9
Everything posted by 87MJTIM
I swapped the bumper on my last fall. I kept the brackets and bolts (except one) from the original. I may be per$uaded to part with them.
Starter Bolts Dimensions Help!
87MJTIM replied to njcomanche1227's topic in MJ Tech: Modification and Repairs
I found the part number, but it does not give a size. J400 6964. Check with a dealer for the size. -
New Door Panels... Again. Suggestions On Color?
87MJTIM replied to Zenobian_84's topic in MJ Tech: Modification and Repairs
Thx. -
Where did you get the panel boards? The ones on mine are suffering from water damage. Probably from a leaking side vent window. -
The bed rails look too short. Are they after market? Mine run the length of the bed.
I think the consensus is.... there is no consensus. Two other threads asking the same question has too many different fluids to agree. I will use what the manufacture recommends: 75/90 gl3
here's a view of diff covers to determine what you have. You need to go to page three for the diff covers. (I can't capture the image and post it to this page.)
What Have You Towed With Your Comanche?
87MJTIM replied to Goose's topic in MJ Tech: Modification and Repairs
I once towed a small popup camper 200 round trip to hills in WV. The last 4 were a jeep trail with approx. 2000 ft of gain. -
Digital Jeep Manuals (Free) Here!
87MJTIM replied to Biotex's topic in MJ Tech: Modification and Repairs
While searching through older postings, I came upon this for the '88 FSM: http://comancheclub....service-manual/ I tried to download the link, but my browser kept blocking it. Is it still good to download? If anyone that did download it can link it to your listing I would appreciate it. Edit: I was able to save it. Right click the icon. Save it to your computer -
96" = 8' So, it is to long for the 6' or 7' beds.
What Fluid Are You Using In Your Ax15 ?
I just picked up my trans and Tcase from the shop that rebuilt the trans. (BA 10/5 and 231) The guy told me to use Penzoil Synthetic in the trans and 5/30 in the tcase. But the prior link said not to use Penzoil?!?! Should I just use the 75/90? For the tcase, he said that ATF will foam up while driving and could blow out the vent tube. He said 5/30 will not foam the same way. I ask for your $0.02 (US and CA $) -
This company sells side panels for the MJ. Several members have bought from him - myself included. http://stores.zmjeeps.com/StoreFront.bok The panel was about $160. Shipping was about the same. The company is outside Toledo, OH, so you may be able to drive there.
Cleaning Washer Tank Jug
OxyClean. -
Military Wrapped Springs With Lift, Group Buy
He did not ask me for a deposit. He did get my name and number. You should call him. -
I spoke with Joe today. He said he will produce about 20 3/2 military wrap springs. It could be done in about 4 weeks. He will post on CC when they're available. I reserved two for me. -
Since Joe's last post said that to get a group discount, he needed a run of 10 springs. That's 5 people ordering 2 springs. I think there is enough for a 3/2 w/ double wrap. If there is enough interest in another config, then he may give a discount for that run. You would need to get 5 members to agree to the 3/1 or 4/1. -
I like that. I was think of "hearding cats" or "sweeping fleas." -
Is there still a discount available? Joe??? It sounds like everyone has different needs and wants. For a group discount do we all have to order the same springs? Do we have to order at the same time? Is it possible to get a discount code to use when ordering? -
That what I have recorded for you. My '87 is currently getting restored. So I am looking ot move soon on a purchase. -
Someone correct me if I am wrong, but the 3/2 is three regular springs with two booster springs. There is only one wrap spring. The two boosters give you a greater weight capasity - 1700 lbs per spring. The 4/1 has four regular springs with one booster. Two of the regular springs wrap around the bolts (front only?) to give additional support (why?). I don't know the weight rating or lift. The 3/1 config give a weight capacity of 1280 lbs per spring. I don't know if there is any lift from 3/1. I am leaning for the 3/2. I don't know why I would need the add'l wrap, but I would like the lift and weight capasity. My $0.02 My reply from GS said that the 3/2 would give approx 1.5" lift -
Ok, everyone, I have tried to summerize who has expressed interest in buying sets and the configuration. If I missed someone or got the wrong config, please correct me. Garvin - 3/1 ride172 -3/2 butchershop - 3/2 cpa tim - 3/2 or 4/1 jvd - 3/2 or 4/1 sinkrun - 3/2 or 4/1 86comanche - 3/2 or 4/1 biotex - 4/1 3/2 danbyrambler - 3/2 or 4/1 87warrior - 4/1 tazer15 - 4/1 That make 12 possible customers, but not a committment to the configuration. -
I agree. My BA10 is 25 yrs old. Got me 268000 miles. It has never left me stranded or had any work done to it. I change the gear oil for the first time last Sept. Of course, your results may vary. (tounge in cheek. Please don't bash me. Not all of them were bad.)
Put me down for two 3/2. How do we coordinate the ordering, since we are spread out arond the country? How much of discount can we expect? -
I do want to be included in the group purchase, I just want to know the details before I commit fully. I am not really needing the "military wrap" spring. What will the cost per spring be? Approx how much lift? When do we/I need to finalize? I emailed GS through their website with my same questions. This was the reply: "The difference between the 3/1 and 3/2 is design and grading of steel. The 3/2 has a higher capacity at 1700 lbs per side while the 3/1 is rated at 1280 lbs per side. The 3/2 will typically sit the truck 1-1/2" taller than stock as long as your current spring is not the 3/2. Shipping will be between $40 - $60 for a pair depending on which spring you decide on." -
Thanks. I saw on the General Springs website diagrams of the springs. Do either spring give a lift of 2" to 3"? Like all of us, as we age things start to sag. I am sure my 25+ yr old springs are showing signs of aging.
