banshee
Everything posted by banshee
  1. Crap, maga-crap, they do kind of work if you keep them greased
  2. A thought, in your brand new bearing the manufacturer applies grease, "next to none" took apart several brands same findings, So buy the cheap bearing, tap it apart in your vise apply grease I prefer boat axle grease to displace water for you wheelers then tap back together its simple to do, didn't cause damage to seal just slides apart..
  3. Only seen 4 COMANCHES today, but had a blast anyway
  4. Just saying be careful what you weld, you maynot be able to remove cross pin to remove clips is all
  5. Going to be mid to high 80's and sun The billygoat and I'll be there
  6. Con of it's welded it may not be repairable, meaning if you need to replace outer seal you have to replace entire axle, keep that in mind
  7. Agree, what's the worst that can happen you have to resell it
  8. I use mine for off-road mostly when my O2 died I thought I had a hole in the tank drank fuel, my best guess it was getting like 6 mpg
  9. Repost suggested dates lets do this?
  10. Have to disagree the Ubolts do the work, the weld keeps it from rotating
  11. Use it, get good with it, then later resell it and get your money back? Just a thought
  12. Cool thanks, I'll check it out
  13. 87 removed disconnect, the thing is the light don't work at all in 4 wheel drive
  14. It just comes on at random may stay on for minutes or halfway home? Not in 4 wheel drive, Leaver seems to be in normal spot Ideas??
  15. I ran disconnect for years with 35s not braking much, but did finally brake it did the 96 xj shafts and seals still rocking 35
  16. Sorry to be so negotive but my last trip to badlands, well bite the big one, too worn out, they cater to the side by sides.. Just a thought Redbird bigger, better trails, and only $10
  17. banshee
    Wheeling fail
    Broken ujoint, both inner and outer axle shafts But most surprising was bent then broken tierod end
  18. This seal is for a non disconnect right??
  19. That's priceless
  20. Have a lockrite in the front other than the click you'll never know it's there, yea can be a handfull on ice "just know its there and stay ready"
  21. Coolest thing ever
  22. Looks nice great idea
  23. banshee
    Missing wife.
    Priceless, wife read didn't find any humor in it at all but I did
  24. I'm running an 8.8 with limited slip and love it, I put my locker in the front
