics for now, but things are going to happen next week. I have Wednesday, Thursday and Friday off from school, and I plan on getting the MJ on the road in that time. Here's what I plan on doing: - Heater core - Complete timing chain replacement - Upper control arms & bushings (just wait until you see the condition of the ones in there now) - Fix the frakking driveline vibration, by means of a new driveshaft if necessary (time permitting) Basically, that means I need to get the truck running by Wednesday morning in order to get the A/C discharged and the driveshaft to the driveline shop on Wednesday. Lofty goals, but I can't put into words how tired I am of driving beater Thunderbirds and Buicks. Last weekend, I got the new Cloyes timing chain installed. This one isn't perfect, but it's a lot better than what was in there. I wish it was tighter, but I'm kind of out of options unless I want to piece together a new set from NOS Mopar parts ($$$$$$) as the whole thing is NLA from every dealer I've checked. Installing the camshaft sprocket is a PITA - it interfaces with a (thankfully hollow) roll pin on the camshaft. I suggest sticking something in the roll pin to make alignment easier, like so: Anything that fits in the hole in the roll pin will work. This allows you to slide the entire assembly on evenly. Make sure you line the timing set up (dots facing each other, crankshaft keyway at TDC) before you try to install it. The camshaft bolt gets 80 ft-lbs of torque. Make sure not to lose the spring and pin that fit inside the bolt. If you have good eyes, you might notice sparkly flakes sitting inside the blue oil pan gasket. At first, I thought this was bearing material and nearly had a heart attack, but further inspection showed that the bolt holes on the bottom of my timing cover are almost all completely stripped out, and the flakes in the oil pan gasket are aluminum shavings. Now that I've possibly introduced metal flakes into my engine, as a precaution I'll have to change out my $30 in full synthetic oil after less than 500 miles! I plan on getting a replacement timing cover and some other odds and ends at the junkyard this weekend. I'm already sick and the forecast on Saturday is low 50s and rain... :doh: The things I do to myself for you, truck. You damn well better appreciate this.
  7. Awesome video. The truck is really well done, and the owner seems like a pretty cool guy too.
  8. All good :thumbsup: Let me know if you find anything.
  9. Still looking for one. Not 100% necessary but it would make my life a little bit easier if I could match colors.
  10. Alright, thanks guys. I don't use a timing light much but I'd feel uneasy if something that's supposed to be there was missing. Silly me thinking that was one of those "1964-2006 interchange" parts.
  11. This is a trip back down memory lane for sure. My '91 belonged to my grandparents and sat for a similar amount of time to yours before I got it and got it running. Mine even had exactly the same green crap on it too. Looks like you're working with a pretty solid shell and it seems like you've got a pretty good idea of what you're doing. Looking forward to seeing this one come back to life :thumbsup:
  12. So he can open the cowl induction hood all the way? Just guessing :dunno: I mean you don't really NEED that wiper anyway. Weight reduction.
  13. My 4.0's timing cover is all chowdered up and I'm not spending the money or time on a crappy aftermarket one. Does anyone know what years will interchange with a '91? Would I be alright with just grabbing one from the newest Jeep I can find at the junkyard? Can't find much about this online.
  14. Jumper cables, complete factory jack hardware (a 4-way would make a good addition), 1qt each of oil, ATF, and power steering fluid, as well as a fairly comprehensive tool set, including standard and metric sockets, wrenches (ratcheting and standard) and screwdrivers, and of course my Leatherman that I carry at all times. It all fits behind the seat. I want to be able to save my @$$ or someone else's on the side of the road, and go to the junkyard just with my truck tools if I feel like it. The MJ is nice enough these days that I don't worry about having to fix it on the side of the road, but I like to be prepared. If I have the T-Bird I usually don't take the tools. If that thing breaks on the side of the road I have no hope of fixing it. If the truck is parked I bring it all inside for security. I sometimes do work just with my truck tools so I can be sure that I can service the MJ with just the stuff I carry around.
  15. I've never heard a single good thing about ATK engines. Not just here but from other car/mechanic forums as well. Lots of stories of failures after less than 1000 miles, and not just in Jeep engines.
