11
It's mighty hard to tell a stroker externally... Actually, I'd almost say it's impossible. Without ripping the head off or dropping the oil pan and checking the numbers on the crank (if you even can with it in the engine). Scary.
warn hidden winch system for jeep comanche...
DirtyComanche replied to JeepcoMJ's topic in MJ Tech: Modification and Repairs
I've got one of those, just it was made by lincoln. -
You can make the JCR setup OTK. Tell them and they'll ream the one TRE the other way. Then you jsut have to buy those flipsert things and drill out your existing holes. It's advised you weld the flipserts in...
That's over-kill. Road signs are maybe 18g and they last a while. Throw lots of sparks if you do it during the night.
Road signs work pretty darn good.
WTB - One VERY LARGE buffing wheel.
DirtyComanche replied to DirtyComanche's topic in Member Projects: Your Comanches
Hmm. Maybe. I think I'll try and make a MJ/XJ header work first. I don't want any more toy confusion. But then again, a slot grille would be pretty obvious too. I already have an idea hopw I'll patch the gaps. Ever heard of 100mph tape? Er, ah, actually I'm going to steal some .040 aluminum and just pop rivet it on, I think... Tomorrow I go and look at tcases. Grr. -
You removed the umm, shift detent pin? From the tcase... There's two plugs on the back, top is drain, bottom is fill.
Buy some stainless sheet and get it rolled to a nice countour. Header wrap isn't ideal on a street/trail rig if you ask me. It will destroy anything you wrap with it in short order.
Tranny cooler lines.
DirtyComanche replied to DirtyComanche's topic in MJ Tech: Modification and Repairs
Thanks. I'll have to pop into NAPA tomorrow. -
Oh, I had a header panel. And headlights. It had an accident last trip when I got it caught on a tree. I'm a really hot driver if anybody hadn't noticed yet... Anyways, it's still ratchet strapped to the back of the truck. But I have two header panels and two hoods. So that's a decent shot at making at least one fit. I'll have to find some lights that will fit in the stock location but aren't as deep as there's not enough clearance with the rad. I might have some funky gaps going on as I'm not exactly a body man. But I gotta bend some tube before I get too horney on any praticular location of the peices. And I gotta clean up the wiring/vacuum harness. -
Hehehe.... 'Cause I'm gonna need one to fix this mess. This is what I started with. Pretty much the same as the last time anybody saw it other than some bent metal and broken parts... Image Not Found I kinda lost my header panel then ran into a tree Image Not Found Out came the sawzall. Image Not Found Image Not Found Getting there.... Image Not Found Image Not Found Bunch of BS that I cut off. Image Not Found Mocking up the new fender location. Image Not Found As you see, it's gonna be dove nosed with just the stock 4oh rad. I had qualms about doing this, but WTH. It's only time, money, and effort. I'm sure I can make it work decently. There's also some other parts that are going to go in sometime soon hopefully... And maybe another sudden change.
Can you bench test an IAC?
The thing is a pile. I need to spend a weekend and track down all the problems with it. The issue is that I take it out every couple weeks and flog it to death, and it sits all the other time. And I never do ANY maintenance... -
Looks like I'll have to try and find the part number and order them in. I had gone to napa and asked about them, and they were like "Umm (looks at computer), umm (looks at me), uh, go to the dealer". The dealer wanted $400~ per line. -
TWICE I've had an unintended tranny flush with my DD XJ (4.0/AW4) because the quick connect lines pop out of the tranny. What gives? Are they just worn out? Or bad? Can I use something else? Perhaps because the lines aren't supported too well? It's the same one each time... This time I had to leave it because the fitting wouldn't seal when I put it back in. Either the o-ring is gone, or the fitting cracked. I've lost my patience for this.
A trail called 'turtle'
DirtyComanche replied to DirtyComanche's topic in Adventure Planning / Regional Groups
Rich flopping Image Not Found Image Not Found Me shortly before my output shaft snapped. Image Not Found -
I broke on the gatekeeper, so umm, yeah.... Anyways. Dave's first flop (note the expression) Image Not Found Image Not Found Back up Image Not Found Back over Image Not Found Curtis Image Not Found Rich Image Not Found Image Not Found
Tcase drops suck. But no, you'd need to get the shaft lenghtened even with one. Most likely. Well, it's really a 'try it and see' sort of thing. You just have to make sure you have enough yoke engagement or your day will get crappy. While you can get away without a SYE, I'd highly recommend a one if you're 'ugly' with things. The stock mainshaft leaves a bit to be desired. As in it likes to go 'pop' at inoppertune times.
As Twisty said, no side traction. They're great in the thick gooey mud as long as you have the power to get them spinning (self cleaning), and as long as you don't plan to go anywhere but straight ahead. In ALL other instances that are just horrible tires. In high traction rock like moab a guy can run them; but a BFG A/T would perform as good in that situation (and actually be round to boot). For slippery rock they'll go nowhere but sideways. Offcamber (even in dirt) they go sideways. In the snow you sink until you hit bottom (and you're done at that point). They don't like high speed either. And they're totally unstreetable. Okay, you can. But it sucks. Interco tires are rarely round. That said, a lot of guys run them and love them. And I can't rain on that.
Anything but boggers.
The early XJs are the same. I think they changed the hinges eventually.
glass for back window??
DirtyComanche replied to twojeeps's topic in MJ Tech: Modification and Repairs
If you can't find anything and want a 1-peice, any real glass shop can cut you one. -
96 has a good ring to it. Perosnally I'd go the calipers route.
It's weird. The reason it didn't work was I knocked off one of the ballast resistor leads. It fired up and did the usual climb to about 3k, then it came down and died. I thought 'hmm, it ain't idling at all'. Then I realized what my problem was. After it got warm, it still wouldn't idle. So I disabled the EGR and then it did... So I should probably take a couple minutes and go through the manual. -
Anybody broke a NP231 front output?
You mean 241?
