Elijah808
1 Follower
Elijah808's Achievements
Can Spell Comanche
Can Spell Comanche (2/11)
  1. http://www.4wd.com/Jeep-Brakes-and-Steering/Super-Pump.aspx?t_c=65&t_s=430&t_pt=7856&t_pn=AGR812257#overview_Container Anyone heard or has used one of these power steering pumps?
  2. USA Standard Gear? Good company shopping for gears now.
  3. Can I continue to run my stock tire size at 4.88? Or will it be to hard on my motor?
  4. Don't plan on really using this truck on the freeway to commute
  5. So ax4 is all I really need?
  6. Right on! Thanks guys gonna start hunting for an ax5! Now for gears where's the best place to order from? Any brands that are better then others?
  7. Will a Dana 30 be deep enough for 4.88? Any suggestions for brands? Not sure what to buy
  8. What trans would you recommend? Is it a direct swap?
  9. Getting ready to throw a 8.25 Chrysler with a locker in the rear. It's coming off a Cherokee that was stock. Not sure what the best gear ratio to go with. I want to be able to run 35s with ease. Any advice would be great!
  10. I have a 87 pioneer 2.5l 4speed trans. I was told they come stock with 4.10s. Planning on running 35s. Not sure what gear ratio will work best. Not trying to jack this thread2.5s with a 4 speed came with 3.55s2.5s with the 5 speed came with 4.10s If your planning 35s are you planning to swap axles? The maximum gear ratio for the Dana 30 is 4.88s This is the gear ratio I was planning for my truck just haven't sent it in for gear install I would like to swap my front axle I have and 8.25 Chrysler in the back. Not sure what my best option is for axlesIt all depends on how you treat your truck...I know a guy with an xj 4.0 still running the Dana 30 and 29 spline 8.25 on 38s with 4.10s he's been running and dd that setup for years and no problems...He babies it for dd duties and beats it off-road...but he does a lot of preventive maitinence for it not to break... I did see that but they came out after I made the purchase and weren't making an option for the amc 20... I plan on beating on my truck this is my first jeep. I used to run only Toyota but everyone does here in Hawaii. I want something different. Anyone done a 1 ton swap
  11. I have a 87 pioneer 2.5l 4speed trans. I was told they come stock with 4.10s. Planning on running 35s. Not sure what gear ratio will work best. Not trying to jack this thread2.5s with a 4 speed came with 3.55s2.5s with the 5 speed came with 4.10s If your planning 35s are you planning to swap axles? The maximum gear ratio for the Dana 30 is 4.88s This is the gear ratio I was planning for my truck just haven't sent it in for gear install I would like to swap my front axle I have and 8.25 Chrysler in the back. Not sure what my best option is for axles
  12. I have a 87 pioneer 2.5l 4speed trans. I was told they come stock with 4.10s. Planning on running 35s. Not sure what gear ratio will work best. Not trying to jack this thread
  13. Right on! Thanks guys! Can't wait to try it this weekend
  14. I'm having this same problem thing whines like crazy. I've hear you can bleed the system but j can't seem to find any nipple.
