8
Everything posted by mjeff87
First one I've seen with my own eyes, they just put it in there yesterday. Anyone need any parts off it? I'm gonna pull the battery tray JIC anyone wants to run a dual battery setup. Anything else worth grabbing? Jeff
I've never run one, so I can't speak from experience. But a couple of reputable guys over on NAXJA have, and say they really help (and the 2.5 needs all the help it can get). The way they work is that they add rotational mass to the end of the crank to keep it spinning between ignition (power) pulses..which on a 4 cyl is only 1 every 90 degrees. They don't do so much for top end, rather it keeps the engine running when you lug it down to low rpm's, which is where I have problems. If I keep the wheelspeed/rpm's up either by pedal or using 4LO it does fine, but if I'm in sticky mud or stall on a hill in 4HI I have problems :headpop: There's times I'm in 4LO when I shouldn't have to be, and I don't like crazy wheelspin :driving: I figure between it and deeper gears I can avoid both situations (crosses fingers) I feel it's a worthwhile mod for what it costs if you wheel a 2.5 I'll do a writeup with pics and post in the projects forum when the time comes. Jeff (and NO, I don't want to swap in a 4.0L...at least not yet)
Yeah, I know they'd be better, but I'm doing this on the cheap :D I scored a D30 with stock 4.56's in it out of the 'yard (from a 2.5/AW4 XJ) for $80....it's been sitting in the garage in PA for almost a year now. I traded 2 XJ D44's for an MJ D44 (3.07, open :cry: )and a brand new set of 4.56's with install kit. All I need is either an open carrier (and drop in a quick loc later) or a detriot now....I can't decide which to do. Add $100 or so for a gear setup, do a disc conversion on the '44 and slap them in. I oughta go full locker now, but funds are kinda lacking at the moment :( Oh, and I want to add an inertia ring when I swap trannies out. ^^^fall project^^^ Jeff
anywhere between 18-20 mpg in my 2.5, depending on which way the wind is blowing :D 4.10's turning 235/75's, and 171K miles Stepping up to 31's soon, and regearing to 4.56's...hopefully it'll be a wash mileage-wise, although I don't see me commuting in it much at that point. Jeff
I would suspect the O2 sensor is hosed, but if you're trying to start it cold that shouldn't matter. The ECU stays in open loop until the engine warms up, then starts adjusting A/F based on sensors. Try disconnecting it just for kicks and see if it fires :D I had an O2 go bad on my MJ last year and it caused all kinds of random poor running/cutting off problems. I checked everything and couldn't find the cause, and started disconnecting sensors one at a time to see if any had an effect. CPS and MAP sensors killed the engine immediately, TPS just caused more wacky running, but when I pulled the O2 off everything cleared up. I ran with it discoed for about a month, then one day hooked it back up and it didn't change anything....still ran (runs) good. So I left it connected :nuts: Do like Pat says and start with the basics (air, fuel, spark, compression) Jeff
any thoughts on 07 pow wow?
mjeff87 replied to wombat's topic in Adventure Planning / Regional Groups
Mostly bondo, duct tape, and rust here :D I vote either Tellico or Paragon (either of which I have a realistic chance of actually getting to....) Jeff -
I gots class.....mine are stored in the crawl space under my house, not in the backyard (which is full of lawnmowers, axles, and other crap :D ) I'm not on a distributor level like you guys, but I do have a full set of 235's mounted for the MJ (selling them off this weekend, tho), a full set of 175/65's mounted for the Escort, 3 old mounted 175's I took off the Escort (using the fourth one as a full size spare instead of the stupid donut that came stock), the stupid donut spare, and one old truck tire on a rusted out steel wheel that came with the house when we moved in :nuts: Jeff teaser pic: Image Not Found
Getting Ready to Start My First MJ
mjeff87 replied to StylerG's topic in MJ Tech: Modification and Repairs
There's really only a couple sensors on them that feed input to the ECU: TPS (if bad, will run like poo) CPS (if bad, won't run at all...carry a spare in your toolbox ;) ) O2 (can cause erratic, random poor running, hesitation) MAP (same as TPS) MAT (meh....) -
Opinions/advice needed on my 4x4 conversion
mjeff87 replied to clarkerussell's topic in MJ Tech: Modification and Repairs
By the way... why wouldn't you want to resurface the fly wheel? AX15's in particular have a specially shaped 'wheel...it's concave rather than flat. Machining it will remove the concavity (is that even a word? :D ). Also, internal slave/throwouts are very sensitive to changes in clearance between the clutch disc and flywheel....if you do machine it, you should shim out the throwout the same amount as what was machined off the 'wheel. All that being said....I machined my flywheel on my AX5 and didn't have any problems. Cmcolfax machined his and we tried installing an AX5 in place of a dead auto in his YJ and we're having problems with it. Basically, it don't work :headpop: Best bet, if the flywheel is bad enough that it needs to be machined, and you can spare the cabbage, you're better off replacing it. Jeff -
