Jackrabbit41
Everything posted by Jackrabbit41
  1. Ok thanks. I'm probably going to wait to do the elimination because I need my truck running by tomorrow. Also, if I do that elimination will that leave me in 4wd? How does it shift into 4wd anymore? Does it hair use the linkage? And should I pull out that aftermarket 4wd shifter that is pictured earlier?
  2. the rainbow colored lines look like electrical linesand nothing like vacuum but I'm not sure. And do I need to that elimination thing? What if I left it? And when you talked about that cable thing, that has nothing to do with that aftermarket 4wd shifter thing? I'm still confused on some stuff.
  3. So i cut off all the plugs on the cherokee and am going to wire them back in but i am confused on some things. like the breather hoses, there is only 1 on the new t case. should i just ditch the others from the comanche? maybe theres more but i couldn't find any more. and then theres this 3 wire plug. on the comanche it was 4 wires. what wire do i leave out? and what are the plugs on the t case for? this is the old t case from the comanche where the plug goes into [/url]">http:// here is the old plug with the 4 wires, while the new one has only 3 [/url]">http:// here's a pic of both the plugs that Id like to know what they do. the closet one is the plug that i was talking about above. this is the cherokees t case. [/url]">http:// below is a pic of an after market 4x4 shifter. The PO put it in, IDK why. to engage 4wd i had to pull the normal lever and then pull out this button thing [/url]">http:// is this thing part of that shifter? on the old t case, there was a port where it screwed into. [/url]">http:// thanks all! hopefully ill have it in tonight.
  4. So I'm in the middle of the swap right now and have two problems. First one is the electrical connections on the AX 15 look a lot different than the ones on my Comanche. Do I need to wire new plugs? Also I got a new slave cylinder and master but I could not get the new hydraulic lines is it OK to use the old ones? I'll swap it out once napa gets it but they don't have any in stock for a while
  5. How do I know if my cherokee is non CAD?
  6. So I got everything in, now I need to start pulling the hydraulic line and clutch pedal off the Cherokee. One thing I noticed is that the Comanche electrical plugs much different then the cherokee electrical plugs. What do I do about that ?
  7. No for both but I asked a mechanic friend and he just said to pack it with grease. I bought about the flywheel thing but mine is in perfect condition so I just left it alone but maybe I should.
  8. Any advice on how to tighten bolts without having it spin?
  9. What flywheel do I use? Cherokee or Comanche?
  10. today is monday, and ever since friday I've been doing the ax15 swap. its been going well, no issues until yesterday, sunday, when we found out about the PB and the different size. today, monday, i went to a machine shop and had a new brass bushing made for 35$, which was sweet and only took 30 mins. hopefully i can have the clutch and flywheel back on in the next hour or so and then start putting her back up in the comanche. Also, do all of the comanche plugs, and breathers fit on the ax15? or do i need to do some wiring?. thanks! I also got to borrow a tranny jack from work, Imco Construction, and that has been really helpful so far. [/url]">http:// new brass bushing [/url]">http:// [/url]">http:// had to get a new impact wrench. really handy because its small. 450 foot pounds [/url]">http:// pugeout removal [/url]">http:// all cleaned up [/url]">http:// flexing out on some stuff at work. had the quad in the back too so it was a little tippy. [/url]">http:// [/url]">http://http://s1148.photobucket.com/user/Jackrabbit123/media/image1_zpsdnoiuyjw.jpeg.html'>
  11. I'm getting a brass bushing made today. Hopefully I'll have the tranny in tomorrow
  12. I don't know a whole lot but if you have a long bed you don't need an sye unless you got like 10 inches of lift
  13. What's the advantage to a non CAD?
  14. Also, should j use the comanche cross member or the Cherokee one? I know I need to do some modifications which isn't a problem just wondering what's involved
  15. I'm headed to a machine shop in the morning to get a bronze bushing made
  16. It just seems like somebody else would've had this problem. I can't be the only one
  17. Is it a bad sign of no one responds? Lol. Seems like somebody's run into this problem with all the ax15 swaps out there
  18. So i pulled it out and the sleeve around it. the new PB for the ax15 fits into the hole but not tight. you can easily push it in hand tight. what should i do? first picture: top is new ax15 PB bottom is sleeve and old PB [/url]">http:// second picture: top is new ax15 PB both is old PB on top of Sleeve [/url]"> http://http://s1148.photobucket.com/user/Jackrabbit123/media/IMG_4043_zps8b8ncdai.jpg.html'>
  19. Rent a puller (slide hammer type) from Auto Zone, pops right out So will that ax15 bearing fit right in?
  20. So I've been doing the ax15 swap and I'm working on the rear main seal and pilot bearing right now. I have the oil pan out only because the gasket was leaking so i thought i should replace it, plus it makes it easier with the tranny out to. My question is how do i replace the Rear main seal and the pilot bearing. The seal napa gave me looks way different then the one i puled out and the one i pulled out is a 2 piece while the napa one is a one piece. Ive watched multiple videos on the RMS, but still confused. I have the pilot bearing that fits the ax15 output shaft but how do i get the old pugeuot one out and put in the new ax15 one? the ax15 PB looks bigger too. here's some pics. I'm hoping to be done with this in 2 days so as much advice as you can give id love, thanks! [/url]">http:// [/url]">http:// [/url]">http:// Here is the new ax15 PB compared to the one thats still in. the bearing came with a little plastic tool thing, what is that? [/url]">http://http://s1148.photobucket.com/user/Jackrabbit123/media/IMG_4039_zpsytpj4dlf.jpg.html'>
  21. I love that side exhaust, how'd you do that?
  22. I always put a little grease on bearings before I put them in, but do I need to do any more then that?
  23. Never heard of that before, what does that do?
  24. Thanks and for the pilot bearing, should I get one that fits the cherokee I have or one for my comanche? I already have one that came with the clutch but I'm not sure what to use. I've heard different things in what fits
