Q's Jeep
    Knoxville Iowa
  • Interests
    Fishing Hunting Aviation
Q's Jeep's Achievements
  1. Possible starter relay ? Located on pass fenderwell .
  2. Got both sides and all the trim. PM sent
  3. I got one.
  4. wanting to go to open system. would like to find 3-4 core metal radiator what year do i need to go for ? mine is a 87 4.0L 4x4. Next can the heater valve assembly be removed going to the open system ? Thanks
  5. Wix or Bosh the only filters used on my vehicles.
  6. Team Cherokee has all that stuff
  7. Got a chance to pick up 87 MJ 2.5 4x4 5 spd long box fairly cheap. Needs a clutch and tranny and transfer already out. Box is rough but has good doors hood glass and all the trim blue. Just gonna part it out if I get it . Is it worth it my be able to get it for a couple hundred . And it has a custom topper on it. Pretty much have all I need for mine. Just looking for some feed back Thanks Quint
  8. PM sent
  9. The question I have , did the cluster swap , need to replace the oil sending unit , is the replacement the bell shaped type prt#56026782 ? Looking at one for a 4.0L Cherokee W/Gauge 84-91. Local parts store has a bunch of Dumb A*** working . Thanks Quint
  10. Looking for some opinions on some tires 235/75/15 for my 87 4x4 . It will be a daily driver pavement and gravel . Looking at Cooper Discoverer A/T3 , Nexan Roadian A/T2 , Wildcountry or any other recamendations. Live in Iowa so we get all types of weather . Some off road when going fishing and hunting. Thanks Quint
  11. Thanks Q
  12. Good day to all. New to this MJ addiction. Mine is a 87 4.0L 4x4 aw-4 column shift. Has the SPORTTRUCK emblem on the box. What is the actual model of this , Base , Poineer , I'm just curious. Thanks Quint
  13. Thank you sir
  14. Good day to all ! Question on the starter relay on my 87 4.0L 4x4 AW4. The relay on mine has 1 terminal , 4 spades and a blk wire that hooks to the neg battery cable. All the ones Ive been looking at are 1 terminal and 3 spades . Were can I find the OE one like mine ? Thanks Quint