  16. I might need to look into this. My wipers chatter a LOT until the windshield is good and wet. My current blades are roughly 2 year old Tricos that look a lot like the ones you posted, although my (original) arms might just be worn out.
  17. If you find any threads that are missing key photos, please send a message to the post owner to let them know. If you don't hear back within a week, then let a mod (or Minuit) know so we can see what we can do. thanks! To find a specific item in the list, press the Control and F keys at the same time. A box labeled "Find on Page" or similar should appear. Type in what you're looking for and anything in this list that matches will be highlighted. * - Broken Photobucket pics. ------------------------------------------------------------------------------------------- Important!!! Random informative picture thread Cruiser's mostly Renix tips Best Thread for MJ tips and tricks MJ Registry (Find out your truck's build sheet, birthday, and selling dealership) A/C and Heating Replacing your heater core without pulling out the dash Renix 4.0 AC bracket bearing replacement Revive your dead R12 A/C system with Red Tek R12a refrigerant Fan diagnostics and repair HVAC fan replacement Complete A/C refurb writeup Axles – CAD stuff, axle mods, diff covers, u-joints… A CAD delete technique Another CAD delete technique CAD delete part 1 CAD delete part 2 Air switch for CAD Axle specifications Cheap D30 axle seals Ford 8.8 axle swap 1 Ford 8.8 axle swap 2 Ford 8.8 axle truss Front axle removal Home made D30 differential guard Home made D44 differential cover and drain* Home made POSI lock (manual CAD activation) U-bolt eliminator install Universal joint replacement Axle Gearing – What will X” tire do?, ratios… Tire size (and more) calculators Body Exterior – Panel replacement/mods, window stuff, adding stickers, removing stickers… floorpans and rockers source (Key Parts brand) Fixing dents in a Comanche raising the stock flares to fit big tires Making removable half doors easy repair for rusted/snapped front fascia screws Easy Emblem Restoration Door Window Seals replacement tips for repairing front end damage Relocated Front Fender Flares 97+ taillight conversion 97+ conversion* 97+ power door swap 97+ frontend swap 97+ wiring harness tips Back window (and slider) R-n-R Bed lock for securing cargo Bedside patch panel information Beijing Jeep front panel on an MJ Broken door hinge fix Bushwacker flare installation Datsun 280ZX hood vent install Datsun hood louver install* Dip your Comanche Door hinge repair Door hinge reinforcement install overkill door hinge repair Door latch rehab DIY rear corner guards Fabrication 97+ window regulator hardware Fender flare facelift Hatch strut alternatives Hood pins Hood vent installations How to install front clip JEEP emblem letters* How to open a stuck Hood How to remove and replace door glass Installing 97+ door handles & mirrors* Installing a snorkle Installing half-doors MJ Bed swap MJ floor pan replacement Modifying Cherokee front mud flaps for the rear of a Comanche Modifying Cherokee rear mud flaps for a Comanche Power window regulator restoration* Rear glass removal Removing factory pin striping and decals Rocker panel and cab corner replacement* Rusty floor fix Sliding roof rack Stop your tailgate from rattling Tailgate handle restoration TJ fender flares Using front XJ splash guards on the rear of an MJ Using rear XJ splash guards on the rear of an MJ Windshield replacement with rubber trim (no glue) ZJ 5.9L Hood Vent Install Paint gun - best one for the money! Brakes Proper Comanche brake bleeding (including the prop valve) rear disk conversion using ZJ parts WJ steering and brakes Dana 44 axle seal refurb Dana 44 disk brake conversion mj load-sensing proportioning valve delete procedure 95/96 booster master cylinder brake upgrade with Wilwood proportioning valve 95-96 dual diaphragm brake booster swap Adjustable MJ load sensing brake valve Adjustment procedure for the rear proportioning valve