Everything posted by JOMJ87
I am going to look on there website and see how to contact them but if all else fails ill send it to the reader ride ADDY. OK i found it here it is letter to editor email addy jpeditor@primedia.com Cole
WOW good eye i didnt even notice it. Someone should write them and tell them they need to do a reprint. and i vote Pete since he rund this sh1t. :D Just kidding but i think i might email them and let them know. ;) Cole
here's my friends YJ same as mine just i didnt have a pic of mine you can see the clips and everything. Just keep in mine he has about 6" of lift and 35s also when you do it don't just cut the stockers in half we cut a chunk out of it and it worked out great just leave a little more than you need to drill the hole for the pins. Plus his stock arms are straight and ares are bent at the top. Cole
Ok just for you to see in person pull one tire up on a ramp and take a look at everything as far as flex. Then unbolt your sway bar and pull back up. You will see a huge diff in flex between the 2. You use a disco so that you can have them connected for road driving and then in a flick of some pins there are disconected and you get way better flex. I love haveing them but they can be a pain to put back on :wall: but i just need to refine them. Look into it you will like the difference in the flex of your rig. Just make sure you don't leave them disco'd on the road cause you will NOT stay in the road at higher speeds I know from experience and with saying that you also need to have extra pins in the truck at all times. BTW i can post pics if needed i have 2 jepps here with the same homemade setup on them just let me know. Or ill try to find some i might have a little later and go ahead. Cole
Mitchel on demand is like a haynes on steriods and it gives great info and diagrams. I can "GET" access at certain times but not steady and not for the next 4 months since the guy i "get" it from is deployed. We have used it alot and it is so much better that a chiltons or haynes IMO it goes into alot of detail because its for mechanic shops to use. :cheers: enjoy it while it lasts. ;) Oh yeah and any projects you plan to tackle go ahead and print off anything you might think you need for later since you want have access long. :D Cole
I want green to. Cause black is way to hot for SC summers out working on the truck. :D Cole
Thats what i thought at first glance maybe its just a sothern thing??? :cheers: Cole
I Did the same thing But make sure you round the end of the pins off to make it alot easier to put back together. ;) If you want pics i can send them to you or post them. Cole
Yeah if they had the color i wanted i would but i just spray painted the whole thing OD green so it wouldnt be right now for the exterior. My main concern was how well a brush worked on applying it. Sounds like this is great stuff. I will find the silver and use it. Thanks alot Cole
http://cgi.ebay.com/ebaymotors/Jeep-CJ- ... enameZWDVW This one is nice my friend has it and it looks good. Cole
Not to jack the thread but i seen some really nice ones on ebay. Cole
Sweet I am going to look on ebay and see the price and prob order some. I wish they made this stuff in flat OD and i would repaint my whole truck with it. :D I have heard alot of ggod things about it so i will see. One more questions: It goes on good with a brush?? I was thinking when i seen it in gallons and stuff those were for spray guns but then i seen the starter kit and it had brushes and then Ya'll are talking brushes> Just thought id ask. Cole
I don't have any hole but alot of surface rust. The Original owner of it off the lot was in FL and then the PO before me moved to my home town and worked with my dad and me at a tool and die plant. Thanks for the info. Cole
What rear end and tranny are in these pics
JOMJ87 replied to feerocknok's topic in MJ Tech: Modification and Repairs
Yeah i know where thats at its a big baseball town. I played allstars there in school. Some good times i may get back with you on that and meet you one weekend if nothing else works out. I just want to think everyone for the support and help with this axle issue. :cheers: Cole -
SO guys give me a list of your hookups you might have. Oh yeah how much does it take to do my floorboards I'm talking everywhere the hump and all covered in it??? Cole
To narrow for a manche. But thanks neways. Also isnt an 8.8 narrow? I know i read that somewhere but can't remember where it was. Will this cause issues with me havine such a big lift and 35s or should i be OK?? I really don't want to run spacers. 8) Cole -
That would be great. And by the way what road (interstate) do you take to get to tellico from your place? Thanks alot Cole -
Ill et you know if i need you to. How much is an 8.8 from your yard with 4.10 ratio?? Cole -
Turn signals and hazard lights-1989 MJ
JOMJ87 replied to Kenosha Warrior's topic in MJ Tech: Modification and Repairs
All the lights are kinda linked together thats why if you have one out that side flashes faster than it should. Maybe put the old bulbs back in just to rule that out. Cole -
Depends I got to deploy to the desert At the begining of the year and then after that i am looking to change bases.So who knows. Cole -
Will do thanks. I submitted request to about a kajillion JYs and hadnt heard anything. Thanks Pete Cole -
Oh yeah I was saying i wanted to come up closer to all of you guys that seem to have all the right parts. But most likely it will be awhile i will end up overseas first then maybe i can get lucky :brows: Cole -
I think its under the dash in the top of the fuse panel.IIRC I know for certain it wil make them act strange. My buddy had one go crazy on his YJ and they did some crazy stuff. Also if you change to LED bulbs you will possibly have issues with the relay. Cole -
Help - Bad Shimmy, Running Warm
JOMJ87 replied to Rundel's topic in MJ Tech: Modification and Repairs
He will when he hit a big dip in the road and the coils sling him in the ditch and YES it will do that I know first hand and it won't happen agian cause know i carry spare pins for my Disco's. :eek: Cole
