6
the wall of NOS has a new family member :) now with a nos handle!
Strokermjcomanche replied to Pete M's topic in The Pub
One of the harder nos pieces to find for sure . -
There's a whole bunch of WJs in my local yard, got to see what shape and if they're white though .
1999 Cherokee
Strokermjcomanche replied to Strokermjcomanche's topic in Member Projects: Other Cool Stuff
Pm sent -
1999 Cherokee
Not at all , is it worth something to you ? -
1999 Cherokee
Transmission and tcase are in , 4wd shifter /linkage installed as well . Still need to install front axle and locate driveshafts . All the yards around me bend the driveshafts when picking them up with the loader ... aggravating!! -
1999 Cherokee
This is my fifth or sixth time changing leaf springs on an XJ . No videos for me , just getting it done -
1999 Cherokee
Valve cover gasket installed last night . New springs , shocks , sway bar bushings installed today . Easiest leaf spring replacement I've done on an XJ yet , bolts came out with no persuasion. I did have to put new bolts in the upper shock mounts though . -
1999 Cherokee
O'Reillys had them in stock, just had to store transfer them. They were the dorman ones 929-301 . Summit racing is about 40 minutes away from me, they had a Mopar replacement spring for $147 -
1999 Cherokee
It was perfect timing , I was looking elsewhere for parts to convert to 4wd until this happened. -
1999 Cherokee
I'm gonna wait till I'm done with it and make a decision. -
1999 Cherokee
The local pullapart had a wheelbarrow special so I got a transmission/ tcase/shifter /linkage for $80 . I have a front axle but still need to locate both driveshafts. -
1999 Cherokee
Ordered some rear springs, planning on installing them tomorrow. Also noticed the valve cover leaking , probably because the steel sleeves are missing . While I was looking around I happened to notice an American flag decal and a heat tab on one of the freezeplugs , it's a Jasper engine!! It's definitely clean inside and explains why everything is in good shape. -
Differential cross pin bolt
Strokermjcomanche replied to Strokermjcomanche's topic in MJ Tech: Modification and Repairs
I wouldn't want that rollpin to come out,I know that CrossPin can do some serious damage.I know it wasn't the greatest set up but I'd rather have a bolt that I can unbolt if need be. -
Factory MJ rear 44 -
So the bolt head broke on my Dana 44 for the cross pin . i'm changing axle seals I need to get it out, seeing what everyone else has done. I know it's a common problem but never encountered it personally. Some people say they hit the pen really hard and it will shear the bolt ,other people say buy a kit that has a special drillbit and bolts to remove it. Seeing whatever one else is done before hand. Thanks for your help
Can't access private messenger .
Strokermjcomanche replied to Strokermjcomanche's topic in Forum Issues, Ideas, Testing
X2 -
I'm guessing it has to do with the update, or maybe it's something that I did or didn't do. I have access to pretty much everything else except for that.
I've sold a couple sets of 2dr manual door panels /regulators in the past couple years , my friends work at yards and give me heads up before they are put in the system . I agree with the low class people, can't tell you how many times I go to get parts that were perfectly good and somebody ruined. It would've taken a couple minutes to do it correctly, and if it was the part that they needed that got ruined they would feel the same way (maybe) .
I know some people seek them out so they can still roll the windows down when they take the doors off and on . I ran into several Cherokees with them around here, and normally on the base models as mentioned above. I don't know if I call the rare , but definitely not the main stream Cherokee for sure
1999 Cherokee
Thanks. It is ,only been up north for a couple years and the salt hasn't taken its toll yet . -
1999 Cherokee
There's only a couple things I wanna do to it at the moment. It basically needs springs all the way around, the rears are sagging pretty good.Probably put some new shocks on it, The previous owner must've put brakes all the way around on it recently because they look like brand new .Being that it's 2wd i'd also like to convert it to 4wd , and that's basically it.The paint isn't great in a couple areas, maybe touch it up a bit or just leave it alone.
