The86manche
Everything posted by The86manche
Big dump and very long overdue update. Still working on this. But I am THIIIIIIS close to being done. The rust is GONE. From the last time I posted I was working on the driver side firewall and rocker corner. I have made monstrous progress. Starting with cutting all the rust out. It got cold so I rolled it into the garage and continued my work. Part of the floor, inner rocker, brace. And unibody were cut away. Starting with that little unibody spot so I can get the brace welded up and then inner rocker.
Little round one looks like it might be a cap to the rear bumper
'95 zj and '88 mj compatibility
The86manche replied to bmurray7's topic in MJ Tech: Modification and Repairs
I wouldn't say necessarily true. A/c compressor is located in the same place between the xj and zj and the 4.0 is virtually the same with sensors and mounts (depending on the year) The trans might be another story, and the wiring for sure.. -
I love watching junkyard digs. His channel is really funny and enjoyable.
I'd be interested in a set as well!
Tailgate Straightening
The86manche replied to ghetdjc320's topic in MJ Tech: DIY Projects and Write-Ups
As far as I know there isnt.. if you go this method you could use some thick metal as a brace/reinforcement on the inside -
Could find an identical one that's too far gone with good vin and swap to save it? Maybe? Good save either way!
Are you sure that'd an ax4? 4.0 should have an ax15. Have you done a service to the trans? New oil? Or checked the old metal for chunks or shavings?
If you don't mind the low pinion, can always swap the whole axle then
Zj grand cherokees. Limited trim will have 3.73s. I have a 3.73 ring and pinion but it's from a 35 I don't know if it would work for a 30..
I had one in my 5.9 grand cherokee and it took all the abuse a gave it. That being said, it's still better than a d35 lol
Ford 8.8 is another swap people do too. And you can keep your 5x4.5 bolt pattern too. And also discs.
The zjs had a d44a and were pretty tough axles. I beat on mine and had no issues. But you are right about the lack of aftermarket support.. it's very limited.
My best friends brother is saving this jeep! I sent him the link so he should be joining soon.
Tail light bulb sockets.
The86manche replied to Sir Sam's topic in MJ Tech: Modification and Repairs
I happen to have some sockets if you want them. Not new but in good shape. -
Jeep Turbine 10-Spoke Rims Restoration
The86manche replied to NEO auto's topic in MJ Tech: DIY Projects and Write-Ups
I qctually went theough my work to get some turbines that had been refurbed from keystone, the aftermarket manufacturer. They had 3 in stock qnd i took them. $150 a piece. I plan to clean up the one i have and paint between the spokes black. -
What is this? And how do I get another one?
The86manche replied to BentGear's topic in MJ Tech: Modification and Repairs
Its an idler pulley -
parts and deals on Market place
The86manche replied to rylee144's topic in Craigslist/Marketplace/eBay... i.e. Not Your Stuff
Went and checked that mj out last month, guy was nice, mj was very rough. He had a visor for it too for sale. Dunno if he sold it yet or not. -
If you still need sockets i happen to have all of them for both sides that came on some tail lights i found.
I would say pretty well! The spotwelds are still holding together on the bird my dad and i are building And the rocker panel i put on my zj has not split either (again upside down...) I recommend this if you have the money. And they sell adaptors too for different spaces and shapes
