btm24
Everything posted by btm24
  1. Do you have a pic of the build date?!? Brandon
  2. 703 injectors are a popular upgrade/replacement. You can get them any where from 50 to 80 bucks shipped used. Just clean them replace the o rings and your good to go. Thats all I can help with tho sorry Brandon
  3. The XJ ones won't fit right but close enough. I know Some body that has them in there Jeep and they look great and keep the carpet very clean. Brandon
  4. Nice find :cheers: Brandon
  5. Why didnt you try and get the dents out b4 you painted? Looks good tho :cheers: Brandon
  6. This may help you with the 4:10 on 33's ? http://www.comancheclub.com/forums/viewtopic.php?f=9&t=28875 Also go with a XJ or MJ axle you will be much happier. Brandon
  7. Amazing :clapping: Brandon
  8. 1st let me say great job so far :cheers: 2nd where did you get/mount the power inverter? It looks very help full. And how did you wire it? Looks amazing! Brandon
  9. It would be really nice to follow along with some of the projects easy. Brandon
  10. I get 12mpg city and like 15/16 highway :( I have a lead foot :roll: . For the $ you spent on the new o rings and what not why didnt you look into getting the 703 injectors? Brandon
  11. Cool :drool: BRandon
  12. http://www.modifiedpowerwheels.com/forum/ :thumbsup: Brandon
  13. Not aftermarket but is not a MJ tail gate that will fir the MJ with "some" modifications Image Not Found Its off of a J-series pickup. Info on how it can be made to fit can be found here: http://comancheclub.com/forums/viewtopic.php?f=7&t=14951&start=45 Brandon
  14. Got pics? :brows: Brandon
  15. this may be of some help http://www.comancheclub.com/forums/viewtopic.php?f=3&t=29175 brandon
  16. btm24
    Coil spacers
    Got some thanks ya'll! Brandon
  17. I'd try this but, won't WD-40 deteriorate rubber? Yes . You should not use WD-40 on rubber or plastics. WD-40 is a water displacing petroleum product . It will dry out and damage rubber and plastic . Better to use silicone, hard grease or mineral oil when lubricating around rubber or plastic . Exactly how bad would it hurt our bushings ? Probably not enough to worry about . More critical to smaller parts like seals and o-rings . Thank you for the info Ill be taking out the bolts that hold the rear of the leaf springs in and will use a grease gun to grease it all up and put it all back in. I just hope that will help its getting worse :fs1: Brandon
  18. Diesel Was way cool Brandon
  19. btm24
    MJ Archeology
    Ive been though most of the builds starting with the last page and moving up. I stopped at about page 15 a few months back and have not started again. One of the really old ones i liked was jeepaholic's 12" MJ http://www.comancheclub.com/forums/viewtopic.php?f=7&t=4326 Not sure what happened to it but i liked it, and even saved his build page. There were alot of them that I loved but it would take a while to find them again. Brandon
  20. Not a 35 front dana 30 :thumbsup: Brandon
  21. :oops: that sucks but hey build it bigger and better Brandon
  22. Yeah and I'm not sure what bushings they are what ever hells creek use's. Do you think if I greased the bushings that would stop the squeaking? Brandon
  23. It sounds like what ever thats been squeaking is coming from the back end of my truck. What are things that I could grease up to try and stop the squeaking? I was think the leaf spring bushing but :dunno: Any thoughts will be help full thanks Brandon
