jeeptec1
Everything posted by jeeptec1
Are you missing the lines all together or are they failed. I have an 88 MJ and my line from compressor to condenser was blown open. I had my local NAPA build me one. Used the original as a guide. Also you may have to go junk yard hunting . Sent from my iPad using Tapatalk
All my early MJ,s and XJ,s pre 91 use the oval key for door locks, glove box tail gate. Square for ignition. They used GM locks and keys. Chrysler owned Jeep staring in 87 but the Chrysler changes did happen til 91. Sent from my iPad using Tapatalk
Both axles are good axles. The 44 is non c clip the ring gear is about 8.5 diameter. There is a whole lot more support/aftermarket parts available for the 44. The 8 1/4 is what it is. It is a c clip type. Break an axle out it come. 2 spline types. 96 and earlier is 27 spline. 97 and later 29 spline. The pinion shaft is larger on the 8 1/4 than the 44. Aftermarket support is limited. Either one will make a good axle. If your running 33 inch tires i would go 4.56 if you use the Renix fuel injection system. I If you use the later OBD2 efi 96 and later I’d go 4.10’s. The later efi makes more power that early efi. Sent from my iPad using Tapatalk
start date for using the AX-15
jeeptec1 replied to Pete M's topic in MJ Tech: Modification and Repairs
I had an 89 MJ built late 88 it still had the Peogot trans. The build sheet stated Heavy duty transmission. Sent from my iPhone using Tapatalk -
What differences dana 30 99 and newer?
jeeptec1 replied to 1989 comanche mj's topic in MJ Tech: Modification and Repairs
The brakes and hubs I believe are different. The axle shafts are different if one has abs and one doesn’t. If the 92 is non abs it will have the small joints in the axle. If it the 92 has abs it will have the larger joints. The later axle will have the large unjoints. I’m don’t remember if the 99 XJ had the low pinion front diff of not. I know 2000 and 01 definitely had low pinion front diff. If it is a high pinion swap it in. Just remember to get parts for that axle by what it came out of. Oh if it is high pinion the ring and pinion swap over. If it is low pinion they are totally different. Sent from my iPad using Tapatalk -
89 MJ 5spd ax-15 start lockout?
jeeptec1 replied to Andy in Pa's topic in MJ Tech: Modification and Repairs
My 89 never did Sent from my iPhone using Tapatalk -
Yes coolant flows through the valve when heater is on. And is bypassed externally but will always have coolant in it. It will leak under pressure when running. Will drip when off. Sent from my iPhone using Tapatalk
That is the heater control valve leaking. I have replaced many of those. They become brittle from constant heating and cooling of the engine. Easy to replace. Sent from my iPad using Tapatalk
80w 90 is factory fill you can substitute 75w-90 for easier cold weather shifting. There is a fill plug on the side of the trans. I believe it’s a 15/16 plug. Get one of those hand pumps that screw onto the bottle. Sent from my iPhone using Tapatalk
Correct 87 to 90. But wasn’t stated what engine either. Sent from my iPhone using Tapatalk
There are a bunch on eBay. You didn’t state what year or engine. I used 88 Comanche. 4.0 Sent from my iPhone using Tapatalk
88 Comanche 4 inch lift. Right now I have the stock rims 31/10.50/15 with 1.5 spacers. I’m going to 32/11.50/15 tires but I want to go to steel rims 15x8 but I can’t remember if is 3.75 back spacing or 3.5 back spacing. And yes i would take the spacers off. Sent from my iPhone using Tapatalk
Anyone know if the YJ Wrangler steering linkage fit an MJ/XJ. YJ has T style steering MJ/XJ have Y style. I know there are upgrade kits that converter Y to T style. Sent from my iPad using Tapatalk
Should be straight forward. Are they both 4wheelers drive? The Dana 44 shaft may be a little shorter. The Dana 44 housing should be longer Sent from my iPhone using Tapatalk
A/c control head identifying
jeeptec1 replied to jeeptec1's topic in MJ Tech: Modification and Repairs
The a/c compressor should come on in all a/c modes and defrost. That’s what all my Cherokee’s did with factory a/c Sent from my iPhone using Tapatalk -
Does your control head turn on the a/c compressor when the heater only is on? I’m fighting a poor heat problem. I did all the basic stuff new thermostat, flushed heater core. It helped but if I disconnect the a/c compressor I have good heat. Reconnect heat goes back to warm. Sent from my iPad using Tapatalk -
Can anyone tell me what company made this. My 88 Comanche has add on a/c I don’t believe this a old Jeep kit. All the ones I’ve seen have Max a/c and then a/c Sent from my iPad using Tapatalk
3 inch lift and 31’s future plans 4.5 lift soon. when the 31’s wear out then 33’s with cut out flares. Sent from my iPad using Tapatalk
Mine is 100% stock at moment. Early MJ with the small drag link and tie rod at pitman arm. Sent from my iPad using Tapatalk
Has anyone used or installed the rough country HD steering kit? Sent from my iPad using Tapatalk
Thinking of rear axle options
jeeptec1 replied to coolwind57's topic in MJ Tech: Modification and Repairs
I did on one of my Comanche’s is use the later 8 1/4 out of a Cherokee. Yes I did have to cut the spring purches and all that. The axle was cheap $100.00 bucks drum to drum with 3.55. That was about 12 years ago. I threw in some 4.10 gears and called it a day. Oh and welded the spiders because I didn’t care Sent from my iPhone using Tapatalk -
88 Comanche long bed. Ive lifted my Comanche with some used TJ 4 inch springs which gave me exactly 3 inches in the front. I’m want to go up to 3 3/4 no more than 4. My question is do I install 3/4 inch spacers or ditch the factory worn upper spring pads replace with a 1 3/4 spacer? Thanks Sent from my iPhone using Tapatalk
Externally regulated altenator on '90 Comanche
jeeptec1 replied to atxg3's topic in MJ Tech: Modification and Repairs
If your buddy is still running the 90 Comanche wiring and computer use an alternator for a 90 Comanche. The 87 to 90 XJ and MJ use a alternator with an internal regulator. The 91-92 MJ and 91 and Later XJ use an external regular which is built into the PCM. Does the vehicle run? Sent from my iPhone using Tapatalk -
96 and later went to that style. Sent from my iPhone using Tapatalk
95 XJ is OBD 1. It only has 1 o2 sensor. It is before the cat converter. If your vehicle has 2 sensors 1 before the cat and 1 in or after the cat. Please look at the emissions label under the hood it will state 1996 model year. 1995 pcm is 1 large connector. 1996 pcm has 3 small connectors. Sent from my iPhone using Tapatalk
