JeepSchmidt O'Guinness
2123 profile views
JeepSchmidt O'Guinness's Achievements
Comanche Aficionado
Comanche Aficionado (4/11)
  1. Conroe / woodlands area of Montgomery County Tx here; aside from flippers, mechanics, and owners of renix / OBD1 era jeeps... The mj doesn't raise too many eyebrows. Though I had a funny interaction when getting it title'd & reg'd, clerk said jeep doesn't make trucks. I even read a post on here that their clerk said the same thing. My response was I'll bet yeah the taxes & fees that jeep does. Even went as far as pointing out that it was the third character in the VIN that legally distinguished it from suv's. IJ7 vs IJ4
  2. Had one fail on my 95 xj at about 45mph on a HW once. Engine just died. It was before I knew what any symptoms / diag procedures were. So not sure if the cps failed or just backed the bolts out. This was back when the cps was still dealer available, and a new cps fixed the no crank condition.
  3. Does anything look amiss regarding fuel pump relay, auto shut off relay, fuel pump ballast relay (not sure if renix eletrical even has that relay) or the c101 connector at the fire wall. Does the ground for the fuel pump located behind the tail light look secure/clean? My experience with intermittent issues is normally wiring not being secured...
  4. Didn't see it suggested yet, make sure ya have all the air out of the cooling system to address the overheating. But comp/leakdown test are wise to make sure the overheating haven't caused head/piston damage.
  5. If your oem 16gal had three straps the 23 gal should fit inplace without issue. Shortwheelbase used a smaller 16gal tank with only two straps that don't match the placemen of the 23gal long wheel base.
  6. So the ecm has fault code 54, sync signal. Checked grounds and 8volt supply are good. Rotated the the crank pully by hand and the sensor shows 5v when the pulse ring engages the sync pick up and 0v when leaving the pick up. But when cranking, it stays at a constant 5v using analogue meter. I decided to upgrade to the 94+ dizzy to avoid punching the ring pin and removing dizzy gear just to replace the sensor. Issue with the aftermarket 94+ is the housing doesn't line up with the hold down bolt. Yes its a china made O'Reilly's pos. Does anybody know of a model that is clocked correctly? Searched local pnp's but nothing near me. Do I chance a reman and hope its clocked correctly by said underpaid worker? Any advice would be greatly appreciated.
  7. Even the greys have to air down every once in a while. And whats with the saucer shark?
  8. The connecting hose from pump to feed pipe in the tank is notorious for liquifying if it's not a submersable grade line. Basically it won't stay connencted / hold pressure. Pull the pump assembly and go from there.
  9. 1990 JEEP COMANCHE Color: Other Stock #: 1190-44274 VIN: 1J7FT66L5LL247083 Available: 11/24/2023
  10. www.lkqpickyourpart.com 1990 JEEP COMANCHE Color: Other Stock #: 1190-44274 VIN: 1J7FT66L5LL247083 Available: 11/24/2023 I6 manual SWB with eliminator rims, swivel vent window, bucket seats. Might be an acutall eliminator trim package.
  11. I've never been a fan of matching interior/extior color, my ocd kicks in because it's never a perfect duplication. Other then that I think your tan / black scheme should look good.
  12. What color interior are ya putting in?
  13. But that's at least an 18v battery, better add another 50 ft-lbs ...
