banshee
Everything posted by banshee
  1. update ignition module replaced and what do you know started and most important stayed running thanks for all your help and cruiser you keep posting WE need it.... B...
  2. thanks cruiser good info, what i haven't already done, I'll try thanks B...
  3. yep has been for awhile i just automaticly turn them off before typing
  4. nice, love the front bumper mod, may i ask what in the world did you do the the top of the cap?? i'm afraid its NOT going to buff out
  5. update 5-4-13 if already known please forgive the repost so replaced CPS, distributor, and coil, that all being said still having inconsistent firing starts fine runs smooth for about two minutes then just died no sputter, not hesitation just like key shut off??? Now still troubleshooting issue here’s what I’ve found so far, if your CPS is out your injectors will not fire, nor will your coil, the same with your ECU the same input allows the signal output to the injectors and the coil, so either coil depending on resistance may or may-not be bad, ignition module can also cause the same issue… Where to go from here???????????? B…
  6. sorry so long to post pics alternator relocation pass side floor drivers side floor
  7. is the one off a 4.0 the same? if so i just removed one? i mean if your intrested and it will work???
  8. 2012 replaced CPS from NAPA and yes 87 renix
  9. Only random firing checks 3.41VDC from ECU to CPS and back to ECU is this normal? O and with a meter i can't see it change states, meaning hi/low second with the CPS unplugged i read voltage on BOTH sides from ECU is this normal? HELP thinking ECU toast, but it will try to start once in a while after coolinig off but never dose my manche left me walking
  10. banshee
    Blondes
    NICE please see http://www.youtube.com/watch?feature=player_detailpage&v=l38blGqVeHc
  11. campion stock number CC78 say $200 for 3 core all aluminum
  12. sorry i can't help with your question, but i have to say "HASPINATOR" S W E E T B...
  13. first total electric cooling system for my 4.0Lmanche second new G3 ford alternator moved to A/C compressors location third old alternator replaced with replacement bracket keepng the orignal roller lastly the the floorboards replaced/fiberglassed and bedlined =first pics to follow= i have spec the for this alternator replacement bracket if intrested
  14. order bushwacker fender flares
  15. A question Really? Your two core cools better? Hum you really think that much better flow 4.6L with one 10” high CFM behind the tranny cooler and radiator and one 14” two stage where the mechanical used to be, if so Cool thanks B…
  16. I've had my champion 3core installed and cooling my 4.6 for couple years No issues, and yes got from Ebay B...
  17. Not recommending this seller, or even Ebay but here's what i got http://www.ebay.com/...ca904a4&vxp=mtr
  18. I'm just going to say one word about it S W E E T B...
  19. upgrade from 2007 jeep Compass with 2.0L Engine - 140 Amp part number 31-01280 AR OR upgrade from 2004 Mercedes Benz C240 150 AMPS but slightly harder wiring Part number 31-00096 AR autoparts wherehouse.com
  20. my turn enjoy... B...
  21. enjoy
  22. banshee
    Awesome! Lol
    ok got me there? why not then LOL... B...
  23. welcome and sweet truck...
