Everything posted by 70barracuda
Pressure for the LS is 58 psi. The jeep pump works great and achieves that but I think it's running out of LPH in the upper RPMs. The engine leans out when really getting on the throttle and it feels like it just hits a wall. I haven't pushed it because I don't want to lean it out bad. I ordered the new MTS sender for $90 of ebay and I'm thinking I could probably fit a walboro 255 or similar in the spot. It has the overall same shape as the factory pump.
Yeah. Its running out of fuel like 5.5k and up. I never took it that high with the ax15 so I only figured it out the PA trip
I need more fuel for my ls. Don't really want to run a cell and most in line pumps don't like siphon feed. Rather than mess mine up with trying to get something to work I'd like to buy a new sender and use that. Are these legit? https://raybuck.com/product/1986-1992-jeep-grand-wagoneer-gas-tank-sending-unit/ Also if anyone has any experience with fitting a different pump on these senders I'd love to hear it.
Cold air intake help
70barracuda replied to 70barracuda's topic in MJ Tech: Modification and Repairs
I thought about a cowl intake but the less hose it's sucking through the better. And it does see rain but if it's bad I ain't driving it. I thought about an air intake hole in the bumper and some mesh over it. Keeps it kinda high still. Only thing I got is the steering brace. I think I may need to run stiffeners eventually. -
I have an open diff at the moment, couldn't embarrass myself doing a one legged burnout.
Working out some bugs I found after my trip out to Carlisle. One of which being how hot the intake temps were while sitting in traffic. Trying to figure out a real legit cold air intake for this thing. My idea is to build a box for the filter completely sealed, and then cut a 4 inch hole below it, and have a hose routed through the fender area from the fog light opening right up to the filter box. Would it be okay to cut a hole right below the filter, will it affect anything structural? Open to any and all ideas. I do not have much room anywhere else except where the current one is at.
Definitely gonna have to be a burnout next time
About 20 minutes away at a cracker barrel. See ya guys tomorrow!
In my xj I have a cold case full aluminum radiator. I think it's pretty new because I had never seen that brand for our jeeps before. But I tried it out. They have great reviews for other vehicles. So far it's been great. I also have the dirt bound off-road 3 electric fan shroud and 3 spal fans. Factory water pump and 195 t stat. I have the fans tied in to the factory fan wiring so it runs exactly as it would (correctly with relays of course) been running it that way for 4 ish years and even in dead summer it never gets above 217, even with a/c.
So just replaced my stripped window regulator to a "working perfectly" manual regulator off eBay and it's worse than mine was. Won't pick the window up from any position. Atleast mine worked till about 1/4 inch of glass at the bottom. Anyway, trying to find a good manual one seems hard as all hell. New power can be had for like $45. Any chance the worm gear can be swapped from the new electric to my manual? Or any other fixes?
There's a pretty large Sheetz right off 81 into Carlisle, about 5 to 10 minutes from the fairgrounds, we could maybe do? When I registered mine it fell into the unlimited section so idk if that means I'll be with the other mjs or in another spot.
I'll be there the whole weekend with mine
Antigravity batteries are stupid light and compact, but the price is not.
I had kumho ecstas when I had 15 inch rims. Not bad a "summer performance tire". Then when I got 17s I had falken azenis fk510s. GREAT tire. Super grippy and amazing in the rain. Recently just switched to the general grabber UHP. It's considered a performance SUV tire. Don't have alot of time on it but so far seems great. Alot of the RAM and jeep SRT guys run them from reviews I read. These are all performance summer tires.
Girlfriend had this commissioned for my birthday. Now I have the motivation to take the picture for real.
Clutch pedal nylon bushing
I have the wilwood master already. I had taken a new master with a plastic eyelet and threaded it on the rod, the jeep push rod is just different enough it wouldn't sit in the wilwood master. But it sits at an angle and is definitely messing with my pedal pressure. I ordered a heim and will try to make it work without cutting the piece of the pedal first -
I believe those are for the axle pedal box shaft. I need the single one that goes on the clutch master pushrod to pedal -
Not that I've found. I think this is the # J4007472. But no luck on finding one -
Anyone have a lead on a replacement for that little nylon sleeve that goes on the clutch master push rod and clutch pedal? I can't for the life of me find mine or anything that'll work.
I got the brackets and shroud in good shape
So I know this tech is really old and caltracs are a much better set up, but these were $50 on summit so I figured why the hell not. And boy do they help. So much less bounce on take offs and even between shifts. Feels more planted. Now for some much bigger tires in the back end. So much for sleeper...
Broken clutch pedal???
Got the pedal back yesterday. Machine shop did an amazing job. Fixed the crack, rewelded the inside all around and welded the outside as well. Then bead blasted and painted the whole pedal all for an hours worth of labor at $75. Wayyyyy better than my booger weld job I would've done.
