20
Extremely Sensitive Steering
Jeep Driver replied to thejim42's topic in MJ Tech: Modification and Repairs
I'll also mention that grease will solidify over time. Did you flush out all your rod ends? I'd take a look at your ball joints, the upper can be flushed but the lower cannot. Also, flush your front drive shaft. I would imagine all your seals.....main seals.....axle seals.....TC seals.....etc.......are dried and cracked and do or will leak. What about Ujoints? Brake lines??????? You will spend some time and money.....just a fact. -
Low Voltage Issues
Jeep Driver replied to Strokermjcomanche's topic in MJ Tech: Modification and Repairs
Did you replace the battery cables? Cable from alt to breaker? -
No, It's EVERYTHING. Your bushings are bad, I guarantee you that. Track bar too........and I'd look at your rod ends......... The worst thing that anyone can do it let a vehicle sit........and after 12 years worth.........rubber goes to rot. And I'd bet the bushings in the springs are bad too. I'm telling you the truck is wondering and what you consider touchy is you constantly working the keep the truck straight down the road. And for the dampener? yeah, the seals have dried up and it will/does stick. -
I wonder if he's confusing sensitive with sloppy. If your control arm bushings.....or any other part of the suspension......is worn, your truck will wonder and keeping it straight is a full time job. -
Increasing Payload
Jeep Driver replied to drewyoungblood's topic in MJ Tech: Modification and Repairs
Foot Pedal Emergency Brake Relocation
Jeep Driver replied to knever3's topic in MJ Tech: Modification and Repairs
Pop-Out Rear Glass Like A 'breezer' Window?
Jeep Driver replied to 8valvehero's topic in MJ Tech: Modification and Repairs
Someone has a very sweet truck. -
Led Taillights?
Jeep Driver replied to Sir Jacob the 2nd's topic in MJ Tech: Modification and Repairs
These would be cool too. https://digi-tails.com/1966-67-chevy-nova-led-tail-light-panels -
Led Taillights?
With filler panel and body work........properly done........ http://www.carpartsdiscount.com/auto/parts/catalog/chevrolet~c10-pickup~64.html?3593=246264 -
The pic above this post....#6.....is a Yj shifter Does it place it in the same position as the MJ at the tunnel?
Someone in the 'build' forum did just that. He used a Honda shaft as the thread one on the shaft was the same as the ball he used, looked good.
??? What's a triple braced link? The parts in your photos look like the OEM parts, and they look like every 4.0L timing chain set I've ever seen.
Please Help Me. Very Frustrated.
Jeep Driver replied to thatoneguy_ra's topic in MJ Tech: Modification and Repairs
Vacuum leak or intake manifold gasket. -
Turning On A/c Kills Engine
Jeep Driver replied to bongobill's topic in MJ Tech: Modification and Repairs
With the engine OFF! all anyone has to do is turn the clutch by hand, the face of the clutch will turn or it will not. If it turns, it's not the compressor, if it does not, the compressor is locked up. It's that simple. -
The other two guys are correct. I cannot believe a 'shop' could not figure that out in 5 seconds....???????? -
Something Broken In Transfer Case..
Jeep Driver replied to TheDude's topic in MJ Tech: Modification and Repairs
That ring is the back of the bearing stop. At some point the drive shaft as been forced forward into the TC. You'll need a new tail shaft cone. Fix it NOW. -
Fuel pump relay.
Changing The Turn Signal Lights Out
Jeep Driver replied to redwolf624's topic in MJ Tech: Modification and Repairs
The ones from Europe are amber......>>IIRC -
Desperate To Cure Death Wobble
Jeep Driver replied to Project Comanche's topic in MJ Tech: Modification and Repairs
Bad advise? Think not. He's running a 12" tire, he did not say what wheel or wheel width they are mounted to. A 12" tire should be mounted to a 10" wheel, otherwise at full pressure you pull up the tread as the sidewall expands out. To correct this, you guys reduce tire pressure. This causes lateral movement of the wheel inside the tire, IOWs the wheel is allowed to travel left to right inside the tire. Also causes some real slop and sway in turns. What width wheel are you using? -
It's fairly low pressure. Cut the line and splice with fuel hose and two clamps.
http://www.nonlintec.com/sprite/oils_and_zddp.pdf I just replaced my VC last week. There are over 60K miles on this engine, I put 55K on it, using Havoline 40W and Lucas. It is spotless inside. I also replaced the oil pan gasket two weeks ago, just as clean there also. I run a little more than 60psi at 2000rpm and 40psi at idle, no problem with wear. You guys really need to get over yourselves with all the oil science bull$#!& and just run a quality oil and filter. I use Pure1 filters. Image Not Found
Also, How many of you guys have reused axle Ubolts? I want the Ford Explorer style with the flat strap at the arch of the bolt. Ford want $30 each......they can bite me. Plentiful at the PnP. Or have you guys seen these aftermarket? And I definitely want the 9/16 bolt.
I have a 93 8.25 from an XJ. I'm converting it to discs from a Liberty. I snagged the studs from the Liberty, only to learn tonight that the Liberty studs are too big at the neck. At this point.......?? Drill out the hubs to accommodate the Liberty studs? Or From what axle can I get the longer studs to fit the XJ axle? Will a similar year D30 have the longer stud with the correct diameter? Thanks