I have a new clutch, but it's for my old BA10... Do you know if the clutch and pressure plate are the same? If not, what clutch would I need to get? Would I need one from a newer XJ that the NV3550 came from? Thanks. Clarke I don't know for sure. Physically they're likely to be the same size (9.75" or so), but the input spline count may be different between the cases. Try calling the dealership, or check an auto parts store to see if the part #'s are the same. -
Yeah, it's a one piece deal. Think I got mine at Advance or Napa. The Haynes said specifically to not lube it before install, but that went against everything I know about seals....so I smeared some all purpose grease around the inside it first. It ain't blown up yet, and it ain't leaking :D Jeff -
got new clutch stuff? You'd be foolish to not replace it if it needs it. DON'T have the flywheel resurfaced. Replace all the UJ's in both driveshafts (not essential, but again it's a perfect time). They don't like changes in operating angles. Jeff -
Yay! another 2.5-er on the board! :cheers: Welcome. X2 on the RMS. There's also a freeze plug back there above it you might want to inspect and replace if necessary. You may or may not need an inverted torx socket (E12)for the top two bellhousing bolts. 4.0L's have them, but 2.5's seem to use regular hex head bolts. But, it's the same size you'll need for the starter bolts if they're original. If you come across any in either spot, go ahead and replace them with regular head bolts (or studs even). Also, pay attention to the combination of bellhousing bolts/nuts as you take them out.....they are different lengths. Don't just toss them all in a box and trust that you'll remember where they're supposed to go back ;) Jeff -
You won't be able to run the bolt from the inside out, if that's what you're planning :cry: It will contact the sway bar. Jeff
Duct tape works in a pinch, too.... (except for a forehead injury, you'd have to wrap your whole head mummy style :roll: Might sting a little when you take it off) Jeff
Side view mirrors and door questions...
mjeff87 replied to Andy in Pa's topic in MJ Tech: Modification and Repairs
FWIW, those dinky little mirrors are break-away types....so if you hit something with them (say like, a ZJ on the interstate going about 60 mph :oops: ) they snap off instead of ripping half the door away with them :D oh, and they just pop back on, too..... Jeff -
On the passenger side, watch the length if yours is a 4.0L. It pokes thru the framerail right about where the alternator is :cry: I've pulled several sets off XJ's in the 'yard, and it looks like the older models (pre-92ish) use a regular nut on the end of the bolt, and it just clearances. Later models have the hole in the framerail enlarged, and the nut is sleeved (it fits inside the hole and the end is flanged), so it sits flush with the framerail and doesn't contact the alt. The above does not apply if you run a 2.5....plenty of room there, and the alt is on top :cheers: You can't flip it around, either, because the bolt will hit the swaybar (if you have one :D ) Jeff
and/or a cutoff wheel :evil:
It couldn't hurt to use a dab. I use blue loctite on most everything :D Funny story, two days after I first got my MJ, I drove it from Pittsburgh to Norfolk and back. It had been sitting dormant in a garage lot for 6+ months, but it fired up and ran like a champ. The next morning, I started it up and is was only running on 3 of the 4 cylinders. Turns out the rocker bridge on #3 loosened up and the intake rocker tip slid off the end of the valve (oops). I guess the 16 hour roadtrip at interstate speeds vibrated the bolt loose..... Jeff
$23 for all of it ;) but the whole swap is gonna cost about $100. I need to pick up new rotors, pads, parking brake pads, new spring/anchor kits, and e-brake cables if I can't get the MJ ones to work (I shoulda grabbed the cables off the ZJ for $5/ea but I didn't.....). Might also have to replace the mounting studs in the axle flange if they aren't long enough, too.
Alex, I'm talking about just swapping the brake assemblies from a ZJ D35 to your axle, not swapping in the whole thing (unless the 'yards up there won't part axles out). ZJ D35 discs (which come stock on some models) should be a direct bolt-on to your D35. You might have to get a bit creative with the parking brake cables. I'm swapping ZJ D44 discs onto my MJ D44. I was going to use Crown Vic discs, or ZJ D35 discs (both with some modification required) because ZJ D44 discs are a pretty rare bird, but one just happened to show up a couple weeks ago in the 'yard. Here's the parts I grabbed (and the ones you will need). The rotors/pads/parking brake pads were shot so I didn't take them...I'll just get new ones. Jeff Image Not Found
Hey Andy...welcome aboard :cheers: Jeff (aka "Jeff in VA" over on NAXJA) p.s You can do a 4WD conversion pretty quickly :brows: , if ya have all the stuff...just unbolt the 2WD junk and swap in the new stuff..no modding necessary unless you reuse your 2WD rear DS (have to cut it down a bit)
Jerry hooked me up with a spare receiver plate holder he had, so it's a little less bootyfab now :D I just have to unsplice the light wires and add a connector. Then it'll be a quick disco rear plate..... Jeff Image Not Found
!!need help on oil leak and blown brakes!!
mjeff87 replied to GirsMJ86's topic in MJ Tech: Modification and Repairs
http://www.comancheclub.com/forums/view ... prop+valve http://www.naxja.org/forum/showthread.p ... +rear+prop Enjoy the read. Jeff
