Jesse J
Everything posted by Jesse J
  1. ok so updates updates. It bombed emissions due to me putting my map hose fix in the wrong hole on the throttle body. I have yet to take it back to the shop to get it re tested. This thing burns fuel like a mf I will tell you that much. I think it doesnt help that I am a little undergeared with my 4.27s. I have decided to run dual tcases it being stick now its going to be tricky to wheel without a granny low. Was running the numbers and if I chopped up my spare np231 I would have a 138 to 1 crawl. it also gives me a better front driveshaft angle which I desperately need with my front 44 and 5.5 inches of lift. Also I will be pilling the 92 HO out of the cherokee to stroke and bore. And so hopefully next summer the comanche will get a HO stroker. I fixed the overheating. closed to open did the trick I spent a total of 5 dollars on it just for some hose adapters I had everything else on hand. And my front LSD showed up so now my master installs need to come (eta mid november) and I will have double true tracs and 4.89s
  2. fair enough fair enough
  3. but they are cool
  4. thats a good point.
  5. could you print one of those and then be able to somehow cast them ?
  6. I won an MORE steering brace at the takeover and I am super excited to put it on the jeep. Seems like a quality product
  7. ok thats what I thought. anything else I can do?
  8. I used brakleen because I used the rest of my carb cleaner to clean my throttle body I will do that when I get the chance. o2 sensor is downstream on the downpipe of the exhaust correct?
  9. we are leak free from as far as I can see. anything else I can do to make it run cleaner? except not own a 34 year old truck
  10. well in classic fashion I took my throttle of to clean it and I found that my vac line into the throttle wasnt going to the right hole on the nubs. the top one I thought the top one was the right one but nope its the bottom. figured I don't need to do tip 31 because I have basically already done that with the brake line?
  11. it looks great! I have heard it really tightens the front end up
  12. I am pretty confident about the vacuum to it. the little rubber thing that connects right to the throttle body isnt the tightest fit I had to push it back in before the test.
  13. the actual sensor?
  14. dig the louvres!
  15. it has been deleted thanks to your awesome writeup and video
  16. it got a new pump last week I do not
  17. I got my emissions done and it is baaddddddd. I should be below 220 HC and I am at 3086-4046 and for CO2 max is 1.2 and I have 13-14.5. My map vacuum line is fine I rebuilt it with some brakeline because it snapped a while back. I have no idea what to do because I like driving my truck. I can sign up for a vintage license plate but then technically I can only cruise and take it to car shows. I also have the option of swapping an HO into it?? new injectors?
  18. I was running a solid 220 but like I said that is pre burp I have a good feeling
  19. ok I got the swap finished up this morning. I am running about 10-20 hot still but I havent even burped it yet!
  20. I would like to build the spare HO (stroker maybe??)in a year or 3 so fully HO swap because my renix has 312 and counting. thats smart. the new shop has a overhead s shape with a chain hoist idk about getting the block on a pallet and out of the way. Whats the best way to stop rust from getting to it? just soak it in wd40?
