dasbulliwagen
    3
  1. O2 sensor, fuel pressure, fuel filter, would all be things to look at. Mine would cut out at times while driving too, but never at idle, turned out to be the O2 sensor, cleared it right up, but change the fuel filter too. I had a Ford F250 once that would cut out like that, it turned out to be a gas tank full of rust that would clog up the inlet screen, and pack the filter full of crud...not as likely here, but still a possibility.
  2. Pete! How about a snail mail address for those of us who don't have paypal, nor the need to set one up. Maybe make a new stickie with all the donation information! We love ya Pete and all you do for us! Keep up the good work!
  3. It most likey has the 904, but I worry about an AW4 holding up to an 800HP engine. You may want to look at building a 727 type as found behind the 258 in the Grand wagoneers. I know there are a ton more performance parts for that trans and that they can be built for higher HP.
  4. Take a picture of the transmission for us to see which one you have... may make a difference for you in the future. It could have either the BA10/5 or the AX15. The AX15 being the better trans. I think early 89 had the BA, and later 89 had the AX.
  5. Bias ply tires? REALLY??? Is this going to be a daily driver? If so you'd really be better off with some radials.
  6. GALAGA!!!!
  7. I know extreme 4x4 on power block was a rerun, but it was like a complete Rusty's love fest on there today. I know that extreme is getting paid by them to be like that, but are we the only ones that don't like Rusty's or are other forums/clubs like us, when it come to them? Just thought Id throw this out there. I don't really frequent any other forums so I don't really have a clue when it comes to this. Can anyone share their experiences on other forums about rusty's or are we alone?
  8. ALL column shift MJ's are automatic transmissions. AW4.
  9. Wasnt there someone talking about getting rear discs for these froma crown vic? Id like to know more about that too if it is what it is.
  10. Not true. Had a friend get busted like that in a private parking lot. Got a ticket for "Performance Driving"... it was like a 4 point ticket!
  11. An AX15 would not have been mounted behind the 2.5 in an XJ. It would have been the AX5.
  12. To convert your AC to r134a you should get a new accumulator or receiver dryer.... can't remember which its called on this model, and a R134a conversion kit for your model.... most parts stores should be able to help with this. Install the new accumulator, install the R134a fittings in their proper places and take it to a shop to have it properly vacuumed and charged with new oil. Not really a big deal.
  13. Trouble shooting ....... just aim better next time! :rotf:
  14. To swap the 4.0 into an 86, you MAY or may not need to finnesse the firewall, and you will need to swap the front core suppert in order to use the 4.0 radiator, because theres no way the 2.8/2.5 rad will work with the 4.0. I'm not sure if its just a bolt up job, but I'm sure someone else will chime in with that.... I'm thinking there will be some welding? You seem to be on track with everything else. You will probably need a rear driveshaft made to fit because the cherokee one will be too short, and the comanche original will be too long. The 86 most likely has a dana 35 with probably 4:56 gearing... but that will need to be confirmed. 86 metric tonne models came with a nice AMC corporate 20 rear end, which is comparable to a dana 44, but they are extremely rare. Do not campare this 20 to the CJ 20 with its weakness, they are different animals. Let us know what you find and keep us updated. And start a thread in the projects section!
  15. Got pulled over in mine for failing to put my new plate sticker on.... the new registration and sticker was right there in my ashtray waiting to go on. Cop saw I was really up to date and let me go! :thumbsup:
  16. HEHEHEEHEHE!!!! Been there done that! I also did the 2x4 as a cab lift to compensate for rotted floor and cab sag in a Ford Ranger. ALuminum street signs work real good too! I'm glad I don't live up north anymore!
  17. WOW! :popcorn: I havent been in the projects section in a while. I always miss the good stuff!
  18. 50 liters is more like 12 Gallons..... not that it matters.... you do a lot of riding... thats the point! Looks like fun. I never got to ride a quad, but My bike I think gives the same feeling of being out and free. Keep it up and good luck with your training!
  19. Read somewhere that it has pulled in more than 1 BILLION dollars in box office worldwide already. BILLION!
  20. How badly damaged was the Comanche donor? I hope you didnt cut them off of a nice truck that could have been saved. Please tell us otherwise....pleeeeeese! But on the other hand.... AWESOME PROJECT! Keep up the good work and keep the pics coming!
  21. Where in North Carolina are you guys? I'm in Asheboro.
  22. Bought steel today to begin fabrication of bumper mounts for an XJ rear bumper. When I get started I will make sure to take pics and maybe make a DIY thread. From initial looking and measurements it should be fairly easy and straightforward. I would like to add a hitch at the same time too if possible, I have a bunch of parts to fab one from so we will see what happens. Ill keep ya posted.
  23. You won't get the built up stink of burned kerosene if you go with the propane unit. In an enclose garage too, you should eventually look into a permanent forced air heat system to bring fresh air in or at least to separate the burned air and vent it out so as to avaoid carbon monoxide poisoning.
  24. Seeing those pics makes me really want to finish my 4x conversion! NICE!
