Everything posted by jeepthing07
RTV on water pump gasket?
jeepthing07 replied to chicofuentes0224's topic in MJ Tech: Modification and Repairs
i have put them on dry and with this stuff http://www.midwayautosupply.com/pm-1207 ... 39158.aspx never had a leak -
"A body that may very well be the body of the creature commonly known as “Bigfoot” has been found in the woods in northern Georgia." http://www.cryptomundo.com/cryptozoo-news/ga-gorilla/ Pictures here http://www.cryptomundo.com/cryptozoo-ne ... rilla-pic/ Weird if it turns out to be real...
4.6 the inline 6? i raced a 1995ish f150 (inline 6) with my 2.5 comanche and beat it years ago. they are slow as ****
front ball joint instal instructions
jeepthing07 replied to jeep_freek88's topic in MJ Tech: Modification and Repairs
you can rent the tool for free at autozone or you can get a OTC brand set like this http://cgi.ebay.com/ebaymotors/OTC-3-IN ... enameZWDVW cheap off ebay. the generic ones will just bend and be worthless. i bought a OTC off ebay with the extra cups for $30 -
rabbits can be mean http://www.nothingtoxic.com/media/12143 ... ing_Itself
I wouldn't trade a comanche that nice for a 4cyl TJ my friend had one and i was always pulling him out. as long as he kept it out of mud it did ok though.
"Some historians have reason to believe people don't really understand the genealogy of past U.S. Presidents. Research shows at least five U.S. presidents had black ancestors and Thomas Jefferson, the nation's third president, was considered the first black president, according to historian Leroy Vaughn, author of Black People and Their Place in World History. Vaughn's research shows Jefferson was not the only former black U.S. president. Who were the others? Andrew Jackson, Abraham Lincoln, Warren Harding and Calvin Coolidge. But why was this unknown? How were they elected president? All five of these presidents never acknowledged their black ancestry." http://www.diversityinc.com/public/1461.cfm i don't know why people are making a big deal about it Obama is just as white as he is black lol
even if he becomes president he won't be the first black president
:agree: Kill'em all let God sort'em out... :evil: :D X3
replacing battery acid
jeepthing07 replied to jtdesigns's topic in MJ Tech: Modification and Repairs
i thought that was for testing antifreeze -
I finally found a place that will press a new one on and true it up for $75. I might buy a new crank/rod I'm just trying to do this cheaply but have it be reliable. The PO rode it with a loose chain and it busted the case but other than that it ran good. i thought for $750 it was to good to pass up but by the time its done i will probably have over $1000 in it, still not bad i guess.
I picked up a Honda 400ex that needed the bottom end case replaced for cheap. So I'm tearing it down and everything looks pretty good so far except for when i got to the wrist pin. its scored some and so is the inside of the rod. The rod is not easily replaceable because its one of them cranks you have to press apart to install a new rod. anyone know how much shops charge to do this or know of a good cheap one?
School me on spider gears
jeepthing07 replied to watchamakalit's topic in MJ Tech: Modification and Repairs
you will need new carriers and spider gears -
oil gauge sticking sometimes
jeepthing07 replied to comanche87's topic in MJ Tech: Modification and Repairs
my sisters YJ's oil PSI was always stuck at 80. i replaced the sending unit and problem fixed. -
do I have to drain diff?
jeepthing07 replied to maddzz1's topic in MJ Tech: Modification and Repairs
just jack that side up a little higher than usual and it won't pour out. it don't need to be jacked up crazy high or anything -
Can this header be welded?
jeepthing07 replied to MiNi Beast's topic in MJ Tech: Modification and Repairs
When my YJ started stalling at stoplights on 90* days is how i found out my exhaust manifold was cracked, and when i was trying to find out what the problem was i noticed how hot my engine compartment was. then i found the cracked manifold pulled it off welded it stuck it back on and problem was gone... but it ended up cracking again but by that time summer was over so it kept my engine a little cooler.... but i replaced it with a doug thorley header never had it happen again. -
a cracked exhaust manifold CAN cause stalling.... its called vapor lock i had the same problem on my YJ thats what you get when you have a cracked exhaust manifold under your intake manifold and injectors it will be more noticeable on hot days too http://en.wikipedia.org/wiki/Vapour_lock -
you can weld it... i did but a couple months later it cracked right beside the weld so its alot of work for nothing. check out the APN headers they are supposed to be really good and cheap! -
i got TRW's for like $100 from advance auto
AEV were the only people who could afford them anyways i'm guessing
One of the cleanest MJ's I have ever seen...but for $5K
jeepthing07 replied to robfg67's topic in The Pub
maybe if it was a 92 -
http://4bangerjp.com/forums/index.php?topic=2030.0
nope
