89comancheowner
Everything posted by 89comancheowner
I have a 89 Comanche that is 2wd and I am converting to four wheel. Here is the issue I have a 95 cherokee that I am using the auto and the transfer case. What wiring troubles am I going to have and what is the remedy.
Let the build begin
89comancheowner replied to 89comancheowner's topic in Member Projects: Your Comanches
Going to get back to work on the MJ winter is coming need to get the 4x4 Swap done. -
Axle swap 8.25 crysler axle
89comancheowner replied to 89comancheowner's topic in MJ Tech: Modification and Repairs
were can i get some new spring pearches -
The rear axle in out mjs r spring under and cherokees are spring over can you just bolt the 8.25 spring over on or mjs using factory spring i see that the shock mounts would need to be changed what else would need to be done.
Let the build begin
Picked up some new bling today. Image Not Found -
Let the build begin
Getting them ready for the 4x4 swap Image Not Found -
Black89Comanche - Dad's First Comanche
89comancheowner replied to Blue88Comanche's topic in Member Projects: Your Comanches
OOOOOOOOOOOOO UUUUUUUUUUUUUUUUUUUU- 41 replies
- Headliner DIY
- Headliner
(and 3 more)
Tagged with:
Let the build begin
Well found this really clean 95 and had to have it. It threw a rod out the bottom of the motor but other than that it is really nice. So the plans are to put the doors on for power windows and locks. Change out my blue interior to the ultra clean gray interior out of the Cherokee. Got a three inch lift coming it will be here Wednesday. Ok now the fun part Taking all the drive train out to make my MJ 4 wheel drive hell ya. Note my MJ is standard and going with the auto thats in the Cherokee. On the way home Image Not Found Image Not Found At Home Image Not Found Image Not Found Image Not Found -
Let the build begin
bought a stripe stripper wheel and went to town on the stripes i really did not think it would work but I was wrong it took me 15 min to do one side. Here is a before. Here is after -
1988 5.9L Magnum V8 Comanche
89comancheowner replied to terrawombat's topic in Member Projects: Your Comanches
ya I know what you are talking about I have a 1990 300zx twin turbo with a rod sticking out the side of the block but with that said i really like your project. -
would like to have that 3000 GT in the back of your pics -
Project back from the dead
89comancheowner replied to Druville's topic in Member Projects: Your Comanches
Looking good had to Do the same thing with mine keep us posted good work -
Doing an interior swap and need some gray door panels please let me know.
Let the build begin
Not smashed to bad had to cut out bumper support on the frame and weld in one off of my 2 door Cherokee donor. The tires are 31/10.5. -
Let the build begin
put different wheels on -
Let the build begin
got my front end changed over here is a before and after what do you all think. Before: After: -
will take one or two or three or four but I need 33/12.5/15s
What is the rear axle in a 1989 2 wheel drive and what is the axle in a 1989 4 wheel drive cherokee any help would be great
I am wondering the bolt pattern on Our MJs and does newer jeep wheels fit
Let the build begin
I officially got the parts jeep home and the wife can not believe that i am going to strip it o well. I will do the front firsts and then start on the dash changing it from blue to gray and then the seats and console. Then the 4wd swap i have the manual trans that was in it but it lost a few gears so I am going to take my 2wd manual and have the output shafts changed. -
Let the build begin
:wrench: Took the front end off the bumper mount on the driver side was smashed in so i cut it out. Getting ready for the new parts from the very clean 1989 jeep Cherokee that I picked up today. So now I can convert mine to 4wd when i get a manual 4wheel drive trans. GOT LUCKY FINDING A WHITE ONE -
Manual trans question
thank you for your answers looks like i need a 4wd trans the Cherokee that i am getting is 4wd and my truck is not but the trans is bad in the cherokee so I can rebuild mine with that output shaft? -
What is the difference between a 2 wheel manual trans and a 4 wd manual trans. like adaptability.
