fiatslug87
Moderators
    8
Everything posted by fiatslug87
  1. I Like it :thumbsup: I've heard that 2011 will be the last year for the Dakotas, any truth to that dasbulliwagen?
  2. What do you mean by "decal". If you mean the emblems that are Black/Chrome Junk Yard or ask in the Classifieds.
  3. In case anyone searches for this topic and comes across this thread:
  4. I just purchased one of these, a little pricey (could get five from Quadratech for the same price), but I got tired of the cracking bottle and the bad cap seals. http://www.macsradiator.com/replacmentjeepradiatorfilltanks.aspx There used to be some on e-Bay for ~$100 but I don't see them anymore.
  5. The panel is secured to the brackets with two fasteners each, the tan part at the top of the brackets in the picture is actually part of the panel that I cut out to salvage the brackets. The panel should be wide enough to span from under the plastic trim piece under the rear window to these brackets (just off the floor), maybe the PO cut the panel short? The brackets have that angled shape at the bottom so the “tabs” in the floor covering can slip inside them. Should look like this.
  6. Lets start our own auction. What do you think it will go for? My guess: $7500
  7. Can you post a couple of picture of these "brackets"? Are they bolted to the floor and look like this, they are for the carpeted rear panel that covers the back of the cab, available with some trim packages.
  8. According to the diagnostic procedure (first page last two bullet points), vacuum should be present when you unplug the connector, so it seems like a bad solenoid.
  9. I have a slider up in the rafters of the garage, I'll pull it down and trace it. PM an address. -Mike
  10. #6 in the pic below is PN 53002864 from the dealer $30-50
  11. Who wants to be like Pete? http://cgi.ebay.com/SIZE-7-1-2-STETSON-Cowboy-Hat-Jeep-Comanche-Style_W0QQitemZ330418870548QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item4cee7fd914
  12. Yup this looks like the one from the Accessories Guide.
  13. Have you checked the EGR valve? I had similar symptoms, turned out that was it. Here's how to check the EGR, from the '90 FSM
  14. I have a grab handle and a floor shifter handle and possibly the visor clips (long visors or short?). I'll check and send pictures tonight.
  15. Here's how to check the EGR, from the '90 FSM
  16. Did you try this decoder? http://jeep.avtograd.ru/VIN/vin_en.asp 2WD, 2.5L, PIONEER
  17. What? They work for me even from your quoted post. Just go to http://www.napaonline.com and search for part numbers: 7151365, 7151366, 7151367 Edit: Eagle, you beat me to it.
  18. These are all the lines that lead to the valve cover that you can get from NAPA. http://www.napaonline.com/Search/Results.aspx?Ntt=7151367&Ntk=Part%20Number&Nty=1&N=0 from cover to connector http://www.napaonline.com/Search/Results.aspx?Ntt=7151366&Ntk=Part%20Number&Nty=1&N=0 from connector to air box http://www.napaonline.com/Search/Results.aspx?Ntt=7151365&Ntk=Part%20Number&Nty=1&N=0 from cover to air box
  19. This might help you troubleshoot. And welcome. http://www.comancheclub.com/forums/viewtopic.php?f=9&t=12734
  20. Any shop that sells camper shells should have a boot gasket for the shell, very similar to the rubber strip from the bottom of a garage door as jimoshel mentioned. The problem with them is they rub against the back of the cab and eventually abrade through the paint. I prefer the type with their own window as Eagle described.
  21. Here's a BRAHMA on a short bed, fits OK, a little lower than the cab, and a little narrower than the bed in the front.
  22. I bought one at Kragens Auto Supply, it never worked properly so I took it back and got one from NAPA, it's been going for 7 years. Make sure you remember where all the spacers/bushings go if you don't have any reference material. Edit: Well, here it is if you need it from the '90 FSM.
  23. Shelby Dakota's had something similar. In '90 when I was looking for my Comance one dealer tried to get me to buy one of these since he didn't have any Comanches.
  24. Make sure to get yourself black lug nuts if you go with black wheels.
