jeepsouth
Everything posted by jeepsouth
  1. Been getting "wanna sell it?" a lot lately ,but there's just no way.
  2. Until two weeks ago I had my exhaust cut short ,and dumped (turn down) just before the axle. Now I have replaced the section that goes over the axle with the correct walker piece ,and I am much happier now. Painted it black ,and slash cut the outlet end for a better look that really compliments my truck.
  3. Flow 40 here as well no cat, very happy with it. Should be better when the pacesetter goes in.
  4. Wow i want one!
  5. My leak was the distributor gasket.
  6. I have to do everything on the driveway!
  7. Jeepsticker.com here also,very satisfied.
  8. Yeah i was surprised to see how little weld was there also. The first time i just ran a short bead with everything in place so didn't realize how wimpy it really was.
  9. Weld broke again on my clutch pedal this time i removed it ,and rewelded it as it should have been from the factory. Here it is And with a coat of paint.
  10. Yeah 31 will fit.
  11. Search on here for this-cheap forward window channel fix I did this back in 2011 still working well.The seal i used actually came from my job ,but simular material is available out there for sale.
  12. No indication on can that says ok for plastic ,but no indication against using it either. Can says high gloss acrylic laquer that goes on easy ,and provides uv protection.That was all i needed to read right there.
  13. Thanks, only took about 3-4 hrs. all together.
  14. Thanks, got the ideas from others on here.
  15. Diy write-up completed.
  16. Remove ,and thoroughly clean/degrease tail lights. Use brown scotchbrite pad ,and water to remove oxidisation from lenses use only enough muscle to do the job. Dry ,and check your work, go at it again if need be.Wipe down completely dry lenses with alcohol ,and a clean cloth.Apply three wet even coats of clear with at least a 10 min. wait between coats (check weather condition reccomendations on can) Let dry ,and reinstall.This is what i used-this is the result--
  17. Thanks. Which what? Scotchbrite pad? The brown ones that autozone sells in the paint/body section.
  18. Used wet scotchbrite pad ,and cleared with duplicolor. Here are the results.
  19. Nice mj welcome as well.
  20. Nice truck,cool car ,and welcome to the madness.
