COMJNUT
Everything posted by COMJNUT
  1. XJ instrument cluster ZJ D44 Rear axle will soon have installed the "ultrastar/silverstar" 16" wheels from a mix of ZJ's and XJ's. Had to build a set from multiple junkyards.
  2. OMFG! what a priceless piece of aggravation. and all it is...a steering servo off of a 1/10th scale R/C car in a plastic box. :rotf: I got me a couple of steering servo spares laying around...
  3. more info about problem, most can be solved online unless you just need a spare hand to lift something.
  4. you are allowed to purchase a vehicle overseas and get it shipped in :roll: I would guess the owner of the J8 happens to work at chrysler, and it looks like he has done his own aftermarket mods to it already
  5. I put a posi-lok cable in when my vacuum actuator went out, so I could have the choice of 2low or 4low.
  6. this :cheers:
  7. 20 car pileup in colorado springs, the first minute is setting it up for the carnage and NSFW due to language: PART 1 PART 2 FIXERED :shake:
  8. nearest one to me is in dallas...a good 10 hour drive, have good picking down there!
  9. COMJNUT
    1J7FJ26S8ML559034
    what it looked like when I bought it June of 2005:
  10. COMJNUT
    231 neutral
    NP231J 1991... I'm so glad I can Laugh at myself: :cheers: CLICK THE LINKS 2HI 4HI NEUTRAL :chillin:
  11. COMJNUT
    231 neutral
    eggzackery :jump: Ok, I'll be checking mine while I'm doing the oil change...and with video! :clapping:
  12. COMJNUT
    231 neutral
    Eight bolts?? EDIT: See you caught it. uh...yes...8, 4 that connect it to the rear axle, and 4 on the output from the t-case...oh wait I'm not stock in that aspect...dangit :rotf: I have a SYE, well then bag the output of the t-case, or you will have fluid all over the ground, and you will need to fill it after the dolly tow. :shake: or just do the 4 and then tie the driveshaft up to the chassis :banana:
  13. I'm not saying that this should happen, but I've seen much worse :eek:
  14. COMJNUT
    231 neutral
    the right way to tow on a dolly...remove rear drive shaft, it's only 8 bolts easy people! :nuts:
  15. COMJNUT
    231 neutral
    But...when it is in 2wd, the front and rear are separate. I tried it on mine while the front axle was disengaged from the drive shaft. I'll have to do the neutral thing myself soon...just to believe.
  16. just saw this, way to go rick! more photos of the varmint, Image Not Found Image Not Found
  17. Thinking about going up there this friday the 31st, plan to be there by 10:30am, and to have a full day of fun
  18. I didn't even know they made these from the factory... :eek:
  19. and to get back on topic this is one of my friend's 5.9's that I drool over, he has done a great job on it. http://www.mallcrawlin.com/forum/showthread.php?t=19304
  20. ya, but a red flag would go up if someone from way out of state were to call and try to get him down to that. :(
  21. thanks, only $165 for shipping 4 35lb packages from eht to denver with UPS ground
  22. linky? :cheers:
  23. way to go on the score you lucky bastid :cheers: in the two years...i've only found one...just one...the "spare" :nuts:
  24. COMJNUT
    ordering soon: http://www.horizonhobby.com/Products/De ... =PRO333500
  25. way to rub salt in the wound...I've been wanting those wheels for the last 2 years... :shake: and that video, give me those wheels and I'll give you mine before you do that
