banshee
Everything posted by banshee
  1. Ok yes with the tcu unplugged it shifted when I changed gear with gearshiftNow what??
  2. Update unplugged tcu and if I manually shift it shifts
  3. Thanks for the help so far but dose anyone have the wire diagram of the tcu? Thinking I have another problem it's not being ALOUD to shift
  4. Gents Changed tps, changed tcu out of a running driving shifting truck, same problem it simply will not shift out of low hear, what am I missing???
  5. Beautiful truck
  6. Are they year spacific?
  7. Anybody have an extra TCM the relay for servo 2 is burnt
  8. Checked and cleaned both connectors to granny, what tells module to change heard? Speed, throttle position what??
  9. Fuse is good and has power?
  10. Sorry 87 manshe 4.0L AW4
  11. Pulls perfect in both low and reverse, but will not shift out of low?? Any ideas
  12. 35 mud rovers not rogers
  13. I ran 35 Rogers for years with 410s without any issues, changed to 488s much better at take off from a light, and much better while in overdrive
  14. Anybody running without a high valosity joint? Meaning extend shaft and replacing HV with standard Ujoint
  15. Really cruiser never seen or even heard of it before honestly I was floored when I found it
  16. Update wasn't the pump the hose was swelled up just before pump slowing flow/pressure to the point of almost killing the engine
  17. Have you ever changed your fuel filter? 2nd check your fuel pressure
  18. You nailed it only have 29psi at fuel rail
  19. Cat gone
  20. This what I did works fine
  21. Gents Driving down the road if I put pedal more than say half way down motor starts cutting out, runs smooth at an idle, and seems to run smooth up to that point them nothing? Thinking either fuel filter or pump? Your thoughts??
  22. Anybody have 1? I need it please text 765-720-2647 thanks O I'm in central Indiana
