I’d also recommended removing the bed, tank and all the lines. No sesnse risking damage or possible fire here. I think you’ll find it’s totally worth it to do this. Should be a rewarding project though you will likely find much more rust once it’s opened up. I would also suggest you really support the frame when doing this. You don’t want to have any flex from the repair area. May not be a bad idea to weld on some frame reinforcement plate brackets to that area once the underlying repairs are complete. The junction where the bed frame connects to the uniframe under the cab are crucial structural areas as are the leaf spring mounting points.
Weak Brakes - Need Help Diagnosing
ghetdjc320 replied to dotnetrob's topic in MJ Tech: Modification and Repairs
The major difference between the XJ and MJ units is that the MJ is just a distribution block and the XJ is a proportioning valve. Meaning the XJ unit will effectively reduce pressure to the back brakes. This is important in a disk/drum brake setup to prevent the rear drums from locking up prematurely. I’d try slamming on your brakes in a safe gravel area and see if the rear locks up before the front. Ultimately though, that little block helps you brake safely but shouldn’t greatly affect your braking power overall if plumbed correctly. -
Can you take a picture of the booster and master cylinder? -
Looks like you may have an add a leaf in the pack from the pictures. Driveshaft angles are important here if you don’t want it to vibrate like crazy on the road. If you’re not running a slip yoke eliminator in the transfer case, then both the pinion and transfer case should be very close to parallel to the ground. In this scenario you’ll just need to lengthen your driveshaft at a local shop to fit. If you’re going to install a slip yoke eliminator, then the pinion will need to point up to the transfer case output. see this article for the tech info you need: https://4xshaft.com/blogs/general-tech-info-articles/driveshaft-angles Hope this helps
ZJ disc parking brake cable
ghetdjc320 replied to JIMMYRIG's topic in MJ Tech: Modification and Repairs
Here is the one you need: XL2Z2A635AB It’s a 2001 explorer RHD right side. It should be about 51” which is about 3” longer than stock. They fit great on explorer or zj disk brake setups. Should fit the kj disk swaps too for those running an 8.25. -
There are. The best I’ve used so far is a pair of explorer cables. You need two of either the left or right sides. I don’t recall which ones but someone should have the answer. KJ liberty cables work but are far too long for an MJ. -
Wanting to put a new ax15 transmission in
ghetdjc320 replied to InTacosWeTrust's topic in MJ Tech: Modification and Repairs
Novak will dril the XJ tcase pattern for you. -
another coil spring question
ghetdjc320 replied to jamespwsullivan's topic in MJ Tech: Modification and Repairs
Shocks are your likely issue unless you are bottoming out your springs against the bump stops. -
Power Steering Pump Replacement
ghetdjc320 replied to RiversideMJ's topic in MJ Tech: Modification and Repairs
The only tip I’d recommend is bleed out the power steering system thoroughly to remove any trapped air. Once you have the new pump and lines installed, remove the draglink from the pitman arm, fill the reservoir with a good quality, pure ps fluid (with no stop leak or friction modifiers), and move the steering wheel back and forth from lock to lock about 50 times in each direction. Do this ant a steady pace, not too fast or slow but about the same speed you’d use when turning a corner. Occasionally check the fluid level while doing this as you don’t want to run out, but otherwise leave the cap on when doing this to keep the fluid from spilling. Then let it set for a few hours (preferably even overnight if time permits), check fluid level again and move the wheel from lock to lock another 10 times. Check fluid level and, if at the right level, reconnect and start it up. -
Rough country steering stabilizer.
