Dave Stark
Everything posted by Dave Stark
  1. A piston engine will actually run on very low pressure (70-80PSI), if with very low power. The most important thing to look for is difference in compression between cylinders, if you have a difference of more than 10-15PSI on any of the cylinders then you have a problem & it may be time for a rebuild. You'll be doing good if you in the neighborhood of 140 - 150 PSI on all cylinders. ~Dave :banana:
  2. Very sharp truck! :bowdown: :bowdown: :bowdown: That doesn't look like the original interior (only because it is so clean), do you know if its been replaced?? :cheers:
  3. If i lived there i would have to buy one of these: Image Not Found :USAflag: :banana: :banana: :banana: :banana: :USAflag:
  4. Welcome, I'll be moving to Dallas next month, I'm doing massive work to mine & will probably have some extra parts so make sure to post up... :wavey:
  5. :agree: Mine were so bad on Drippy that it was metal on metal. I went through http://www.energysuspensionparts.com & got the bushings for the entire truck for around $100. Definitely worth it. ;)
  6. :cheers: :cheers: Guinness for me. :cheers: :cheers:
  7. I've got the new style doors now off the same C4C '98 XJ & thought that since I've already taken so much from this site that i should give back a (very) little. Hopefully this will help some others wanting upgrade their doors get it done faster. The hinges are a direct bolt up, so this write up is for the catch: After you've bolted up the new doors remove the old style catch & use a marker to place a line where the new one will be centered. Next remove the seat belt & dust guard. Now you will be able to reach the back side of the nut plate for the old catch. Many of you will not like this, but with very light pressure you can break the spot weld without damaging the surrounding area. After that you can pull the old nut plate out from behind, this is what you will come up with: Now go to your old doors & pull the bottom nut plate. You will be able to reach it through the speaker hole. This one is held on with tabs that can be bent with relative ease. Now, in order for this to work you will have to take a 3/8 drill bit & oversize the holes. This is a very small difference from the original hole size & will not affect the bracket in the least. Next, make marks on the door jam where you want the new catch, i placed mine as far toward the inside of the truck as possible. Using a 1/2" bit drill the holes so that you will be able to adjust the bracket. I used a Dremmel tool with a reamer bit on the top hole. From here it is just a matter of holding the nut plate from the back & threading in the bolts on the front. (Note that the inside edge of the catch is against the curve on the door jam.) Here is the finished product. I like the touch with the sad face because the XJ was C4C. All in all it took about half an hour per side & it turned out really well.
  8. I'm thinking there's an o'ring in there. ;) Lots of heat + gasoline= demolished o'rings even with minimal handling, especially after 20+ years :yes:
  9. Very glad to see that its off the blocks :cheers: I'm thinking flatbed?? :dunno:
  10. Wired the lights for my new header pannel. ;)
  11. Dave Stark
    sanders
    This will most likely do what you need: http://www.harborfreight.com/cpi/ctaf/d ... mber=95020
  12. Installed latch catcher so the doors i got from a '98 XJ will close properly. :brows:
  13. That's such a shame, still just a kid. They will get what they deserve.
  14. I replaced my radiator in the parking lot of an apartment complex. I rebuilt my entire VW beetle at various places (grocery stores, Walmart, parts stores, roadside), almost never had to do any work at home :clapping: Only had 3 fires in the thing too :ack:
  15. In addition to the laundry off the winch cable there has to be at least one dead car in the front yard, preferably on blocks. :D
  16. Fuddled with mounting brackets for some buckets i got out of a '98 XJ. It's much more difficult than i thought it would be, sigh. :roll:
  17. What you need is to find a rust free XJ shell & start transferring sheet mettle. Don't give up. :popcorn:
  18. Looks like you got yourself a stucco truck :thumbsup:
  19. And I'm spending all this time & money fixing up mine :fs1: What a shame :wall:
  20. Lake Tahoe is not that far from Sacramento. JW JEEP will most certainly have what you need :typing:
  21. Dave Stark
    Dark Suckers
    At first i thought this was going to be some really elaborate racial joke. It's sad really because if this was presented one hundred years ago, it would probably be a valid scientific theory. :doh:
  22. Save that hardware, you'll be surprised at how often it will come in handy :smart: PROTO tools??
  23. What about Mouse Milk? :bowdown: ATF & Acetone? Sounds dangerous :eek:
  24. Gotta love how the salt builds up on everything there. BTW, where's your shock?
  25. Does the FSM come with a troubleshooting guide? The Chilton manual is rather....Lacking? :nuts: I also have a '91 & would love to have a copy as well...
