6
Project Deja vu
Strokermjcomanche replied to Strokermjcomanche's topic in Member Projects: Other Cool Stuff
Ran out of cut off wheels but the floor pan is fitting nicer than I thought it would . I was trying to have the pan welded in today but other things got in the way . -
Project Deja vu
Thanks Don . I am , about 20 minutes away . -
Project Deja vu
I spent some time on it and did some quick bodywork to make it look better . I went through the Jeep and replaced the brakes , gave it an oil change , scrubbed the interior, put a new exhaust and O2 sensors on it for the next owner (whoever that will be ..) -
Project Deja vu
I picked it up this morning and started to tear it apart because the interior is trashed, the PO used the interior as an ashtray and it has seen better days . I will be putting the Agate interior in and it was included in the purchase price of the Cherokee, I just have to go and pull the parts myself. As mentioned before it's really solid except for one spot ... the passenger front floor . -
Project Deja vu
No you aren't seeing the same Jeep twice, it's almost a carbon copy of my 99 and it's way more solid than it too . -
Project Deja vu
I have been looking for a replacement for it as I have nothing else that will seat more than two people, then I seen an ad for a 98 Cherokee that popped up ..... -
So I have a 99 XJ that I've had about 16 years , originally had 37k miles on it and now it has 142k miles . It has now reached the point that I don't have the desire to fix the extent of rust it has (only to have it come back ) . It looks good in the pictures but not in person ...
https://m.ebay.com/itm/Nut-Strip-Set-Jeep-1984-to-2001-XJ-Cherokee-Crown-Automotive-52001174K/382166833617?epid=139959301&hash=item58faeb19d1%3Ag%3AvHgAAOSwFjNZiLfn&_sop=10&_nkw=cherokee+hitch+nut+strip&_from=R40&rt=nc
The passenger side should have a nut strip installed but the drivers side won't several places sell the strips and they are around $30 a pair
Front Door Trim Panel for Eliminator Edition - MI
Strokermjcomanche replied to 1989 Eliminator's topic in Wanted
If you haven't found one yet I should be able to grab one from a 2 door Cherokee , it'll have the chrome piece but will need to be cut to length -
TRANS fuse keeps blowing.
Strokermjcomanche replied to Knucklehead97's topic in MJ Tech: Modification and Repairs
In the transmission,they can be checked by measuring the ohms at the transmission electronic plug . -
Might have a bad solenoid ( possibly blowing the fuse ?) , mine "shifted " to but was a dog too. I ended up having two bad solenoids out of the 3 in there . -
Black dash is located , got it out of a 86XJ (glove box is trashed) . The rest I'm still on the hunt for ....
Thanks , it's gone now
Manual to Automatic
Strokermjcomanche replied to Comanche_Dee's topic in MJ Tech: Modification and Repairs
I had an 87 2.5 aw4 2wd MJ (also had A/C ) , it ran great down the freeway / downtown/etc nothing wrong with that truck by any means . I fail to see where he posted that he was street racing on the weekends and wanted more power , why can't he do what he wants to his own truck ?????? To the OP , no reason you couldn't be into that swap for $500 , where do you live ? -
Manual to Automatic
Why are you searching for an 86 ? He stated in his first post that he has an 87 . Anyhow , if they have the trans .... they had the truck .... and they have the flexplate etc And I can read mine just fine .... -
Manual to Automatic
Here's A list of 2.5 4x2 transmissions, couldn't see where you live ... http://www.car-part.com/cgi-bin/search.cgi -
Ok so where's the place at ? Do they have a number?
Ok how much ?
Hello I'm in the need of several parts please : easiest first lol: A black dash (non broken with glove box door . Black seatbelts ( bench side) Rear speaker brackets The interior HVAC vacuum harness+switch and electrical harness (with a/c for an 1987 ) Please let me know what you have and price please , I'm located in Youngstown Ohio.
Keep it up Don !! Your mind is going to tell you it wants more cigarettes ,but your body is thanking you for quitting. Be prepared for weight gain , doing anything for that ?
NEW MJ Fuel Sending Units
Strokermjcomanche replied to mrmel2you's topic in MJ Tech: Modification and Repairs
When you are referring to a "sending unit " that is just the fuel gauge sender that you are using . I'm just saying this so no one goes out and thinks that this will be a bolt on affair ( the fuel tank baffles ) . You can purchase an H.O or Renix fuel XJ sending unit and harvest the fuel gauge sender so the gauge will not read backwards. The operating pressure of the renix 2.5 is around 17 PSI and the 4.0 is 31-39 PSI . The Walbro pump has the correct specs although some people say you can run the same in both ... Good write up though ! -
I do
My 87 sportruck
Strokermjcomanche replied to Strokermjcomanche's topic in Member Projects: Your Comanches
The brakes were non existent . Had to replace the wheel cylinders, shoes , hardware , hoses, calipers , rotors , turned the drums , also replaced all 4 shocks and the steering stabilizer Probably going to to end up using these canyon wheels and 31s