Front combination valve cut-a-way pics How to change your one piece front rotor and wheel bearings KJ discs on an XJ Chrysler 8.25 axle write up One man brake bleeding Parking brake pedal refurbishment Power brake troubleshooting guide Proper Comanche brake bleeding (including the prop valve) Rear extended brake lines Rear load/height sensing valve delete and bypass procedure Use a guitar string for an e-brake cable WJ dual diaphram brake booster swap XJ handbrake in an MJ 1 XJ handbrake in an MJ 2 ZJ disk brakes conversion ZJ disk brakes, WJ dual booster and YJ front brake lines Bumpers – Custom bumpers, installs… Custom bumper build 1 Custom bumper build 2 Custom bumper build 3 Custom front bumper build Custom heavy-duty stock bumper Custom rear bumper 1 Custom rear bumper 2 Front tow points S-10 rear bumper install Warrior bumper install Clutch – Clutch components, other such clutch stuff… 99 clutch master into 87 MJ Clutch master cylinder rebuild Clutch slave replacement Cooling – Radiator tech, fans... 3 ten inch cooling fans install 4.0L radiator installed into 2.5L MJ Closed to open cooling DIY 1 Closed to open cooling DIY 2 Closed to open cooling DIY 3 Dual OEM aux fan installation Dual 2-stage E-fans install How to bleed a closed cooling system Renix 4.0 AC bracket bearing replacement Thermal fan switch for 2.5L Transmission cooler install Downloads – Parts manuals, FSM's, etc... 1988 MJ/XJ Electrical manual Jeep Comanche MJ parts manual Jeep Historical Drawings by Hubert Cossard (French Site) Jeep Parts and Service Manuals Renix FI (Fuel Injection) manual 88-90 Factory Parts Manual 91-93 Factory Parts Manual 84-93 Factory Shop Manual Electrical Cruiser's mostly Renix tips Renix engine sensor testing techniques 87 Factory Electrical Troubleshooting Manual Soldering 101 video factory Sentinal Headlight installation Steering column repair Replacing the headlight switch/connector Headlight switch replacement Addendum to Cruiser54's C101 elimination: Deletes connectors but retains connector housing Adding an auxiliary fuse box Aux input added to factory tape deck Battery cable copper lug source Dimmable dash light LEDs Camshaft sensor test Cruise Control install using factory parts Dual Batterys under the hood Dash harness rebuild/refurbish Factory radio guide Finding an active electrical short Full gauge cluster swap for column shift MJ HO full gauge cluster swap tips HO MJ/XJ Premature Ignition Coil Failure Fix & Relocation How to put an ignition switch back together Installing an aftermarket security alarm system Jeep Ignition Distributor Info Renix connector locations Crank position sensor testing (video) Renix Camshaft sensor replacement Starter relay upgrade Upgrading the puny Jeep meep-meep horn XJ rear harness to MJ rear harness guide Engine – Maintenance, HO engine codes, etc Cruiser's mostly Renix tips All Vacuum line schematics Oil Pressure sender fitting- What to do if it breaks 2.5L aluminum valve cover 2.5L vacuum line info All you wanted to know about oil and oil filters Brown Dog offroad motor mounts review Camshaft sensor test Convert Renix Metric Oil Filters to the More Common SAE Threaded Filters Easy oil changes How to install an HO stamped steel valve cover on a Renix head Installing a 1996 throttle body mounted MAP sensor on early HO engines Installing a 99+ intake manifold Installing a Unifoam filter in the air box Jeep 4.0L cylinder block, crankshaft, camshafts, cylinder head, and connecting rod specs Larger capacity 4.0L engine oil filters MJ Renix to HO Oil Filter Adapter & O-ring Data "Ram air" inlet hose for stock air box Reading OBDI 91 and 92 MJ fault codes Rear main seal replacement Relocating alternator to A/C mount Renix alternator relocation Renix Camshaft sensor replacement Renix extended idle work around Renix Throttle Position Sensor (TPS) testing / adjustment Renix throttle body spacer Renix valve cover breather repair Restoring and refurbishing your valve cover Timing chain replacement XJ/MJ V8 Swap Torque specs for AMC engines Exhaust – Manifolds, mufflers… HO exhaust manifold on a Renix 4.0L Prevent Exhaust Header/Manifold Cracks With a Flex Joint Fuel – Hoses, tanks, piracy fluid… Adding a fuel rail pressure gauge AN fittings how-to Bosch aftermarket fuel-pump install Draining your fuel tank Fixing a leaking fuel tank Fuel injector cleaning 1 Fuel injector cleaning 2 Fuel Injector cleaning 3 Fuel pump ballast resistor upgrade Refurbishing the fuel sender Renix Fuel Injection Factory Manual Interior – Clusters, panels, steering column tech, seats, switch panels, interior lighting… freshen up your interior with vinyl paint Convert Electric Doors to Manual Doors 120 mph speedometer installation Ambient temperature dash display from Mercedes Automatic floor shifter 97 upgrade/mod Bucket seat restoration and repair Center console writeup Cigar lighter and aux switch plate combo Cleaning and refurbishing a stock tape deck radio Column Shift PRNDL Indicator on a Full Instrument Cluster Convert ashtray into extra cigarette lighter sockets Cupholders 1 Cupholders 2 Cupholders 3 Cupholders 4 Cupholders 5 Cupholders 6 Cupholders 7 Cupholders 8 Cupholders 9 Cupholders 10 Dakota bench seat install 1 Dakota bench seat install 2 Door speaker grill mod Door speakers 6.5" upgrade Fix for speaker/window crank interference Freeing up the seat back tilt levers Gauge swap speedometer cable solution Headliner 1 and overhead console Headliner 2 Headliner 3 Headliner 4 Headliner 5 Headliner 6 HO full gauge cluster swap tips How to keep AC vents from rattling Ignition lock removal Loose steering wheel cure Making ZJ/WJ seats tilt forward MJ dash removal Multifunction switch (stalk) repair Paint/dye your carpet Quadratec Ultimate floor liners Rearview mirror and interior lighting upgrade Removing door panels Seat repair Steering column repair Transfer case shifter modification Upgrading to full gauge cluster (plus odometer recalibration) Upgrading to a gauge package w/column shifter XJ buckets in an MJ Lighting Aftermarket fog lights wiring diagram Beijing 2500 XJ tail lights on an MJ Converting courtesy lights to LED Dodge Dakota taillight swap Dome light fix Euramtec B pillar light alternative Export model amber parking light assemblies GE Nighthawk LED headlamp evaluation Headlight wire harness upgrades Installing EURO city lights Installing EURO side repeater lights Installing LED lighting in your camper shell Interior lights upgrade LED dome lights LED overhead courtesy light Melted headlight switch and connector repair MJ light bulb part numbers including LED replacements Porsche 911/912 interior lights Renewing MJ tail lights 1 Renewing MJ tail lights 2 Renewing MJ tail lights 3 Rewiring your marker lights as turn signals Wagoneer front clip lighting upgrade 1 Wagoneer front clip lighting upgrade 2 XJ roof rack / light bar on an MJ Steering WJ steering and brakes Steering Gearbox upgrades discussion Ruff Stuff 7/8" Heim Steering install Steering wheel info and disassembly Adjusting caster Adjusting steering gear play DIY power steering pump adjustments and modifications DIY steering column lock plate compressor tool Saginaw power steering gear technical reference Steering column repair Tie rod end and draglink replacement Tie rod upgrade YJ steering linkage on an MJ Suspension – Setup tech, spring info… Airlift airbag helper kit Budget 5-6" lift parts list Bump stop extensions DIY adjustable front bumpstops Factory shock swaps How to install 2" coil spacers and shackles How to measure ride height Installing front and rear JK shocks Leaf spring overhaul: bushings, bolts, pads, coating, shackles Lift vs control arm length table Longer sway bar end links Lower control arm install MJ rear sway bar on a shortbed MJ rear sway bar on a longbed MJ shock absorber cross reference RE bumpstop install Tips for getting more flex from your truck WJ lower control arms WJ upper control arms install WJ sway bar swap V8-ZJ swaybar swap System Conversions Late model XJ Parts Manuals and Shop Manuals downloads a. Renix to OBD1/2 