Jackrabbit41
Everything posted by Jackrabbit41
  1. Spent most of the day fixing my wiring so it looks better. I put 3/8s and 1/4inch split loom around most of my accessory wires and tomorrow I'm going to install my new toggle switches onto my switch panel and wire them up.
  2. I'm going to drill and tap a hole for this and put a rubber hose up into the engine bay. [/url]">http://http://s1148.photobucket.com/user/Jackrabbit123/media/Mobile%20Uploads/image_zpsuculhh49.jpeg.html'> I might go back and get a small one though because I'm not sure that washer will fit on the housing
  3. So when I was welding on my homemade"truss" some how or another a bead ended up in the vent hole in my HP dana 30. The shop that put 4.10s in it noticed that and told me to put a pressure control valve mounted backwards on the diff cover so that the pressure can escape because it's a live axle. How would I go about doing this the best way? Or what should I do? Thanks
  4. True but a bad slave can cause the master to have a small slow leak around the fuse box . I was told that by a local mechanic becuase right after I put in a brand new master, it started oozing
  5. Finally got the HP30 back. Turns out they didn't have my number so that's why they didn't call. I should've called earlier but whatever
  6. I had the same thing and it was my slave. If you replace one without the other one of them fails soon after due to different pressures. Make sure it doesn't get on your fuse box! If you have an internal good luck.
  7. I just watched a video of your rig on some random youtube channel. pretty cool and ya I'm planning on getting a roll of some of that insulator type plastic stuff and that'll hopefully make it look cleaner too.
  8. Another funny/random story for y'all: Up here in Bellingham, Wa there is lots of Canadians that come down from Vancouver to hang out and most of them are terrible drivers (no offense to any Canadians out there!) and when i was coming home from practicing lacrosse with my friends I saw a car on the train tracks. I didn't stop at first then i though that i could winch them off, so i turned around and hooked my strap to there rear left A Arm. It was a Toyota corolla or something so i didn't have much options. Once I started pulling with my 8k winch it came right off the tracks and onto the street. It was fun plus they paid me 50$ so i was stoked. More money for the jeep! The cop told me that this happens all the time so maybe ill get to do it again. Sadly i didn't get any pictures.
  9. I saw you out driving on the guide yesterday. The cage Looks really good
  10. I'm planning on making a rear bumper just like yours. Are the bed side guards tied into the frame or are they just hanging off the bumper?
  11. I also need to figure out my cup holder situation. What should i put in the bottom to keep heat/hold stuff?
  12. More progress on the center console. Next i need to rewire my train horn and lights because I half assed the job back a few months ago when I installed them and my wiring is really messy. I also am going to build an extension that comes off and converse the 4wd shifter like the factory plastic one did. I left room for more switches in the cute like more lights and hopefully lockers next summer. Oh and maybe a winch in their too but I'm fine with the controller thing. [/url]">http:// [/url]">http:// [/url]">http:// [/url]">http:// [/url]">http:// [/url]">http://http://s1148.photobucket.com/user/Jackrabbit123/media/image6_zpsroqs4tlp.jpeg.html'>
  13. I've never really out any time into following it so I guess I better do that. Never heard of that adjustable rpm thing before and I'm pretty sure that's not it.
  14. So this red "button" thing has always had me curious. The PO told me he put it in. Once you pull the lever for 4wd, you also have to pull out this button thing. Do I need this any more? I put in the ax15 and np231 and I'm soon to have a HP30. Also I'm going to get the novak case shifter. here's some pics of it. [/url]">http:// [/url]">http://http://s1148.photobucket.com/user/Jackrabbit123/media/image5_zpspotz3y5k.jpeg.html'>
  15. So I put in the injectors and it's running good. I don't notice much of a throttle response increase, but we shall see about the better Mileage. I also start making me center console and switch panel. [/url]">http:// Hard to tell but the injector holes were nasty. To clean them, I scraped out the inside with one hand and held a shop vac up to the hole with the other hand. This way the gunk wouldn't fall down into the cylinders. I then dipped quetips into gasoline and wiped out the inside. It worked really well and the insides were shinny clean. [/url]">http:// I had a hard time getting the new ones in so i dipped them in gasoline and that made it a little easier to slide them in the fuel rail and the cylinders. [/url]">http:// [/url]">http:// Now for my center console build. Its Saturday and I got about 1/3 of the way done. I build half of it out of cardboard first and then made the first half out of steel. I need to get the right size hole saw for the cup holders and I can't decide what the base of the cupholders should be. Like the part down. [/url]">http:// [/url]">http:// [/url]">http:// First steel piece. I didn't get as many pics as I thought. Ill put some more on tomorrow. [/url]">http://http://s1148.photobucket.com/user/Jackrabbit123/media/image8_zps4tr6t8wx.jpeg.html'>
  16. So today while I was sitting in AP physics I came up with the idea off build a center console out of some 16 gauge steel for my truck and put a switch panel in. I have a train horn and some lights that I already have installed and they have switches but I'm going to redo my wiring because its so messy and then put both those accessories on some toggle switches. I got some shine aluminum for the switch panel too. My injectors came today and they look great other then the fact that they look used. Dirty Jeep Guy said that he tested them, so maybe thats why. here's some pictures: [/url]">http:// [/url]">http:// What do y'all think about these injectors? [/url]">http://http://s1148.photobucket.com/user/Jackrabbit123/media/IMG_4588_zpsdpv4doy0.jpg.html'>
  17. Did you ever get your axle back yet? No. They were supposed to call me last Friday when it was done but they never called. I'm going to go there today and see what's up
  18. How come the rim is chrome in one pic and black in the other?
  19. Finally ordered a headliner. I'm missing everything so it was 225$ From sms headliners. /edit 10/15 Also got some Bosch injectors coming
  20. Thanks! And do you know how many bulbs there are off the top of your head? No problem if not.
  21. Anybody know of any LEDs for the dash lights? I've looked all over but can't find any.
  22. I love those gauges. What gauges and LEDs are those?
  23. I'm having the exact same problem. I just put in new rms, and oil pan gasket and it looks like my rms is leaking already. I was told it could be my oil filter adapter gasket but j fixed that and it's still leaking.
