fiatslug87
Moderators
    8
Everything posted by fiatslug87
  1. According to the 87-90 parts manual these are the part numbers for the gear shift lever assembly: AX4/5 XJ/MJ gas 83500518 AX4/5 XJ/MJ diesel 83501407 AX4/5 YJ 83503110 AX15 XJ/MJ 5252042 AX15 YJ 5252055 So AX4/5 and AX15 are different.
  2. The bottom piece is either the incorrect one for an AX-15 or somehow it's 180° off. This is mine as it exits the trans it bends towards the front, the shifter is in neutral in the picture.
  3. Thanks, really appreciate all the work you are putting into this!
  4. Is the photobucket fix supposed to be in this now?
  5. Here's a pic my wife took as it began (there was on and off cloud cover), we only got ~79% coverage here, you can see some sun spots on the surface. She used an 800mm lense with a solar filter.
  6. :banana: :banana: :banana: :banana: :banana: :banana: :banana: :banana: :banana: :banana: :banana: :banana: :banana: :banana: :banana:
  7. Has anyone fitted a cabin air filter into our truck's vent system somewhere?
  8. I'm sticking around for the 2045 event.
  9. fiatslug87
    Bed Plug
    Found them, if you want pictures pm an email address, I only have photobucket and you know how that is at the moment. It's yours for $5 shipped first class in a padded envelope. Pm if interested.
  10. fiatslug87
    Bed Plug
    I think I have a couple, I'll check tonight and let you know.
  11. No you're not, it's just good natured ribbing.
  12. I knew someone smarter than myself would eventually figure out how to get all the images back. Thanks guys!
  13. Almost makes you want a RENIX, doesn't it? :)
  14. Does this mean we should leave our images on PB for the time being and not delete our accounts?
  15. I have a soft spot for '88 Olympic editions.
  16. Thanks guys, that sounds more reasonable. I think the bolts are only 1/4 inch.
  17. Thanks Don. I didn't expect it to be that high and i didn't think the bolts were that big. I'm at work and will check tonight.
  18. Does anyone have the torque specs for the u-joint strap bolts? Same for front and rear driveshafts? Thanks
  19. Come on guys, 147 views and only 27 votes?! Don't let a non-MJ, especially non-JEEP win!!!
  20. It will be interesting to see what they do to it.
  21. This is a JC Whitney sponsored contest. http://blog.jcwhitney.com/wrenchandride2017/#woobox This is the direct MJ link http://woobox.com/vzfkjp/gallery/8LiSv9bl_6M Is it anyone's on this board?
  22. So Don secretly LOVES the RENIX system, that's what I have always thought. :rotfl2:
  23. Nope
  24. There are CARB approved headers, search Summit Racing find the one you like and look for a better price. Do not take the chance of using a non-CARB compliant header, never know how picky the smog tech will be, you don't want to pull the intake again.
  25. The '88 electrical manual can be downloaded here: http://comancheclub.com/topic/12083-electrical-manual/?hl=electrical+manual
