2
Everything posted by neohic
http://www.mcneilracinginc.com/off-road-fiberglass/jeep/cherokee/ :rock on:
Twice now I've replaced an alternator with an parts store unit and had it fail right out of the box.
What? Using a Comanche as a donor for a Cherokee? :shake:
Oh My Clean. Il/wi Border
neohic replied to Automan2164's topic in Craigslist/Marketplace/eBay... i.e. Not Your Stuff
You need that one too. -
Rob, aren't you always after the strange and obscure when it comes to MJ stuff? :idea: You need that.
Any specs on that beauty? :drool:
Cutting Down Drive Shaft Slip Yoke. Bad Idea?
neohic replied to Biotex's topic in MJ Tech: Modification and Repairs
Or just keep it... you know... just in case you get another MJ. :D -
Sorry guys... That's a photochop that's been floating around for a few years now.
They're all 10" fans. I've had two of them for years now and I have no idea what manufacturer they are. I bought them at an Advance Auto close to six year ago. The third fan I just had sitting around but it had the same numbers on it so I ran with it.
I'm in the same boat so I just made up my own setup. I used a 210 on/195 off switch in a HO thermostat housing for two of the fans and one remains on constant. The shroud is 16 gauge stainless. Only other change was to get rid of the studs for where the clutch fan bolts on and replace them with bolts for clearance. Works great! The other two fans only come on when I'm in traffic or just idling around. Gauge stays right under 200* all the time.
Well, today was the day that the poor old '91 was taken out of commission. Had a couple things to take care of in the new chassis then things really started happening. The door jams got a coat of new paint just because I thought it'd be easier now and less over spray later on in the interior. Then there was the '91. It was almost sad taking things apart as I really haven't had any issues with the truck over the almost two years that I've had it. It's really for the best, though. The rust in it is just too deep to structurally trust it for too much longer. So, I started with the dash. Plans are to go from the firewall forward just to get it running again to I can move it around the yard under its own power. Metal work next, then paint and reassembly. In preparation for the under hood change over, I got the manifolds back on. On a side note, the weather forecast calls for potential hail. Seems strange to try and protect something that looks like the white truck over the red one. :hmm:
Wife Wanted A Headboard... Six Years Ago
neohic replied to neohic's topic in Member Projects: Other Cool Stuff
Thanks guys! -
http://www.nbcnews.com/business/chrysler-backs-down-agrees-recall-2-7-million-older-model-6C10363045#business/chrysler-agrees-recall-2-7-million-older-model-jeeps-6C10363045?ocid=msnhp&pos=1
Yeah... I know... Anyhow, the wifey was all, "Hey, do you think it's possible to finish that headboard tonight?" Well, I needed a little help if that was going to happen so she took matters into her own hands. And anyone who knows me knows that I really don't like working with wood. In fact, I'm pretty sure I have a grimace on my face just about everytime I have to touch the stuff. Anyway... done and happy! -
This just might turn into another mustache/facial hair appreciation thread! :laughin:
It's almost time to take the '91 off the road and pass the point of no return. I'm expecting to break every single bolt taking that truck apart so once it starts getting swapped over, there's no going back! As for the new chassis, it got a little more stripped down. The interior it totally out, along with a few more underhood items. The manifolds came off due to the crack in the exhaust manifold big enough to... how was it Austin?... "big enough for midgets to walk through". While I was in there, I started looking at what I'm going to do for fuel lines as I know the ones on the '91 are not going to swap over nicely. Fortunately, Austin left the lines for the 2.5 that was in there and the quick connects at the firewall. Cool! I'll just leave that alone and splice into the rubber lines that connect to them. On to the interior, I knew that the floors needed some attention. I was happily surprised that they're still mostly solid! I only need to change out the common spot under the pedals. Here' an interesting spot on the trans tunnel too. You been hauling around chubbies in the past, Austin? :laughin: Well, the box came off too to take a closer look at everything and I was again happily surprised at how solid the frame is. I've got a couple mouse nests to clean out, but the only real rust is on the axle and springs. Let's compare: Hmm... I still have some work to do. I kinda wish I could just do some magic Freaky Friday type of change-o switch-o. :thwak:
850 4Wd Chief
neohic replied to uselesstactics's topic in Craigslist/Marketplace/eBay... i.e. Not Your Stuff
Strange color for a Chief. I totally dig it. -
Yeah... it works okay. Every once in a while I have to tell myself to keep the hammer strikes to one side when I notice it starting to lean. Threw some paint at it last night... update! -
Why did I actually laugh out loud at that? :oops:
Another day on this. I added more to the scrolly, leafy things and added some formed channels to put the wood into. Other such headboard stuff as well... Going to be some oak 1x2s stained the same color as the rest of the trim in the room. -
Cool project! I love the lines of these Falcons and Rancheros. Any long term plans for it?
With a smaller tube diameter, I think it'd look neat with a double tube setup. :dunno:
... so I figured it'd be a good time to start. I started with 2" and 1.5" round tubing and 5/16" and 1/4" round bar. It's for a kind size bed so that means I've got a ton of real estate to work with. Did some notching... some cutting... fitting... welding... you know, headboard stuff. Obligatory close up of a weld: Planning on some wood work between the two lower tubes. Not sure how I plan on finishing it yet... probably something awesome though.
Comanche Of The Month - June 2013
neohic replied to Automan2164's topic in Comanche of the Month (MJOTM)
I love the almost cartoonish stance about this truck. Almost like one big RC! The antenna just adds to the look. Great truck! Totally deserving of MJOTM! -
How About A Half?
neohic replied to neohic's topic in Craigslist/Marketplace/eBay... i.e. Not Your Stuff
All yours if you want it, Jim. The wife put a veto on the thought of turning it into a permanent outdoor grill. :doh:
