banshee
Everything posted by banshee
  1. Thanks for the input it was just a thought wasn't aware about the on-road downfalls so you think the ‘on-road is illegal’ might have some truth to it?? B...
  2. Anyone using them on the rear? Pros/cons? In Indiana I was told they aren’t legal to run on road? Worth the investment?? :huh???: Feedback requested… B…
  3. new aluminum three core radiator to arive the 15th, two wheels drilled for beadlock studs, CC sticker installed on window 'pics to follow' issues with camera cord... B...
  4. Couple questions first How high are you going? How much $$ are you willing to invest? And lastly how much articulation are you going for? your answers will affect my answer… B…
  5. Check; Tie rod ends and/or ball joints, most likely one or more have massive play, if not have the alignment chacked cam/caster could be that simple… B… Mine was two tierod ends and the cam/caster was off badly from hitting ??? good luck
  6. banshee
    Roll Bar
    :wall: If you remove that bedliner let me know, where and price, I'll be to get it... B...
  7. banshee
    Crazy mad flex
    I believe it dose as long as you didn’t have to be pulled out? lol :rotf: B…
  8. banshee
    Crazy mad flex
    mine before body mods... B...
  9. walked past it, disapointed my radiator isn't here yet :mad: B...
  10. just west of Indianapolis In... B...
  11. banshee
    please watch
    one more http://img.thesun.co.uk/multimedia/arch ... 22180a.swf I laughed until i almost cried... B…
  12. banshee
    please watch
    https://www.supermotors.net/getfile/879 ... rdrill.wmv watch, save have a laugh on me... B...
  13. E-bay 1987 88 89 Jeep Cherokee Aluminum Radiator 3 Row CC78 (Fits: Comanche) Buy It Now $159.50... just a thought. B...
  14. what are you looking for new? I have two dunlop mud rover's almost the same about 50% left, but I'm in Indiana if your intrested... B...
  15. give me a second or two and I'll post a link to mine... B...
  16. Just type in year and ‘Comanche fuel sending unit’ in your search engine that’s how i found mine… B..
  17. Obviously I need to repost my question It’s simple under everyday driving in Indiana heat (90) it runs around 200deg F, if I park it running it blows the coolant out of the radiator into, then out of the reservoir bottle, then the motor gets hotter because of loss of heat transfer Radiator pressure tested and held 16# for almost 3hours, according to shop the tested it and preformed the flush, no major difference in cylinder compression, no missing, no water out of the exhaust, new 185 thermostat, spring present in bottom hose, new pump, three month old 2 core radiator, Bluntly it ran cooler before I changed it (radiator) because of leaking… B… HELP?
  18. Anyone ever tried to put a larger radiator in the front of an MJ? or should I just relocate it into the bed? 220deg F plus is unacceptable, 35mph or above on the open road seems to be fine feedback requested/ advice required... B...
  19. :agree: get an idea of what you need, I dropped my upper mounts several inches at the same time as my soa lift, it required I remake them but it was worth it, I'll look and see if i have the measurements from when I did mine... B...
  20. Swap them, if you’re just doing a little playing in the mud ‘maybe?’ Serious wheeling don't waste your time and money… Totally :agree: B…
  21. Honestly never thought it would be on its lid that much requiring the UV overcoat… B… Top coat it ;) I applied the Chassis Coat on top of the POR15. It is UV stable. I don't see why you couldn't apply any sort of under coating or other black paint over the POR15. It takes a long time to scuff the POR15 so it can be top coated. Those foamy sanding blocks and thin foam sand pads will save your hands and arms.
  22. Cool, mine's all hand made in my barn... B...
  23. Question are the shocks still good? if so ever consider remaking the mounts to a lower point allowing longer travel? if there already torn out now’s the time, plus much cheaper than new shocks? :wrench: just a thought... B...
  24. Did they install the proper weight oil? not a fan of walmart? B...
