banshee
Everything posted by banshee
  1. :agree: but extended time on road in 4wheel could cause issues with the drivetrain over time ‘shouldn't be an instant thing’... Be careful and remember it’s there while in use on-road... B…
  2. I just went thru the same thing, same cylinder, new O-rings, removed and used green scratch pad to clean everything, put back together using vacuum grease, and all good... Note I replaced every one, only do it once I always say… good luck... B...
  3. dunlop mudrovers good, cheap, not bad onroad live... B...
  4. NICE but before tunes??? :dunno: B...
  5. cheap & easy, Remove old Control arms, cut off ends, lengthen between ends Re-weld on old ends, remember to rebuild if in question, what you add to one add to the others, keep pinion angle correct... just a thought… B…
  6. 'flat steel instead of diamond plate' why??? I like it nice job... :bowdown: ... B...
  7. :agree: HOTT Totally love the light bar, home run, best idea i've seen?? B...
  8. I normally reply to this question ‘stop signs are nice’ :idea: but that's illegal… :no: B…
  9. 'herculine the floorboards' not so bad mine's lineX yes loud, yes hot, but not as bad as nothing at all, and yes easy to clean, just remember to leave a drain port/hole something to allow water to get out INPORTANT... had to drill mine out afterwards NOT fun… B...
  10. :clapping: "bumper crop!" :clapping: play on words I like??? B...
  11. Definitely spent some time on it, Not just thrown together, :clapping: I like it… B…
  12. wait untill you see the one where the water is running thru the doors
  13. bad idea needed help with bad idea the crew
  14. Camera being a pain, pic’s to follow... B...
  15. banshee
    really bad day
    point taken $300 radiator not so bad OUCH man going to make it? B
  16. banshee
    really bad day
    good news as of 5:pm this afternoon and $80 my radiator has been repaired I'm ready to install it first thing in the morning and do a little testing then Saturday head out around 6:an for Linton and redbird and a day of wheeling yes the radiator is toast, but should make it thru the day without issues we'll let the lawyer’s deal with everything else… looking forward to seeing you all there!!!B…
  17. IAT thanks don... B... I think he means the IAT (Intake Air Temperpature) sensor. The stock location for this is on the intake manifold, not the airbox, although it is a popular performance mod.
  18. banshee
    really bad day
    no clutch fan bearing went out causing the damage, fan replaced radiator still in welding shop hopfully it'll be ready for saturday wheeling at redbird??? if not i'll be wheeling at TJ... B...
  19. isn't your high idle temp switch inside the airbox, and dosen't it have to be removed/relocated first? B...
  20. banshee
    really bad day
    ouch most expensive two hours wheeling I’ve ever spent 10:am installed new $250 radiator 11:am went wheeling 12:30pm clutch fan chewing on radiator 1:pm radiator removed at local shop to be welded 1:20pm stupid welder blew large hole into core instead of telling him and/or showing him how unhappy I was I just left, I’ll call tomorrow afternoon to see if he made any progress, Note got brownie points from wife for not showing my ^ss at shop… B…
  21. as of 8:pm i now have a three core aluminm radiator in my manche i also have a SS 20g fuel cell inside the bed, lines on, not mounted down, antifreeze not installed, things to do tomarrow... B...
  22. Received my new three core aluminum radiator from champion second received my CC window sticker pics after installation :cheers: thanks Pete :cheers: almost ready for redbird the 27th… anyone else going to be there??? B…
  23. :agree: smaller isn't better, still need to hold overflow at high running pressure/temp and be able to return it into the system after cool down... don't want to be loosing coolant... B...
  24. Nice :clapping: did i read that right? only 113thousand? Barely half done… B…
  25. Pete calm down your doing a fine job... B...