Swapping an HO fuel pump into a non-HO trucks sender Renix to HO TPS adapter 89 Cherokee Renix to 99+ HO Manifold Swap Nickintime's video b. 97+ ‘97+ H.O. Fuel tank option 97+ power door swap 97+ frontend swap 97+ wiring harness tips 97 swap how-to Adding emissions components to my MJ 1997 XJ fuel pump to 1997-2004 dakota fuel pump 97 swap: header panel, doors, mirrors, ect Overhead console for 97-01 swap 97 XJ trim on shortbed MJ Adapting MJ headlight harness to 97 XJ harness c. 2.8L - 3.4L Swap 2.8L to 3.1L/3.4L/3.8L swap notes older 2.8L to 3.4L swap links d. 2.5 – 4.0 Swap 1986 2.5L to 4.0L swap 2.5L to 4.0L swap links 97 rear flares how-to 2.5L to 4.0L swap tips Transfer Case – Linkage/shifter tech, upgrades… Boostwerks shifter linkage upgrade Installing Novak cable shifter on a np242 Modified transfercase shifter linkage 88 MJ 4.0l ba105 np231 Novak 4wd cable shifter install Novak shift cable on np-242 NP-231 t-case upgrades NP231 Upgrade (dead pics) NP231-NP231 doubler Speedometer gear info Transfercase linkage Transmissions AX-15 swap how-to AW4 troubleshooting AW4 Automatic to AX15 Manual Swap AW4 Automatic to AX15 Manual Swap AW4 neutral safety switch clean and refurb AW4 TCU shift mod AX-5/15 and BA-10/5 transmission identification BA-105 drain/fill plugs off-the-shelf solution BA-10/5 to ax-15 or aw4 swap info Everything you ever wanted to know about the aw4 Manual transmission gearing Ratchet shifter Transmission installation guide pins Transmission cooler install with pics and part numbers T-19 transmission conversion and rebuild Towing/Undercarriage – Hitches, skid plates… Gas tank skid plate ideas How to install a factory transfercase skidplate MJ trailer light wiring harness and mount Spare tire hoist repair 1 Spare tire hoist repair 2 U-Haul 2" reciever hitch Under hood Upgrades – Cleanup tips because some things are just ugly or in the way… Vacuum canister relocation 1 Vacuum canister relocation 2 Vacuum canister relocation 3 Wheels and Tires – Refinishing, wheel specs, dubs… Aluminum wheel restoration Turbine rims restoration Factory wheel weigh in Jeep wheel specifications Jeep wheels guide Windshield Wipers and Washers 97+ windshield washer tank installation 97+ windshield wiper arm installation MJ/XJ wiper bushing install Wiper motor replacement Windshield wiper motor and bushing replacement Comprehensive Wiper Mods/Upgrades/Maintenance Other – Didn’t find it anywhere else? Have a look in here… Tons of XJ mods Jeep Comanche Specs Acronyms and abbreviations Christmas Comanche Comanche vehicle dynamics portfolio Comanche weights and measures spreadsheet Cruiser's mostly Renix tips Driveshaft lengths Hi-lift jack mount How to get into your MJ if you lose your keys How to make an on-board welder Jeep model list (MJ, XJ, etc.) Jeep technical photos Jeep VIN decoder Locking your toolbox MJ periodic maintenance schedule MJ related info links MJ screw / bolt / nut info & sizes Non-Jeep DIY writeups Random informative picture thread Rust removal using electrolysis Safe towing and recovery discussion Stripped bolt head removal Torque specifications 1 Torque specifications 2 Upgrades from the junkyard Ultrasonic cleaner for small parts
  18. Must be something about red MJs...
  19. Here were mine. Truck is 100% rust free otherwise. Lots of pinholes in the passenger side. I'm going to need to replace some metal eventually.
  20. :bowdown: :bowdown: :bowdown: :bowdown:
  21. I must've missed the memo. Only touched a razor very occasionally since the middle of September. Mostly because my hair grows farther down on one side of my face than the other.
  22. Can you get a pic of what you did to the wind strips? If it made a big difference I'm very interested in doing what you did.
  23. This is my new favorite 97+ swap. The half and half '99/old school interior matches better than I thought it would and I like that you kept the old school exterior look. The lift and tires match perfectly, and it's all tasteful and understated. Brilliant truck.
  24. :yeah that:
