mjeff87
    8
Everything posted by mjeff87
  1. Not yet....but I will eventually. Gotta keep it semi-presentable at the moment to keep the wife happy :nuts: you know. Once those quarters get smashed up enough, she'll say it looks ghetto and I'll say "I'll just cut 'em off, then" That's my plan......
  2. I cut it ALL out, plus had to trim the rear of the framerails a tad. Special bonus was the noxious green/blue smoke that came off while cutting :D Jeff Image Not Found
  3. It only took me 3 months, but I finally set aside a weekend and got Pat’s old rear bumper mounted on the MJ. It took a sawzall, angle grinder, and about a case of beer :evil: but I’m very happy with how it turned out. The only things left I have to do are tack weld the brackets to the framerail, add a drip/spash panel under the tailgate, and figure out a less-ghetto way to hang the license plate light. I’m thinking about making a receiver mounted plate holder so I can pull the plate/light off when wheeling so I don’t smash it all to #%@*$. (Sorry Pat…..I had to trim it a bit to get it to sit how I wanted it :teehee: ) Herewith, on with the pics….. The stock POS bumper Image Not Found The replacement Image Not Found Need to trim some stuff Image Not Found Test fit…..it didn’t Image Not Found Notching the framerail Image Not Found and the bumper brackets also Image Not Found got some spare parts left over (anyone need any of this crap?) Image Not Found had to shorten the bumper ends a bit Image Not Found flap disc-ed and ready for paint Image Not Found it fits now! Image Not Found sits nice and flush Image Not Found shot from under (I cleaned it all up and undercoated some) Image Not Found all done Image Not Found Image Not Found
  4. It was a good weekend. Got Pat's bumper mounted up finally (see post in the projects forum), and scored a set of ZJ D44 disc backing plates and calipers from the 'yard. $23 out the door..... I was going to use a set of Crown Vic discs but this makes it sooooo much easier! Jeff Image Not Found
  5. The contractor that did the install is on scene now. It appears that when they pulled the cabling for that leg thru, they pulled it a bit too tight :cry: It's been in for almost a year, and I guess it finally chafed enough to make contact. Can you say "spark shower"???
  6. Almost burned down the building at work this morning. This is what happens when you have a dead short on a 1750KW emergency generator feed......this happened about an hour ago, and the conduit is still hot to the touch. More pics at I gotta go change my pants right now :eek: Jeff Image Not Found
  7. I carry a "junkyard" box....it's a large metal ammo box I picked up at a flea market. It carries the usual hand tools, in addition to: torx bit set allen wrenches (SAE and metric) multimeter wire stripper/needlenose/line tool 8 mm combo wrench 10 mm socket (by far the most used tool in the box) paint pen scissors telescoping magnet (I drop stuff alot :D ) small bottle jack that I hide in the bottom of the box and cover up with all the other crap Everything else (the big stuff) I leave back in the truck and go get if I need it: 1/2 drive socket set (with 32 and 36 mm sockets) 1/2 breaker bar crowbars, deadblow hammers pipe wrench hacksaw cordless screwdriver w/ bit set tarps come-along Jeff
  8. Other end of the state, the "Pittsburgh" side....and there ain't sheeeat over there. That's why I moved to VA, so I could have a junkyard to build my MJ from :D Jeff
  9. It's an internal slave. Cabz/Pete/anybody.....whatcha got? Jeff
  10. mjeff87
    pure madness
    ARB huh....wanna get one for me too :bowdown: :D Yeah, you won't need a carrier. Jeff
  11. mjeff87
    pure madness
    Give girsmj86 a ring on that. You're alot closer to him than I am.... Jeff
  12. X2 :cheers: Jeff p.s. let me know how much lift the ZJ coils give you. I've got a set to toss into mine, and am hoping between them and a 1-1.5" spacer I can get 3" in the front. Mine is (was) a 2WD 2.5L also
  13. Drilled out the rivets and pulled the pan thingy last night, but still didn't get enough space, so the rest of the panel is coming out tonight via the sawzall. And I either have to notch out a space under the lights, or nip about 5/8" off either side of the bumper to make it fit inside of them. Think I'm gonna go the latter route.....I think it'll look and function better tucked in flush. Oh, and I gotta loose the spare tire cable jack thingy too..... :D Jeff
  14. http://www.pirate4x4.com/tech/billavist ... n_AX15.pdf That might help a bit ;) Jeff
  15. I have to chop that piece out, plus notch out under the taillights. I'll have to figure out some way to seal up under the lights so they are somewhat weatherproofed....I've got some leftover 22 gauge from when I had to patch the floorboard on my Escort I might just pop-rivet in there. I also have to drill out and retap 4 of the bumper mount bolts that snapped off @$%*!#
  16. Whatever it's called.....does anyone need one? It's that piece of sheetmetal under the rear of the bed that's rounded out in the center for the spare tire. I'm gonna fab up Pat's old rear bumper on my rig this weekend, and I'll have to loose mine to get the bumper to fit up. If anyone needs it, I'll take some care in cutting it out ;) and I can mail it out. Otherwise, it's gonna meet a horrible death via the sawzall :evil: or cutoff wheel. Lemme know if anyone wants it...... Jeff
  17. I still might roll up there and check it out....but I'm committed to getting your old bumper mounted up on my MJ this weekend :D We'll see what happens. Jeff
  18. I've got a spare CPS too if you need it, plus a couple spare fuel pump relays I carry with me. Give me a shout on my cell if you need help (but I'm stuck here at work 'till 3:30 or so). Where'd it die at? Jeff
  19. on a riding mower???? boooyah! I do know of two seperate incidents (not me personally, mind you) of people being issued DUI's on riding mowers.
  20. I'm ashamed to admit, but if you guys think I keep the engines clean in my Escort and the MJ.....y'all ain't seen my riding mower yet :brows: I get a little OCD on it (but I have to store it outside under a tarp, so I consider it "weatherproofing" it more than anything) I don't think I could bring myself to enter it into a roundy race, but wouldn't mind going to check one out. Add it to the list of things my wife won't be interested in..... Jeff
  21. Anyone into it? I just found out we have a state association :nuts: http://www.vlmra.com/ Pat! the next race is practically in your backyard, up there on the peninsula. Wanna go drink some beers and watch some 'necks? :D Jeff
  22. between you and Eagle, you guys must have most every MJ covered on the Atlantic coast :D Welcome to the club! and, by the way......."Raven" = :drool: Jeff
  23. I fergot to verify :dunce: , but from what I remember looking at, I didn't see an external cylinder on it, so it must be in-. I'll call him tomorrow and make sure. Jeff
  24. I eyeballed it, and it's definately an AX15. I suggested he just weld it up but he wants to replace it. It's a bow-shaped crack that runs the entire length of the bottom where it mates to the gearbox. I honestly don't know what's holding that chunk of metal in place aside from good luck ;) Gonna see if I can snag an Xj one out of the boneyard, unless someone on here has an extra BH laying around they'd want to part with (and save my back from dropping a tranny). Either ship to me in VA or I can get an addy for him in PA. Jeff
