2
Everything posted by Fernando87mj
the time has come , my heaters leaking . To those who have replaced their heater cores , which brand did you guys use and what were the results ? Would you buy again ? My heater cores leaking and I don't want to do the job twice. looking on rock auto theirs a spectra brand heater but some reviews appear to not be so good. I also saw this heater core which appears to be copper and I was curious if any of you guys have used it 1987 jeep Comanche 4.0 BA 10/5 factory a/c
Went out to the mountains today and everything went well the drive was 2 hours long and the truck ran really good and didn't leave me stranded but when I got home I found this nice little surprise, heater core replacement is in the future
Need New Ball Joints?
Fernando87mj replied to Arch_Stanton's topic in MJ Tech: Modification and Repairs
Quick question, Do you know if these Will fit my 2wd Comanche ? -
Most I've done on a empty stretch of highway , ride wasn't as bad but the wind noise was crazy Tires are 235-75-r15
I wish I could find a speedometer that matches mine with the trip odometer!! I see you have an 87, mine is a 91, so they don't interchange. All my searching indicates they don't exist. To get the trip odometer for 1991/92 one has to go to the complete gauge cluster with the red numbers instead of blue.Yup , happy mines came with it , but I like the look of the red gauges more, I could be wrong but I think it might be part of the tow package since mines is a base but has the aux fan , d44 track lok read end,tachometer and the 4.0 , Also I think it might be an early 87 due to the hood prop rod being on the radiator support .......... Got a little off topic there lol
Almost there....
Is it bad if the track bar clunks when moved ? I'm having steering shimmy going 35-45 and I'm trying to look for the issue , could it be loose or is it just bad ? https://vimeo.com/151254837 * update got under and tried to tighten everything and everything appears to be on properly , under inspection I also noticed the sway bar bushing is cracked and it appears to be shrunken ?
VICTORY ! I finally fixed my low idle issue New iac from rock auto Cleaned throttle body with old toothbrush and throttle body cleaner Idle: Before After It's really odd hearing the engine run at the proper Rpms , I've never had the engine run like this but I'm glad I got the issue resolved ! Also replaced the belt After research the Goodyear gator back belt now has been renamed here's the new PN/ name
Help comanche not starting!!!!
Fernando87mj replied to chrisquested's topic in MJ Tech: Modification and Repairs
Check to see if the fuel ballast resistor is cracked or broken , jumper those two wires together and see if the jeep starts -
88 4.0l to a ????? 4.0l
Fernando87mj replied to jeepbtf's topic in MJ Tech: Modification and Repairs
87-90 will be the same -
Woodgrain dash question
Fernando87mj replied to schardein's topic in MJ Tech: Modification and Repairs
got any pics of the door panels ? -
What do Deloreans and Comanches have in common?
Fernando87mj replied to fiatslug87's topic in The Pub
only if the flux capacitor is switched on and when you have 1.21 gigawatts of electricity -
New member to the family , a 2014 Jeep Compass with the 6 speed , I know many might not like them , but honestly it's feels and drives good and it gets good gas mileage ,and I like the looks , I like it !
Thanks! And I use the tapatalk app on my phone
Yup , and thanks a lot , your Comanche looks great !
Really Small update , it's been a while but the jeep is being DD to school and it's been performing great ,the idle is a bit low but I'm positive it's the iac , the cat and exhaust has been installed , and exhaust rattle is now gone . It's a flow master cat with a walker sound fx , sounds pretty stockish but with a slightly deeper tone , also took her a bit off-road , pretty easy trail since its 2wd with a lsd Poser shot Also had the white lettering flipped on the tires , really happy with the look Later on I plan to instal new Carpet and insulation ,the old vinyl is a mess but currently gets covered with a mat interior shot for like the 1000x time because why not.
^post pics when installed :) thinking of getting blue LEDs my self
Fuel pressure was 8 psi , took out the sending unite and somehow the hose slipped off ,bought a new clamp and put the hose back on and all is good . Bought a new lock ring and seal and put it back together and the damn thing is leaking again when the tank has more than half :( searched up cc and saw that the p/n for a tank o ring from mopar is 5300 0575 is that correct ? Will it fit my swb gas tank ?
Decided to go ahead and see how the tps and CPs were doing Tps Cps I'm gonna go ahead and I test the fuel pressure tomorrow and see what I get , I replaced the fuel pump with a carter from napa and a fuel filter with a wix 11 months ago , it can't hurt to eliminate the possibility of a bad fuel pump
