Just noticed a comanche on the american version of top gear! In the short promo scene where there is a jet plane ,and a helicopter etc flying out of an explosion if you look to the left just above the sweet looking mustang there is a comanche, rollbar in the bed and all. :clapping: look here.
Just above the starter a little to the passenger side. Should have a little rubber end with a slit opening well unless it fell off as mine did just the other day. I have the same prob. Try blowing out w/compressed air-worked for me ,but still have light leakage when blower is higher than middle setting. :cheers:
My cooling system will do the same when on the highway. I'm running an electric fan in place of the clutch fan ,original radiator, new thermostat,newer water pump installed by po. What gives? :dunno:
I just got my a/c going again also ,and i too have lower voltage while running. I have replaced my clutch fan with an electric one though so more power used there.The aux. fan runs with the a/c compressor this takes some power to run. May be just that.
Check your fuse block for contamination from a leaking clutch master cyl. Check your taillight wiring too.E-brake cable should still be avail. :cheers:
Look for a leaking clutch master cyl. The fluid drips onto the fuse block and causes much mahem! I have probs. with my blower motor stopping from time to time only to start working on it's own ,or when i wiggle the fuse. :cheers:
