banshee
Everything posted by banshee
  1. banshee
    Awesome! Lol
    may i ask one simple question? WHY???
  2. one word SWEET
  3. Mine along the same lines as your van, my first battery is the primary and the second just feeds my cooling fans, and other equipment. The wiring the two batteries are connected thru a 15Amp bounce resister thru NC contacts, and if the engine temp climbs the contacts open disconnecting the two batteries and another NO contacts close, connecting the one battery to the fans allowing the alternator to just be charge the primary battery as the fans run. Then as the engine cools down the contacts again change reattaching the two batteries together, disconnecting the fans and the alternator is now recharging the cooling battery thru the bounce resister at a slower rate of only 15Amps allowing the alternator not to be overworked… Note; I’m running an aftermarket 163 Amp Alternator, with two 800CCA batteries… B…
  4. a question of my own do or have you ran gasline antifreeze in your truck? why thinking ice in fuel filter either choking off or restricking flow just an idea... B...
  5. por15's good stuff but as stated the prep is the sticker sorry but physical remove it first, then caot with whatever you chose... B...
  6. First question Open or closed cooling loop? Then is the system completely full of water/antifreeze? And if so, I’d have to point at your thermostat... B...
  7. new 37" pitbuls would be nice, chance slim, thinking more of vacation boohoo
  8. N I C E lol
  9. mine is an 87 4.0L requires 105amp, O-reilly $100 give or take
  10. guys got myself an 87 manche rinex 4.0L after it was mudding ran fine, now nothing no fire any ideas where to start??? B...
  11. i'm going to try it, i'll let you know how or if it helps... B...
  12. Sorry forgot the pic http://i.ebayimg.com/t/Used-Flex-a-Lite-15-Fan-/00/$(KGrHqMOKiEE3ykefpeNBO!gSqNepQ~~_12.JPG
  13. so here I am again, another question online i saw a 15inch plastic flex fan it promises to add 20% more air flow thru the radiator at lower rpms, so that being said first is anyone useing one, if so any luck with the normal 220degF low 4-wheeling engine temp??? thanks... B...
  14. LOL
  15. I totally agree except the power washer isn’t such a great idea sensitive electrical equipment and water DO NOT mix…
  16. mine 'ant no cherry' because she isn't
  17. :agree: totally, as far as hard on parts A reason to upgrade, do we need a better reason???? B...
  18. ideas, suggestions, input all required, at this point there are NO bad ideas B.
  19. I saw an upgrade allowing me to relocate my alternator up into the old AC compressor's location anybody seen one? anybody using one??? a link or help... B...
  20. I like it, looks cool atleast to me? B...
  21. II'll bite "why NOT?
