Strokermjcomanche
    6
  1. Here is the picture Alexia showed me with the correct location for the floor shifter cable .Image Not Found
  2. Image Not Found Had more made if anyone is interested .
  3. Alright disregard my previous question .
  4. Ok so I made the link , but don't understand how to actually post the pic .
  5. What are you hosting your pics through ? I really need to learn myself too . I am ashamed that I'm that computer illiterate not to be able to .
  6. I agree , but someone might have an Xj that's looking for one .
  7. Overshoot is caused by bad bushings in the wiper transmission . You can buy new bushings at your local parts store in the " help "section . Part# dorman 49447 .
  8. When I swapped the drivetrain into my 89 Comanche (that was manual )from a 95 xj with a floor shifter I had to drill the hole in the firewall for the cable in the location 3-4 inches from the pedal as you described . I used the shift cable that came with the 95 xj there was a thread on this but I can't find it . Alexia had a pic of the firewall somewhere .
  9. Babyblack86 on here has extra parts along with the other members that have the factory diesels . I don't think you'll ever lose money on it unless they want a fortune .
  10. Maine , but I know he goes to Arizona as well . I don't see or talk to him much , but my aunt ( his mom ) just passed and we got to see eachother . When he said A10 I remembered this thread .Image Not Found
  11. Just found out my cousin flys one of these. He is also a instructor .
  12. Anyone else see there is a visor on the white cherokee in the background off to the right .
  13. At least you have the weather going for you CJ. :yes: Lol. The urethane is softer in the heat and is easier to cut through and make damaging the windshield less likely is what I meant . Thanks Don
  14. Butyle should not be used for a windshield , urethane is what is being used now . Flowable silicone is a temporary fix as the rust will allow the window to eventually leak again . Ask your local windshield place if they have a better product for sealing the windshield if you don't want to remove it . The window has a better chance coming out in warm weather if you're going to take it out .
  15. Chainsaw. :rotfl2: Are you sure you'd still be standing after a case ? Might lose a limb in the process lol.
  16. The caliper piston does sit above the rotor slightly as you said they were . The casting numbers on mine are 103707 ,337 and 323 . The part stores should be able to use the casting number to match up to make sure you have the correct calipers . Also check the calipers to make sure the bleeders are at the top of both calipers , I've had several wrong boxed ones .
  17. Your insurance company should go after USAA not you . They have lawyers and that should be part of there job . Do you have receipts of all the parts you had just bought before the accident? Their insurance company (like all others) of course doesn't want to pay money out . In my experience working at a body shop in Ohio the rental not only goes against your claim but they may not pay the full amount if it was above what they pay per day .
  18. Have you switched the turn signal flasher with the 4way flasher ? Also check the connection for the front lighting harness at the air box on the drivers side , may be corroded inside .
  19. You can put a tilt column in from the same year / era Comanche / cherokee .
