Jeeper1093
Everything posted by Jeeper1093
  1. https://www.facebook.com/marketplace/item/2275364879327753/?mibextid=dXMIcH https://www.facebook.com/marketplace/item/755102306361795/?mibextid=dXMIcH
  2. Fantastic. That's simple enough. Thanks for the help!
  3. I am looking for a vacuum fitting for my 86 4 cylinder Comanche. I am loosing vacuum around the 4 line fitting going to the throttle body. I have no idea what this part is called so I am having trouble finding one locally. If any knows what it's called or has info on how to get one, your help would be greatly appreciated. I have a rough idle and I believe that this leak may be causing it. Thank you in advance for any help.
  4. I'm in Boone NC. I have an 86 2wd and 87 4wd. 2wd to be for sale soon I hope.
  5. Castrol with a quart of Lucas high mileage and you're good for 5k
  6. Try OC Auto carpets
  7. https://www.facebook.com/marketplace/item/652721765816226/
  8. How much do you think shipping would be to 28607
  9. Thanks Cruiser. I'm going to look into it today. I can't find any issues under the hood, thought it was the vacuum ball but it's not. Goona double check under the hood and then start looking under the dash.
  10. That's what I figured. I'll have to make time to tear into it
  11. I don't think that it will fix it either but I will try it.
  12. My 86, 2wd, 4cyl, 4 speed only blows heat out the defrost. I can't find any vacuum leaks. put a new vacuum ball on it and no improvement. What else do I look at? Thanks in advnce for any help.
  13. Pete has one
  14. The Jeep CJ-8 Scrambler had no break between the cab and bed. Way better than a Honda Ridgeline!! It does look to be a Mopar JK-8 conversion.
  15. I have an 86 Comanche with a 2.5 4 cyl. It needs a radiator. Is there an upgrade option or is a stock replacement from Napa good. I have no overheating issues with it the way that it is. It's just starting to leak. Thanks for the help
  16. This is definetly on my radar for a future purchase or 2 maybe.
  17. If you still need these specs, I can help you as soon as my Black 87 gets out of the shop. My 86 is broken or I would help you now
  18. I am parting out an 87 with a Dana 35. I can pull the spider gears if they will work for you. Unless someone wants the complete axle.
  19. Thanks Joliet
  20. I would agree that the cloth is more comfortable but the passenger seat is near perfect. I would no rule out cloth as long as I can find a matching set.
  21. It may just be the lack of light. I took the pictures in the dark. I'll get better pics in the morning. There is a set of black seat covers behind the seats. I haven't looked at them yet. It's kind of a carmel color interior.
