89comancheowner
89comancheowner's Achievements
Can Spell Comanche
Can Spell Comanche (2/11)
  1. I have a 89 Comanche that is 2wd and I am converting to four wheel. Here is the issue I have a 95 cherokee that I am using the auto and the transfer case. What wiring troubles am I going to have and what is the remedy.
  2. Going to get back to work on the MJ winter is coming need to get the 4x4 Swap done.
  3. were can i get some new spring pearches
  4. The rear axle in out mjs r spring under and cherokees are spring over can you just bolt the 8.25 spring over on or mjs using factory spring i see that the shock mounts would need to be changed what else would need to be done.
  5. Picked up some new bling today. Image Not Found
  6. Getting them ready for the 4x4 swap Image Not Found
  7. Well found this really clean 95 and had to have it. It threw a rod out the bottom of the motor but other than that it is really nice. So the plans are to put the doors on for power windows and locks. Change out my blue interior to the ultra clean gray interior out of the Cherokee. Got a three inch lift coming it will be here Wednesday. Ok now the fun part Taking all the drive train out to make my MJ 4 wheel drive hell ya. Note my MJ is standard and going with the auto thats in the Cherokee. On the way home Image Not Found Image Not Found At Home Image Not Found Image Not Found Image Not Found
  8. bought a stripe stripper wheel and went to town on the stripes i really did not think it would work but I was wrong it took me 15 min to do one side. Here is a before. Here is after
  9. ya I know what you are talking about I have a 1990 300zx twin turbo with a rod sticking out the side of the block but with that said i really like your project.
  10. would like to have that 3000 GT in the back of your pics
  11. Looking good had to Do the same thing with mine keep us posted good work
  12. Doing an interior swap and need some gray door panels please let me know.
  13. Not smashed to bad had to cut out bumper support on the frame and weld in one off of my 2 door Cherokee donor. The tires are 31/10.5.
