Q's Jeep
Everything posted by Q's Jeep
Possible starter relay ? Located on pass fenderwell .
Got both sides and all the trim. PM sent
wanting to go to open system. would like to find 3-4 core metal radiator what year do i need to go for ? mine is a 87 4.0L 4x4. Next can the heater valve assembly be removed going to the open system ? Thanks
PM sent
Wix or Bosh the only filters used on my vehicles.
Where can i find this?
Q's Jeep replied to xComancheKidx's topic in MJ Tech: Modification and Repairs
Team Cherokee has all that stuff -
Got a chance to pick up 87 MJ 2.5 4x4 5 spd long box fairly cheap. Needs a clutch and tranny and transfer already out. Box is rough but has good doors hood glass and all the trim blue. Just gonna part it out if I get it . Is it worth it my be able to get it for a couple hundred . And it has a custom topper on it. Pretty much have all I need for mine. Just looking for some feed back Thanks Quint
The question I have , did the cluster swap , need to replace the oil sending unit , is the replacement the bell shaped type prt#56026782 ? Looking at one for a 4.0L Cherokee W/Gauge 84-91. Local parts store has a bunch of Dumb A*** working . Thanks Quint
Looking for some opinions on some tires 235/75/15 for my 87 4x4 . It will be a daily driver pavement and gravel . Looking at Cooper Discoverer A/T3 , Nexan Roadian A/T2 , Wildcountry or any other recamendations. Live in Iowa so we get all types of weather . Some off road when going fishing and hunting. Thanks Quint
Thanks Q
Good day to all. New to this MJ addiction. Mine is a 87 4.0L 4x4 aw-4 column shift. Has the SPORTTRUCK emblem on the box. What is the actual model of this , Base , Poineer , I'm just curious. Thanks Quint
Thank you sir
Good day to all ! Question on the starter relay on my 87 4.0L 4x4 AW4. The relay on mine has 1 terminal , 4 spades and a blk wire that hooks to the neg battery cable. All the ones Ive been looking at are 1 terminal and 3 spades . Were can I find the OE one like mine ? Thanks Quint
non comanche still a jeep ?
Q's Jeep replied to ejndssn's topic in MJ Tech: Modification and Repairs
Check fuel pump connector. Relay? Intermittent fuel pump issue/ could be on it's way of going out . Check fuel pressure. How many miles on it ? -
I will check it out when I swap it. pretty sure it isn't the solenoid because I use the screwdriver bypass method and it still didn't fire up. Where are you getting the starters from ?
I'm looking for a set for my 87 as well .
D35 Leak?!? How serious is this?! HELP!
Q's Jeep replied to lexluthier72's topic in MJ Tech: Modification and Repairs
Put 2 referance marks with a center punch, 1 on the yoke and 1 on nut . buzz it off pop the seal out put a little grease on the inside of the new seal to aid in installation and run the nut back till the 2 referance marks line up. Have done many this way and aint had one fail yet. You can do it !!!!! -
Anyone using Mystik Oil Products in there MJ ? Engine , Transmission , Transfer Case , Frnt & Rear Diff's ?
Alternator relocation question ???
Q's Jeep replied to Q's Jeep's topic in MJ Tech: Modification and Repairs
Where can I get on of these pulleys or a part number ? Called a couple of the local part stores had no clue what I was talking about. Any help would be appriciated Thanks -
Looking for the best place to to get a rear bumper for my 89 MJ 4x4. Or for bumper brackets to build my own. It is going to be my daily driver. Thanks
Just got my first MJ 89 4x4 4.0 AW-4/column shift. What is involved in relocating the alternator due to A/C comp is shot. Not going to retro the a/c . Or is there a idler pully assembly available to replace the a/c comp ? Thanks