ghetdjc320 replied to 90comanchegirl's topic in MJ Tech: Modification and Repairs
No skyjacker, Rusty’s, rough country are in the same category imo. -
Dana 30 help & spartan locker talk
ghetdjc320 replied to TheMaddTitan13's topic in MJ Tech: Modification and Repairs
EAS25875 is the size I came up with. Just make sure your axle tube ID and axle shaft OD at the seal location is correct. https://sealsit.com/product/economy-axle-seal/ Seriously, last seals you’ll ever need to buy and way easier to install. Just make sure to use the proper sealant (mega black or “the right stuff”) and make sure the seal surface is nice and clean. No trying to tap in some little tin seal anymore. -
I never tried the Spartan but had the Aussie locker for some time in my YJ. It also did great. I agree that front locker is nice if you’re just doing one lunchbox style locker. The Aussie was pretty smooth though with no clicking or popping when not in 4wd. As for the axle seal, did you swap in a single piece axle shaft? If so, the axle shaft is machined for the seal near the housing on the passenger side of the carrier. However, the CAD axles didn’t machine this spot for a seal. The seal referenced above should work but it is finicky getting it to sit in the bore properly. If you want a surefire way to seal it so it won’t leak again, use a seals-it economy axle seal. I can’t remember the exact size but basically the seals-it seal is a fat, self-aligning seal that greatly simplifies installation and provides a far more reliable seal than those dinky tin metal seals. I’ll see if I can find the one that fits the D30. -
Steering box recommendations?
ghetdjc320 replied to Warren99's topic in MJ Tech: Modification and Repairs
Consider this though, I have gone through literally a dozen steering boxes over the years. Junkyard OE, Lares, Redhead, and all other manner of rebuilt boxes from the parts stores. I can tell you, it's like trying to win the lottery with those rebuilt crap boxes. Best case scenario, I got about 6 months out of a rebuilt Lares box from O'reillys. At some point, your time surely has to be worth more than the cost of a new PSC box. I know PSC advertises it as their "big tire" box, but it works with smaller tire sizes exceptionally well. PSC has also rebuilt boxes for XJ's and I did run one of those successfully. At least for me, this truly has been one of those "cry once" scenarios. I simply do not believe that a steering box can be correctly rebuilt if they re-use or try to rebuild the valve circuit at all. I think they all use some cheap aftermarket parts kit that just doesn’t work. Bearings and seals, sure. But not the valve circuit. -
PSC big bore box. I’ve been down this rabbit hole far too many times. A new psc box is the way to go -
Pinging under load need help
ghetdjc320 replied to ja_racing's topic in MJ Tech: Modification and Repairs
Interesting, one more question: have you always ran it on the same Renix system? And is it the 89-90 or the earlier ECU? -
Has it always has this pinging issue since it was built or is this a new issue? -
Fuel Pump Ballast Resistor Upgrade
ghetdjc320 replied to HOrnbrod's topic in MJ Tech: DIY Projects and Write-Ups
You can still get a stock style replacement https://www.summitracing.com/parts/cwa-33000682 It doesn’t have the ring terminals as the one posted here but will function the same -
Did you degree in the camshaft using an adjustable timing set? -
Do you happen to know what your quench distance is? Low comp strokers have had these issues before. Has the cam timing been adjusted at all? And when you say stock cam, is it an oe renix cam? What’s your actual stroker recipe/combo? -
It could also be that it’s starving for fuel when warm. Seen this happen in many older efi systems. Try adding a bit of gas to the TB and see if it fires up
Keep in mind that the fuel tables will typically provide less fuel when starting up while warm and not more fuel.
Adding AC, need details for Dealer AC harness
ghetdjc320 replied to Kedosp's topic in MJ Tech: Modification and Repairs
The diode is like a one way check valve for the AC clutch power. It should be located inline near the AC clutch. Its purpose is to prevent the clutch from back feeding electrical current when the clutch is cycled off. I've run without them before in an MJ ac system but they are good insurance and should be installed. The diode should have a symbol of some sort indicating the direction of current flow. Again, just think of this as a check valve -
Windshield Glass Replacement
ghetdjc320 replied to kriswinner's topic in MJ Tech: Modification and Repairs
I had safelite replace the glass in my MJ several years ago. I just told the exactly what it was (91 MJ). They installed the 97+ glass and seal by default.
