ghetdjc320
  1. Personally I’d stick with the non-radius arm axles unless the price difference is huge. Those axles for most people will run 40’s if setup well. That will be either some serious trimming or serious lift in an MJ though
  2. Almost finished up! Just got the ski running today and will be finishing the seat and trim tomorrow. Need to move back to the MJ and take care of a hydroboost swap next
  3. Lol, in my defense it’s late here and it’s been a long day
  4. Good to know. Thanks for the follow up!
  5. Rockwell 2.5 ton axle or bust lol. You’ll have a good 4” of clearance under the pumpkin with 35s but you’ll never be able to break the axle
  6. Also, check all your sockets and bulbs in your tailights and turn signals
  7. There is a small lip where the blower motor fits through the firewall. I drilled a small 1/4” hole under the motor and into the wheel well opening to drain. That rubber seal will not keep out the water that pools up there
  8. In custom setups we use “universal backstrap”. You can but it at crutchfield and sometimes the local hardware store has a similar material that works
  9. And these are all California EO complaint: https://www.summitracing.com/dom/search/brand/magnaflow/part-type/catalytic-converters/universal/yes/emissions/california-eo-approved?SortBy=Default&SortOrder=Ascending&N=%3A%2B Or rock auto sells them carb compliant oem one for $245
  10. A regular magnaflow cat is under $100. Don’t gut your cat, it pointless. Just replace it with a weld on magnaflow if it is compliant. If not then get a replacement on rock auto. A gutted or removed cat is not an improvement over a good working unit. Just lookup how they work. They simple and effective devices. Essentially they are an afterburner for anything that didn’t get completely burned off in your engine. They aren’t a restriction or a filter. Here is a list of some: https://www.summitracing.com/dom/search/brand/magnaflow/part-type/catalytic-converters?SortBy=Default&SortOrder=Ascending They are available in both stainless and ceramic elements with or without heat shields (with is much better for our trucks)
  11. Please don’t take off your cat unless it needs to be replaced. All it does is stink up the cab and air around you and adds zero performance unless it was plugged (normally the ceramic honeycomb starts to come loose and blocks the flow). I run a magnaflow stainless cat that uses a stainless honeycomb vs the standard ceramic material. Here on island everyone removes there cat thinking they will gain power. Imagine walking down the road along the ocean with a nice salty breeze then a truck drives by and all you smell is gas for a minute. And for what???
  12. Let us know what height you end up with after the swap
  13. My BA10 worked flawlessly for years in my YJ. Lots of off-roading during those years also. Oddly enough, when I swapped in the “upgraded” ax15 I had nothing but problems. The 2nd ax15 was fine though. Everyone at the time (different forum) made it seem like the ba10 was on borrowed time but it was actually a decent transmission. I’ve only ever had one though so maybe mine was the exception???
  14. I think all of us that have run the General Spring ones have netted quite a bit of lift. I ended up giving away my general spring 4 leaf pack because it gave me at least a 2.5” lift on my soa setup even after setting for months and under load. I got a really nice used set from a California junkyard and had them shipped to me by boat. Once I received them I disassembled the pack, cleaned, painted and greased them. Threw in new bushings too. If you need replacements I’d recommend you do something similar. I’ve really been wanting to go to sua and get rid of this soa the previous owner did. If I did, I’d sell you my springs.
  15. I’ve seen them used before and it should work great.
  16. I am one of those people but on the pro audio side lol. The goal still needs to be a flat response from your drivers and a well dampened interior that does not add to or or take away from the original audio recording. This is the principle with which I approach every system I design and, to some degree I like to apply those same principles to car audio. To the OP, apologies for the spurious information. You can fit 4x6 speakers in back and they do help the overall soundstage. I recommend you buy a well built quality speaker and keep them all the same brand and preferably the same series. This should help timbre match the speakers and provide better sound quality. You can fit 5.25 speakers back there also but the corner position they are in greatly increases speaker reflection. So basically, just stick with 4x6 speakers and delete them as @Minuit suggests. One of these days, if I get the time and ambitions, I’ll work on installing a pair of 6.5 or 8” subs into the b pillars.
  17. Most car audio systems I hear are not what I would consider quality and getting a system to sound good in a rattly, loud old Jeep is tough. It’s so much more than just the kind of speakers installed. The environment needs to be treated first. I’m also strongly against using any sort of EQ. If a speaker can’t keep a flat frequency response than it not a quality speaker. Car audio is tricky though and my background is integrated AV systems in commercial and residential theaters as well as restaurants and club environments so I approach car audio a bit differently than others may. Not saying it’s the right or wrong way but I know what I’m listening for. In my mj though, I haven’t spent to much time on the audio system aside from dynamatting the whole interior, replacing speakers and wiring as well as installing the head unit. I was prepping for it though. Installed a singer 240a car audio alternator.
  18. Was a lot of work but well worth it. The backup cam is an awesome feature in a lifted truck especially when trying to hookup my boat trailer.
  19. Don’t meen to disagree but that hasn’t been my experience. I’ve noticed a more encompassing sound stage. The frequency response of the cab is all relative to what’s in the cab anyways. If I have a bunch of stuff behind the seats though the sound gets lost and they become useless. I really think it would be a great location for a pair of 6.5 or 8” subs though! Also thought about putting a sub in the center console.
  20. That being said, I currently run infinity reference 4x6s in back and 5 1/4 up front. Also installed a Sony double din touchscreen CarPlay head unit (that was a ton of work)
  21. 5 1/4 will fit with a bit of trimming. My though has been to put a pair of 6.5” or 8” subs back there behind the panels. It would be a nice custom setup
  22. I’m about to pull out the oem ones I have in storage for that price lol
