pizzaman09
Everything posted by pizzaman09
I didn't know this! Makes sense, it's a variant of the jack points on my 62 Austin Healey and 99 BMW, they both use a rod that goes into the rocker panel to jack it up from the side. Nice design that kind of locks into place and is fairly stable. I'm not much into old American cars so this is not a detail I've taken note of before.
I have to admit, I'm not sure what this does, can you elighten me?
Based on my many years of cruising bring a trailer, I'm convinced that 50% of XJs and MJs with this grill have them in upside down. It's almost like a coin toss. I approve that Jeep did an XJ this year!
I don't really want to have to get the pan past the axle so I'm leaning towards the single piece. I had a heck of a time trying to get the axle low enough to get the pan out last time.
Last year I changed my rear main seal and oil pan gasket to try to fix the oil leaks I have. I was under the truck today and see that the Fel Pro 1 piece gasket I used on the oil pan appears to be extruding out at the rear. Does anybody have an opinion on whether the single piece or multi piece gasket is easier to deal with in install as I'm going to have to do this again.
87 MJ D44 axleshaft endplay?
pizzaman09 replied to jpnjake's topic in MJ Tech: Modification and Repairs
That is strange. What brand bearings did you go with? I just did SKF bearings on my D44 and have no end play. -
Brake Lights Not Working: Help Diagnose
pizzaman09 replied to Comanchemodder's topic in MJ Tech: Modification and Repairs
I am very appreciative of this thread and the positing of the electrical diagram. I personally found my brake lights not to work because the wire connected to the brake light switch was fatigued off on the LT Blue/ black wire. Following the electrical diagram allowed me to zero in on the issue. -
This is really funny, last time I purchased mulch and potting soil at Home Depot, I threw the potting soil in the trunk of my Austin Healey Sprite and the mulch in the passenger seat.
March 2026 - A Slippery Slope Build
pizzaman09 replied to 89 MJ's topic in Comanche of the Month (MJOTM)
This is a Comanche of be very proud to own. Ultra clean outside and in, tastefully modified in all the right places. Well done and congratulations on the Comanche of the Month! -
I agree that forced induction can be fun, but I'm a bigger fan of the power curves of a good naturally aspirated engine, many can have epic amounts of character. Plus the naturally aspirated engines just sound better.
Re-Seal my sealed beam light
pizzaman09 replied to AnotherOldJeepGuy's topic in MJ Tech: Modification and Repairs
My 1990 side marker lights blink. It's a late 1989 build if I remember correctly. -
Sure is!
Some CVTs are fun to drive. I'm personally a fan of any CVT that doesn't have fake shift points. I like the rubber band feel. Probably the most fun rental car I've had in the USA was a Nissan Cube because the CVT just gave it a bunch of character when you drove it. I dislike CVTs that have fake shift shock, it ruins the experience and feels really wrong. I once had a rental Optima, of which made 11 simulated shifts from zero to highway speed going up a long on ramp.It just kept taking the car out of peak power for the sake of making it feel like a slush box.
I would skip glueing it and just put it back together unglued for your test so that there isn't anything different with respect to the seal. The I'd go spend $30 at the auto store for two new bulbs. I had one that has about an 1/8" diameter hole in it, must have been from a rock. That one was very weak and when I took it apart the glass fell off. Replaced it with a cheap Sylvania replacement and was much impressed with the greater light output. I really should do the relay mod or get some LEDs for it. -
Should I replace these suspension parts?
Those parts are still functional but there is a tremendous amount of compression set. The cracking is due to ozone attack over time. They are ready to be replaced, you probably won't notice any difference driving but theoretically your sway bar will react better. -
The 2000 mile drive each way makes it quite the expedition for me.
Look over the exhaust manifold for cracks.
Looking good hauling a lot of weight.
I haven't done Johnson Valley but have done the others, totally worth it. I'd love to get the MJ out there someday.
Glad you got it sorted out!
Oh, I didn't realize they changed those bits. Kinda surprising to hear that an OEM would mess up a clutch, it's kind of an easy thing to spec based on torque you need to transmit.
I've driven a 2015 four door Rubicon with the Pentastar and manual and found it to be excellent. I don't much care if my trucks are fast, I have a 99 BMW M3 to go fast in and feel real torque.
This so much! If I could buy a 2 door truck based on the 4dr JL platform with the Pentastar and a manual, I'd buy it immediately. I considered a 4 door Gladiator, and after sitting in one at a dealership, I decided it was too long and had too small of a bed.
Very nice. I did a garage a bit larger than your building attached to my house, I considered in floor heat but instead did 2" of foam under the concrete and a mini-split to heat it all. I did the same in my basement and it's nice though not a toasty floor like what you are planning.
