Just got done re-checking temps. Laser temp gun showed the upper rad hose pressurizing and getting hot at 205-208 degrees at the thermostat housing. Temps cooled to about 196 as the thermostat opened but then climbed to 228. I pulled the temp sensor plug which allowed the auxillary fan to kick on. Letting that run gets the temp down to about 203 at the housing. Sensor at rear of head reads about same as well but gauge reads 220-225 so the gauge appears off. However, if the aux fan isn't running, it shoots back up to close to 230 or so. This is all at idle in the garage. I'm going to replace both temp sensors but I still think its going to run hot and require the aux fan to be on a lot. Any thoughts based on this new info? It's a newer radiator, clean with no blockages in the fins. Temp difference between upper rad hose and lower is about 35-40 degrees so cooling.
To answer a previous question, no A/C at this time.
