FrankTheDog
Everything posted by FrankTheDog
  1. There can’t be many left optioned like that truck is. I don’t think I’ve seen more than a half dozen short bed fleet sides in my life. With the Honcho package and a 401? Probably never. At least since the early 80’s.
  2. Did you buy it?
  3. Where’s that?
  4. I has welding skilz.
  5. Mid engine under the bed. A lot of them also have 4 or 5 speeds column shifted.
  6. https://duckduckgo.com/?q=kei+truck+parts+in+usa&t=iphone&ia=web This should help you find Kei truck parts.
  7. This is to adapt a wiper motor?!?! LOL, now that makes more sense!
  8. So it allows an HO engine wiring harness to plug into a renix computer?
  9. The engine or the fuel injection/ignition system? As in Renix vs HO?
  10. What exactly does this do?
  11. Our winter didn’t start until the middle of March when we received 2 feet of snow. Then it was gone in a couple weeks.
  12. Startron disperses the water throughout the the fuel. I run it in everything except my daily drivers.
  13. This, pull the carburetor off and on a clean surface disassemble it and clean it. Use carb cleaner to clean out the passages. i use a small masons plastic mixing tub I picked up at Home Depot to clean my fuel system stuff. If anything falls out it can’t go anywhere’s.
  14. Could be a piece of debris got caught in between the float needle and its seat.
  15. Always shut it off by turning the gas off. That way you won’t flood the engine again. Everything l have that’s not a 2 stroke gets the gas shut off to turn it off. I also run startron in all my occasionally run equipment.
  16. Did you check the frames on those 4Runners? My neighbor has a 2000 V6 and the frame was swiss cheese and there was zero rust on the body itself. He went down south and bought a clean frame and had the frame cleaned up and painted and swapped into his truck. Now the whole thing looks like brand new.
  17. That’s for the coke to keep the drivers going.
  18. I would leave the color alone. It’s a close enough shade that it’s not a garish contrast. Save your money for more important things.
  19. https://www.foxnews.com/video/6323422056112 Here it is. That is an impressive launch.
  20. That’s a beautiful truck!
  21. And load capacity?
  22. Smart cars, Dumb drivers. Asleep at the wheel because it has Autopilot. But he’ll be safe!! Lol
  23. How’s this for safe. Luckily l put 4:10’s in it before I tried this endeavor. 1981 Westy hauled from Knoxville to Winsted CT.
